This sample shows you how to serialize objects in Map Suite to XML and then deserialze them back to objects. This is usefully in many GIS mapping application to save the state of styles, layers, projections or just about anything. The XML is readable and well formatted, great for working with in you GIS application.
This sample shows you how to generate source code calls from Map Suite objects. Imagine that you have a Layer that has been styled a particular way and uses a certain projection. Once the object is created you can pass it to the code generator and it will create source code to re-create the model passed in. This is very helpful especially in GIS applications where users define things through a custom UI but then want to leverage that in code.
Sample:Context Menu with Sub Menu
Based on a discussion forum request, today's web project shows you how to add sub menus to ContextMenu. This is a built-in function in all of the most recent daily builds of Map Suite, which you can download from the ThinkGeo Customer Portal. This project also demonstrates how to enable the ContextMenu's auto wrap feature when you click on the edges of the map.
Sample:Current Extent to Bitmap
Sample:Use Map with MVC Framework
