This class inherits from the Overlay abstract class. This specified overlay stores the AdornmentLayer used in the MapControl.
Provides data for the ControlPointSelected event.
This enumeration specified the control point type when editing a shape. The deafault value is None
This enumeration specifies the type of extent change that has occurred when doing interactive actions with InterativeOverlay.
This class inherits from InterativeOverlay abstract class. This specified overlay describle the Extent Changing interative process with MapControl using Mouse or Keyborad.
This enumeration specifies the picture formats when getting images back to client from Google Maps.
This class encapsulates the information and simple method for interactive actions.
This class inherits from Overlay abstract class. This specified overlay describe the interactive process with MapControl using Mouse or Keyboard.
This enumeration specifies the mode to draw the InterativeOverlay when doing interactive actions with InterativeOverlay.
This class specifies the InterativeResult when deal with the Interative method in InterativeOverlay.
This enumeration specifies the behavior that occurs when double tap on the MapControl. The default value is ZoomIn.
Contains the different map tools as properties and acts as an entrance for setting these map controls.
This class represents an overlay that requesting images from OpenStreet Map Service.
This enumeration specifies the mode to process other overlays when doing interactive actions with InterativeOverlay.
This class inherits from InterativeOverlay abstract class. This specified overlay describle the TrackShape interative process with MapControl using Mouse or Keyborad.
This enumeration specifies the type of transition effect to use when the map is panned or zoomed.
This class represents an WmsOverlay which has MapSuite world map kit server integrated.
This enumeration represents which projection will use for world map kit.
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
This is the base class for NativeTileCache system which inherits from TileCache class.
This class represents the parameters passed in through the CreatedMemberNode event.
This class represents the parameters passed in through the CreatingMemberObject event.
Indicates how the default value of a member will be dealt with by the modeler.
When applied to a method, specifies that the method is called after serialization of an object graph.
When applied to a method, specifies that the method is called before serialization of an object.
