map_suite_mobile_for_ios
Map Suite Mobile For iOS
Map Suite for iOS is a powerful .NET control that lets you add interactive maps and professional-grade GIS to your iPhone® and iPad® apps. Using the power of the Xamarin mobile platform and ThinkGeo's Map Suite together, you can develop native iOS apps using the C# language and .NET libraries you're already familiar with.
Map Suite Mobile for iOS Quickstart On iOS
Run GitHub Sample on iOS(4'02“)
Map Suite Mobile for iOS Hello World
Hello World on iOS(4'14”)
Product Guides
Helps you get started building your first application with the Map Suite Mobile For iOS.
Introduces the dependencies Map Suite Mobile for iOS needs with their features, versions and source websites.
Learning Samples
Package
Standard
Standard version contains commonly used packages which should meet most user's requirements. The packages which are not included are not commonly used and very big in size, such as FDO package, Oracle Package, etc. You can always reference those packages separately.
Compare with Barebone
Barebone
Compare with Standard
API Documentation
  • ThinkGeo.MapSuite.iOS
    The The Mobile for iOS API documentation covers the ThinkGeo.MapSuite.iOS namespace which resides in the ThinkGeo.MapSuite.iOS.dll assembly. It contains all of the The Mobile for iOS specific classes such as the map control itself, Overlays, and supported map classes.
Change Logs
  • API Change Log
Videos
Step through the Mobile For iOS sample applications and see how they're put together. We'll demonstrate how to use each app, then take you through every part of the source code and show you how it works.
iOS Getting Started Sample
iOS Getting Started
iOS Map Visualization Learning Sample
iOS Labeling Learning Sample
iOS Drawing & Editing Sample
iOS Geometric Functions Learning Sample
Screenshots
The Mobile For iOS screenshots gallery section showcases a wide range of screenshots covering various GIS features of the Mobile For iOS map control.
Tablets
Getting Started with Map
Visualization
Visualization
Label Styling
Label Styling
Geometric Functions
Geometric Functions
Drawing And Editing Features
Siteselection
Siteselection
Visualization-US Weather
US Earthquake Statistics
Phones
Visualization
Visualization
Label Styling
Label Styling
Geometric Functions
Geometric Functions
Siteselection
Siteselection
Frequently Asked Questions
map_suite_mobile_for_ios.1489457757.txt.gz · Last modified: 2017/03/14 02:15 by tgwikiupdate
