ThinkGeo.MapSuite.Android,
Version=10.0.0.0, Culture=neutral, PublicKeyToken=null
namespace ThinkGeo.MapSuite.AndroidEdition {
[SerializableAttribute]
public class AdornmentOverlay : Overlay, IDisposable
public GeoCollection<AdornmentLayer> GeoCollection Layers { get;
public Boolean ShowLogo { get;
set; }
public class CenterCoordinateMapTool : MapTool {
public class EditInteractiveOverlay : InteractiveOverlay {
public
InMemoryFeatureLayer SelectedControlPointLayer
{ get; }
public class GpsMarker : Marker,
IDisposable {
protected
virtual void Finalize();
public class LayerOverlay : TileOverlay
public GeoCollection<Layer> GeoCollection
Layers { get; }
public class MapLayout : ViewGroup
public abstract class MapTool
: RelativeLayout {
public class MapTools : GeoCollection
: GeoCollection<MapTool>, INotifyCollectionChanged, INotifyPropertyChanged
public class MapView : RelativeLayout
public GeoCollection<InteractiveOverlay> GeoCollection InteractiveOverlays { get; }
public GeoCollection<Overlay> GeoCollection Overlays { get;
public class Marker : ImageView
public class MarkerOverlay : Overlay,
IDisposable {
public GeoCollection<Marker> GeoCollection
Markers { get; }
public class OpenStreetMapOverlay : TileOverlay {
[ObsoleteAttribute("This constructor is obsoleted and will be removed in or
after version 10.0. Please use OpenStreetMapOverlay() instead.")]
public OpenStreetMapOverlay(GeoWebProxy webProxy);
[ObsoleteAttribute("This property is obsolete and might be removed in or
after Version 10.0. Please use TileCache instead as following code:
openStreetMapOverlay.TileCache = new
FileBitmapTileCache(CacheDirectory);")]
public String CacheDirectory { get; set; }
protected
override void CloseCore();
[ObsoleteAttribute("This method is obsoleted and will be removed in or
after version 10.0. WebRequest is not used for requesting web images in this
class.")]
protected
virtual void OnSendingWebRequest(SendingWebRequestEventArgs e);
class.")]
protected
virtual void OnSentWebRequest(SentWebRequestEventArgs e);
[ObsoleteAttribute("This property is obsoleted and will be removed in or
after version 10.0. This property used to wrap another property on
OpenStreetMapLayer, while it is not used now. Please use TileCache property
instead.")]
public BitmapTileCache ProjectedTileCache { get; set; }
instead.")]
public Projection ProjectionFromSphericalMercator { get; set; }
[ObsoleteAttribute("This event is obsoleted and will be removed in or after
class.")]
public event EventHandler<SendingWebRequestEventArgs> SendingWebRequest;
class.")]
public event EventHandler<SentWebRequestEventArgs>
SentWebRequest;
after version 10.0. WebProxy is not support for retrieving web images.")]
public GeoWebProxy WebProxy { get;
set; }
public abstract class Overlay
: IDisposable {
protected
override void Finalize();
[ObsoleteAttribute("This method is obsolete and might be removed in or
after Version 10.0. Please use Refresh(TimeSpan bufferTime,
RequestDrawingBufferTimeType bufferTimeType) instead.")]
public void Refresh(TimeSpan
bufferTime, BufferTimeType bufferTimeType);
after Version 10.0. Please use Refresh(IEnumerable<RectangleShape>
extentsToRefresh, TimeSpan bufferTime, RequestDrawingBufferTimeType
public void Refresh(IEnumerable<RectangleShape>
after Version 10.0. Please use Refresh(RectangleShape extentToRefresh, TimeSpan
bufferTime, RequestDrawingBufferTimeType bufferTimeType) instead.")]
public void Refresh(RectangleShape
extentToRefresh, TimeSpan bufferTime,
public class Popup : FrameLayout
public class PopupOverlay : Overlay,
IDisposable {
public GeoCollection<Popup> GeoCollection
Popups { get; set;
public class SqliteBitmapTileCache : BitmapTileCache {
public override virtual String CacheId { get;
set; }
protected
override virtual
void ClearCacheCore();
protected
override virtual
void DeleteTileCore(Tile tile);
protected
override virtual
BitmapTile GetTileCore(Int64 row, Int64
column);
protected
override virtual
void SaveTileCore(Tile tile);
public static class Validators
public static void CheckCanRefreshRegion(Boolean canRefreshRegion);
[ObsoleteAttribute("This class is obsolete and might be removed in or
after Version 11.0. Please use WorldStreetsAndImageryOverlay class
instead.")]
public class WorldMapKitOverlay : TileOverlay {
public class WorldStreetsAndImageryOverlay : TileOverlay {
public
WorldStreetsAndImageryOverlay();
public
WorldStreetsAndImageryOverlay(WebProxy webProxy);
public
WorldStreetsAndImageryOverlay(String clientId,
String privateKey);
public
WorldStreetsAndImageryOverlay(WebProxy webProxy,
String clientId, String privateKey);
public
Int32 TimeoutInSeconds { get; set; }
public
String ClientId { get; set; }
public
String PrivateKey { get; set; }
public
WebProxy WebProxy { get; set; }
public
WorldStreetsAndImageryMapType MapType {
get; set; }
public
WorldStreetsAndImageryProjection Projection
{ get; set; }
protected
override void
DrawTileCore(GeoCanvas geoCanvas,
TileView tile);
protected
override RectangleShape
GetBoundingBoxCore();
protected
override TileMatrix
GetTileMatrix(Double scale, Int32 tileWidth, Int32
tileHeight, GeographyUnit boundingBoxUnit);
public class ZoomMapTool : MapTool
public class AndroidGeoCanvas; //removed
public class BingMapsTileOverlay; //removed
public class GoogleMapsTileOverlay; //removed
public class OpenStreetMapTileOverlay; //removed
} //end of namespace ThinkGeo.MapSuite.AndroidEdition
ThinkGeo.MapSuite,
Version=0.0.0.0, Culture=neutral, PublicKeyToken=null
namespace ThinkGeo.MapSuite.Core {
public class AreaStyle : Style
public
override Boolean
IsDefault { get; }
public static class AreaStyles
[ObsoleteAttribute("We suggest you use the new static class
WorldStreetsAreaStyles as it has updated and better looking styles.")]
WorldMapKitAreaStyles as it has updated and better looking styles.")]
public static AreaStyle Antarctica1
{ get; }
public static AreaStyle Country1
{ get; }
public static AreaStyle Country2 { get;
[ObsoleteAttribute("We suggest you use the new static class WorldMapKitAreaStyles
public static AreaStyle County1
{ get; }
suggest you use the new static class WorldMapKitAreaStyles as it has updated
public static AreaStyle County2
{ get; }
[ObsoleteAttribute("We suggest you use the new static class WorldStreetsAreaStyles
public static AreaStyle Crop1
{ get; }
public static AreaStyle Evergreen1
{ get; }
public static AreaStyle Evergreen2
{ get; }
public static AreaStyle Forest1
{ get; }
public static AreaStyle Grass1
{ get; }
public static AreaStyle Military1
{ get; }
public static AreaStyle NoData1 { get;
public static AreaStyle Park1
{ get; }
public static AreaStyle Sand1
{ get; }
public static AreaStyle SeaIce1
{ get; }
suggest you use the new static class WorldStreetsAreaStyles as it has updated
public static AreaStyle SnowIce1
{ get; }
public static AreaStyle State1
{ get; }
public static AreaStyle State2
{ get; }
public static AreaStyle Swamp1 { get;
public static AreaStyle Swamp2
{ get; }
public static AreaStyle Tundra1
{ get; }
public static AreaStyle Urban1 { get;
public static AreaStyle Urban2
{ get; }
public static AreaStyle Water1
{ get; }
public static AreaStyle Water2 { get;
public static AreaStyle WaterIntermittent1
{ get; }
public static AreaStyle Wildlife1
{ get; }
public class BingMapsLayer : Layer
public IWebProxy WebProxy Proxy
{ get; set; }
public enum BingMapsMapType {
AerialWithLabels,
Aerial
//removed
members:
Birdseye,
BirdseyeWithLabels
public class BitmapTile : Tile,
IDisposable {
public
BitmapTile(GeoImage image, RectangleShape boundingBox, Double scale);
public GeoImage Bitmap Bitmap
{ get; set; }
public BitmapTile(Bitmap bitmap, RectangleShape
public class BuildingIndexShapeFileFeatureSourceEventArgs
: EventArgs {
public BuildingIndexShapeFileFeatureSourceEventArgs(Int32 recordCount, Int32
currentRecordIndex, Feature currentFeature,
DateTime startProcessTime, String shapePathFilename shapePathFileName);
public
String ShapePathFilename { get; }
[ObsoleteAttribute("This constructor is obsolete and might be removed in or
after Version 10.0. Please call
BuildingIndexShapeFileFeatureSourceEventArgs(int recordCount, int
currentRecordIndex, Feature currentFeature, DateTime startProcessTime, string
shapePathFileName) instead.")]
DateTime startProcessTime, Boolean cancel, String
shapePathFileName);
public BuildingIndexShapeFileFeatureSourceEventArgs();
BuildingIndexShapeFileFeatureSourceEventArgs(int recordCount, int currentRecordIndex,
Feature currentFeature, DateTime startProcessTime, string shapePathFileName)
instead.")]
DateTime startProcessTime, Boolean cancel);
public String ShapePathFileName { get; }
public enum CadStylingType {
EmbeddedStyling,
StandardStyling
//removed
members:
Default
public static class ClassBreakValidatorHelper
public static void CheckClassBreaksAreValid(IEnumerable<ClassBreak> classBreaks);
public static class CogoValidatorHelper
public static void CheckArcAndChordLengthIsValid(Double arcLength, Double
chordLength);
public static void CheckCogoDirectionTypeIsPolar(CogoDirectionType value, String parameterName);
public static void CheckDirectionIsValid(String direction, String
parameterName);
public static void CheckPointCogoFileRecordIsValid(String value, String
parameterName);
public static void CheckQuadrantBearingDegreeIsValid(Double value, String
parameterName);
public class DataGridPrinterLayer : PrinterLayer {
public PrinterTextHorizontalAlignment TextHorizontalAlignment TextHorizontalAlignment
{ get; set; }
public struct DegreesMinutesSeconds {
after Version 10.0. Please call GetFormattedString(int decimals) instead.")]
public String ToString(Int32
decimals);
public class DrawingProgressChangedEventArgs : ProgressChangedEventArgs {
public GeoCanvas Canvas { get;
set; }
public Int64 DrawingElapsedSinceLastInvalid { get; set; }
public RectangleShape DrawnExtent { get; set; }
public Boolean IsDrawingInvalid { get; set; }
public struct DrawingRectangle {
public
DrawingRectangle(Int32 centerX, Int32 centerY, Int32
width, Int32 height);
public
DrawingRectangle(Int32 anchorPointX,
Int32 anchorPointY, Int32 width, Int32
height, DrawingRectangleAnchorReference
anchorReference);
public
Int32 CenterX { get; }
public
Int32 CenterY { get; }
public
Int32 Height { get;
public
Int32 MaximumX { get; }
public
Int32 MaximumY { get; }
public
Int32 MinimumX { get; }
public
Int32 MinimumY { get; }
public
Int32 Width { get;
public
override Boolean
Equals(Object obj);
public
override Int32
GetHashCode();
public
static Boolean
operator==(DrawingRectangle rectangleF1,
DrawingRectangle rectangleF2);
public
static Boolean
operator!=(DrawingRectangle rectangleF1,
public
static DrawingRectangle
Round(DrawingRectangleF value);
public enum DrawingRectangleAnchorReference {
Center,
UpperLeft,
UpperRight,
LowerLeft,
LowerRight
public struct DrawingRectangleF {
public
DrawingRectangleF(Single anchorPointX,
Single anchorPointY, Single width, Single
anchorReference);
public
Single MaximumX { get; }
public
Single MaximumY { get; }
public
Single MinimumX { get; }
public
Single MinimumY { get; }
public class ExecutingSqlStatementMsSqlFeatureSourceEventArgs
: EventArgs {
public
ExecutingSqlStatementMsSqlFeatureSourceEventArgs(String sqlStatement);
public
ExecutingSqlStatementMsSqlFeatureSourceEventArgs(String sqlStatement, ExecutingSqlStatementType
sqlStatementType);
public
ExecutingSqlStatementType ExecutingSqlStatementType
{ get; set; }
public
String SqlStatement { get; set; }
public static class ExtendedHelper
public static String GetVersion();
public static Boolean ShowProductCenter();
public static class ExtentHelper
public
static RectangleShape
ApplyDrawingMarginToExtent(RectangleShape
worldExtent, Single marginInPixel,
Single screenWidth, Single screenHeight);
public
GetSnappedExtent(RectangleShape worldExtent,
GeographyUnit worldExtentUnit, Single screenWidth, Single
screenHeight, ZoomLevelSet zoomLevelSet);
public
static Double
GetSnappedScale(RectangleShape worldExtent,
Single screenWidth, GeographyUnit worldExtentUnit);
public
static Int32 GetSnappedZoomLevelIndex(Double scale, IEnumerable<Double>
zoomLevelScales);
public static DrawingRectangle
Rectangle ToScreenCoordinate(RectangleShape worldExtent, RectangleShape targetWorldExtent targetExtent,
Single screenWidth currentExtentWidth,
Single screenHeight currentExtentHeight);
public class Feature {
public
Boolean IsGeometryValid();
after Version 11.0. For compatibility use GetWellKnownBinary() != null. Most of
the time when this method is used IsGeometryValid(), which does geometry
validation using the NTS topology engine, would most likely be better
suited.")]
public Boolean IsValid();
public
static GeoDataTable
ConvertToDataTable(IEnumerable<Feature>
features, IEnumerable<String> columnNames);
public Dictionary<String,Collection<LinkColumnValue>>
LinkColumnValues { get; }
public abstract class FeatureLayer
: Layer {
protected
Collection<Feature> GetWrappingFeaturesForDrawing(WrappingWorldDirection wrappingFeatureDirection,
RectangleShape drawingWorldExtent, Double canvasWidth, Double
canvasHeight, IEnumerable<String>
returningColumnNames, RectangleShape wrappingWorldExtent);
public virtual Boolean CanDrawProgressively { get; }
public void DrawProgressively(GeoCanvas
canvas, Collection<SimpleCandidate>
labelsInAllLayers);
protected
virtual void DrawProgressivelyCore(GeoCanvas canvas, Collection<SimpleCandidate>
labelsInAllLayers);
public Int64 DrawingElapsedInMilliSeconds { get; set; }
after Version 10.0. We kept a default margin of 256 pixels which should be good
for most scenarios, you can always customize it by setting the property of
DrawingMarginInPixel.")]
public Double DrawingMarginPercentage { get; set; }
public abstract class FeatureSource
public GeoDataTable DataTable
ExecuteQuery(String sqlStatement);
public
protected Collection<String>
GetColumnNamesOutsideFeatureSource(IEnumerable<String>
returningColumnNames);
public
Collection<String> GetFeatureIdsInsideBoundingBox(RectangleShape boundingBox);
public
void RemoveEmptyAndExcludedFeatures(Collection<Feature> features);
protected
virtual GeoDataTable
DataTable ExecuteQueryCore(String sqlStatement);
protected
virtual Collection<String>
GetFeatureIdsInsideBoundingBoxCore(RectangleShape
boundingBox);
public
static GeoDataTable
public
static String
GetColumnNameAlias(String columnName,
ICollection<String> columnNames);
public
protected static
Collection<String> SplitColumnNames(IEnumerable<String> columnNames returningColumnNames);
public event EventHandler<AppliedFiltersFeatureSourceEventArgs>
AppliedFilters;
public Collection<Feature> ApplyFilters(IEnumerable<Feature> features, IEnumerable<String> returningColumnNames,
IEnumerable<String> filters);
protected
virtual Collection<Feature>
ApplyFiltersCore(IEnumerable<Feature>
String linkExpression);
public event EventHandler<ApplyingFiltersFeatureSourceEventArgs>
ApplyingFilters;
protected
IEnumerable<Feature> ConvertToExternalProjectionAsync(IEnumerable<Feature> features);
public Collection<String> Filters { get; }
public Collection<Feature> GetFeaturesByIds(IEnumerable<String> ids, IEnumerable<String> returningColumnNames,
public Collection<Feature> GetFeaturesForDrawing(RectangleShape boundingBox, Double screenWidth, Double
screenHeight, IEnumerable<String> returningColumnNames,
public IEnumerable<Feature> GetFeaturesForDrawingAsync(RectangleShape boundingBox, Double screenWidth, Double
screenHeight, IEnumerable<String> returningColumnNames);
protected
virtual IEnumerable<Feature>
GetFeaturesForDrawingAsyncCore(RectangleShape
boundingBox, Double screenWidth, Double screenHeight, IEnumerable<String>
public Collection<Feature> GetFeaturesInsideBoundingBox(RectangleShape boundingBox, IEnumerable<String> returningColumnNames,
public Collection<String> LinkExpressions { get; }
public Collection<LinkSource> LinkSources { get; }
protected
virtual void OnAppliedFilters(AppliedFiltersFeatureSourceEventArgs e);
protected
virtual void OnApplyingFilters(ApplyingFiltersFeatureSourceEventArgs e);
public Collection<Feature> SpatialQuery(BaseShape targetShape, QueryType
queryType, IEnumerable<String> returningColumnNames,
public class FileGeoDatabaseFeatureSource : FeatureSource {
protected
override GeoDataTable
public class GeneratingGridFeatureSourceEventArgs : EventArgs {
public GeneratingGridFeatureSourceEventArgs(Int32 gridCount, Int32
gridIndex, DateTime startProcessTime,
Boolean isCanceled, String gridPathFilename gridPathFileName);
public
String GridPathFilename { get; set; }
public String GridPathFileName { get; set; }
public abstract class GeoCanvas
public
static PlatformGeoCanvas
CreatePlatformGeoCanvas();
public class GeoCodeGenerator {
public void GenerateCode(Object
sourceObject, String pathFilename
pathFileName);
public class GeoDataTable {
public
GeoDataTable();
public
Collection<Dictionary<String,Object>>
Rows { get; }
public
Collection<String> Columns { get; }
public
void AddRow(params
String[] columnValues);
public
void AddRow(IDictionary<String,Object>
columnValues);
public
static DataTable
implicit operator(GeoDataTable geoDataTable);
public
static GeoDataTable
implicit operator(DataTable dataTable);
public class GeoDbf : IDisposable
public GeoDbf(String pathFilename pathFileName);
public
GeoDbf(String pathFilename, GeoFileReadWriteMode readWriteMode);
pathFilename, GeoFileReadWriteMode readWriteMode,
Encoding encoding);
public
GeoDbf(String pathFilename, GeoFileReadWriteMode readWriteMode, Encoding encoding, CultureInfo
cultureInfo);
public GeoFileReadWriteMode DbfReadWriteMode
ReadWriteMode { get; set; }
public
String PathFilename { get; set; }
public
void AddBooleanColumn(String columnName);
public
void AddColumn(String
columnName, DbfColumnType columnType,
Int32 length, Int32
decimalLength);
public
void AddDateColumn(String columnName);
public
void AddDoubleColumn(String columnName, Int32
length, Int32 decimalLength);
public
void AddIntegerColumn(String columnName, Int32
length);
public
void AddMemoColumn(String columnName, Int32
length);
public
void AddStringColumn(String columnName, Int32
length);
public
void UpdateDbcFilename(String newDbcFilename);
public static void CopyDbfHeader(String sourcePathFilename sourcePathFileName,
String destinationPathFilename destinationPathFileName);
String destinationPathFilename destinationPathFileName,
OverwriteMode overwriteMode);
public static void CreateDbfFile(String dbfPathFilename dbfPathFileName,
IEnumerable<DbfColumn> dbfColumns);
IEnumerable<DbfColumn> dbfColumns,
OverwriteMode overwriteMode, Encoding encoding);
public GeoDbf(String pathFileName, DbfReadWriteMode
readWriteMode, Encoding encoding, CultureInfo cultureInfo);
readWriteMode, Encoding encoding);
readWriteMode);
public String PathFileName { get;
set; }
public enum GeoFileMode {
CreateNew,
Create,
Open,
OpenOrCreate,
Truncate,
Append
public enum GeoFileReadWriteMode {
Read,
Write,
ReadWrite
[FlagsAttribute]
public enum GeoFileShare {
None,
Read,
Write,
ReadWrite,
Delete,
Inheritable
public static class GeohashHelper
public static String ConvertToGeohash(PointShape pointShapeInDecimalDegree, Int32 precision);
public static String ConvertToGeohash(Vertex vertexInDecimalDegree, Int32 precision);
public static String ConvertToGeohash(Double longitude, Double
latitude, Int32 precision);
public static PointShape ConvertToPointShape(String geohash);
public static String GetAdjacentGeohash(Vertex vertexInDecimalDegree, GeohashAjacentDirection direction);
public static String GetAdjacentGeohash(String geohash, GeohashAjacentDirection
direction);
public static String GetAdjacentGeohash(PointShape pointShapeInDecimalDegree, GeohashAjacentDirection direction);
public static String GetAdjacentGeohash(Vertex vertexInDecimalDegree, GeohashAjacentDirection direction, Int32 precision);
public static String GetAdjacentGeohash(Double longitude, Double
latitude, GeohashAjacentDirection direction);
public static String GetAdjacentGeohash(PointShape pointShapeInDecimalDegree, GeohashAjacentDirection direction, Int32 precision);
latitude, GeohashAjacentDirection direction,
Int32 precision);
public static Collection<String>
GetAdjacentGeohashes(Vertex vertexInDecimalDegree);
GetAdjacentGeohashes(PointShape pointShapeInDecimalDegree);
GetAdjacentGeohashes(String geohash);
GetAdjacentGeohashes(Double longitude,
Double latitude);
GetAdjacentGeohashes(Vertex vertexInDecimalDegree,
Int32 precision);
GetAdjacentGeohashes(PointShape pointShapeInDecimalDegree,
Int32 precision);
Double latitude, Int32 precision);
public class GeoImage : IDisposable
public GeoImage(String pathFilename pathFileName);
public
GeoImage(Object nativeImage);
public
Int32 Height { get;
public
Int32 Width { get;
public
Object NativeImage { get; set; }
public
Stream GetImageStream();
public
event EventHandler<LoadingNativeImageGeoImageEventArgs>
LoadingNativeImage;
protected
virtual void Dispose(Boolean disposing);
protected
virtual void OnLoadingNativeImage(LoadingNativeImageGeoImageEventArgs e);
public
static Object
CreateNewNativeImage(Stream stream);
public
static Object
CreateNewNativeImage(String imagePathFilename);
public
static Object
CreateNewNativeImage(Int32 width,
Int32 height);
public Int32 GetHeight();
public Int32 GetWidth();
public enum GeoImageFormat {
Bmp,
Emf,
Exif,
Gif,
Icon,
Jpeg,
MemoryBmp,
Png,
Tiff,
Wmf
public class GeoSerializer {
public
Object Deserialize(String sourcePathFilename, GeoFileReadWriteMode readWriteMode);
public void Serialize(Object
objectToSerialize, String targetPathFilename
targetPathFileName);
public Object Deserialize(String
sourcePathFileName, FileAccess fileAccess);
public class GeoTiffRasterLayer : RasterLayer {
public GeoTiffRasterLayer(String imagePathFilename, RectangleShape imageWorldExtent imageExtent);
public
String ImagePathFilename { get; set; }
public GeoTiffLibraryType LibraryType { get; set; }
public String PathFilename { get;
set; }
public class GeoTiffRasterSource : RasterSource {
public GeoTiffRasterSource(String imagePathFilename, String worldFilePathFilename worldfilePathFilename);
public
public GeoTiffRasterSource();
protected
override RasterSource
CloneDeepCore();
set; }
public class GoogleMapsLayer : Layer {
public
GoogleMapsLayer(String cacheDirectory,
String clientId, String privateKey, IWebProxy
webProxy);
public GeoImage Bitmap NoDataTileImage
{ get; set; }
public IWebProxy WebProxy WebProxy
{ get; set; }
public
String Language { get; set; }
public GeoImage Bitmap GetGoogleMapsImage(Double longitude, Double
latitude, Int32 zoomLevelNumber,
Double tileWidth, Double tileHeight);
protected
virtual GeoImage
Bitmap GetGoogleMapsImageCore(Double longitude, Double
public GoogleMapsLayer(String cacheDirectory, String
clientId, String privateKey, WebProxy webProxy);
public class GraticuleFeatureLayer : FeatureLayer {
public
GraticuleFeatureLayer();
public
GraticuleFeatureLayer(Projection projection);
public
GeoBrush GraticuleTextBrush { get; set; }
public
GeoFont GraticuleTextFont { get; set; }
public
GeoPen GraticuleTextHaloPen { get; set; }
public
LineStyle GraticuleLineStyle { get; set; }
public
Projection Projection { get; set; }
public
RectangleShape WrappingExtent { get; set; }
public
WrappingMode WrappingMode { get; set; }
protected
override void
DrawCore(GeoCanvas canvas, Collection<SimpleCandidate> labelsInAllLayers);
public class GraticuleFeatureSource : FeatureSource {
public
GraticuleFeatureSource();
public
public
protected
override Collection<Feature>
GetAllFeaturesCore(IEnumerable<String>
protected
override Collection<FeatureSourceColumn>
GetColumnsCore();
protected
GetFeaturesForDrawingCore(RectangleShape
Double screenHeight, IEnumerable<String> returningColumnNames);
public class GridIsoLineLayer : IsoLineLayer {
public GridIsoLineLayer(String gridPathFilename gridPathFileName);
public GridIsoLineLayer(String gridPathFilename gridPathFileName,
IEnumerable<Double> isoLineLevels);
IEnumerable<Double> isoLineLevels,
Double lowerScale, Double upperScale);
Double lowerScale, Double upperScale, IsoLineType
isoLineType);
public class Jpeg2000RasterLayer : EcwRasterLayer : RasterLayer
public
override Boolean
HasBoundingBox { get; }
public
public class Jpeg2000RasterSource : EcwRasterSource : RasterSource
public
protected
override void
CloseCore();
protected
protected
override GeoImage
GetImageCore(RectangleShape worldExtent,
Int32 canvasWidth, Int32 canvasHeight);
protected
override Int32
GetImageHeightCore();
protected
override Int32
GetImageWidthCore();
protected
override void
OpenCore();
public class KmlAdornmentLayer : AdornmentLayer {
public String kmlPathFilename { get; set; }
public enum KmlStylingType {
EmbeddedStyling,
StandardStyling
//removed
members:
Default,
EmbeddedStyle,
StandardStyle
public abstract class Layer
public
Dictionary<GeoColor,GeoColor> ColorMappings
{ get; }
public class LegendItem {
public
Single Ratio { get;
set; }
public class LineStyle : Style
public
override Boolean
IsDefault { get; }
public static class LineStyles
WorldStreetsLineStyles as it has updated and better looking styles.")]
WorldMapKitLineStyles as it has updated and better looking styles.")]
public static LineStyle Canal1 { get;
[ObsoleteAttribute("We suggest you use the new static class WorldMapKitLineStyles
public static LineStyle ContestedBorder1
{ get; }
public static LineStyle ContestedBorder2 { get; }
public static LineStyle DegreeLine1
{ get; }
public static LineStyle Equator1
{ get; }
public static LineStyle Highway1
{ get; }
public static LineStyle Highway2
{ get; }
public static LineStyle Highway3
{ get; }
public static LineStyle Highway4
{ get; }
public static LineStyle Highway5 { get;
public static LineStyle InternationalBorder1
{ get; }
public static LineStyle InternationalBorder2
{ get; }
public static LineStyle Interstate1
{ get; }
public static LineStyle Interstate2
{ get; }
public static LineStyle Interstate3
{ get; }
public static LineStyle Interstate4
{ get; }
public static LineStyle LocalRoad1
{ get; }
public static LineStyle LocalRoad2 { get; }
public static LineStyle LocalRoad3
{ get; }
public static LineStyle LocalRoad4
{ get; }
public static LineStyle MajorRoad1
{ get; }
public static LineStyle MajorRoad2
{ get; }
public static LineStyle MajorRoad3
{ get; }
public static LineStyle MajorRoad4
{ get; }
public static LineStyle MajorStreet1
{ get; }
public static LineStyle MajorStreet2
{ get; }
public static LineStyle MajorStreet3
{ get; }
public static LineStyle Pipeline1
{ get; }
public static LineStyle Pipeline2
{ get; }
public static LineStyle Pipeline3
{ get; }
public static LineStyle Railway1 { get;
public static LineStyle Railway2
{ get; }
public static LineStyle Railway3
{ get; }
public static LineStyle Railway4
{ get; }
public static LineStyle River1
{ get; }
public static LineStyle River2
{ get; }
public static LineStyle RiverIntermittent1 { get; }
public static LineStyle SecondaryRoad1
{ get; }
public static LineStyle SecondaryRoad2
{ get; }
public static LineStyle StateBorder1
{ get; }
public static LineStyle Utility1
{ get; }
public static LineStyle Utility2
{ get; }
public static LineStyle Utility3
{ get; }
public class LoadingNativeImageGeoImageEventArgs : EventArgs {
public
LoadingNativeImageGeoImageEventArgs();
public
LoadingNativeImageGeoImageEventArgs(Object
nativeImage);
public
public class MagneticNorthLineStyle : LineStyle {
public
MagneticNorthLineStyle();
protected
override void
DrawCore(IEnumerable<Feature> features,
GeoCanvas canvas, Collection<SimpleCandidate> labelsInThisLayer,
public class MsSqlFeatureLayer : FeatureLayer {
public
MsSqlFeatureLayer();
public
MsSqlFeatureLayer(String connectionString,
String tableName, String featureIdColumn);
public
String tableName, String featureIdColumn, Int32 srid);
public
String tableName, String featureIdColumn, DatabaseConnectionMode databaseConnectionMode);
public
String tableName, String featureIdColumn, Int32 srid, DatabaseConnectionMode
public
String tableName, String featureIdColumn, Int32 srid, String
schemaName);
public
schemaName, DatabaseConnectionMode databaseConnectionMode);
public
override Boolean
public
DatabaseConnectionMode DatabaseConnectionMode
{ get; set; }
public
Int32 CommandTimeout { get; set; }
public
Int32 Srid { get;
set; }
public
String ConnectionString { get; set; }
public
String CustomGeometryColumnName { get; set; }
public
String FeatureIdColumn { get; set; }
public
String SchemaName { get; set; }
public
String SpatialIndexName { get; set; }
public
String TableName { get; set; }
public
String WhereClause { get; set; }
public
void BuildIndex(BuildIndexMode buildIndexMode);
public
Int32 ExecuteNonQuery(String sqlStatement);
public
WellKnownType GetFirstGeometryType();
public
void MakeAllGeometriesValid();
public
Dictionary<String,String> Validate();
public
static void CreateTable(String connectionString, String tableName, MsSqlSpatialDataType
spatialDataType);
public
spatialDataType, IEnumerable<FeatureSourceColumn>
columns);
public
columns, OverwriteMode overwriteMode);
public class MsSqlFeatureSource : FeatureSource {
public
MsSqlFeatureSource();
public
MsSqlFeatureSource(String connectionString,
public
public
public
public
schemaName);
public
public
override Boolean
IsEditable { get; }
public
{ get; set; }
public
public
Int32 Srid { get;
set; }
public
MsSqlSpatialDataType SpatialDataType { get; set; }
public
public
public
public
public
public
public
public
public
public
public
public
event EventHandler<ExecutingSqlStatementMsSqlFeatureSourceEventArgs>
ExecutingSqlStatement;
protected
override Boolean
CanExecuteSqlQueryCore { get; }
protected
override Boolean
CanGetCountQuicklyCore();
protected
override void
CloseCore();
protected
override TransactionResult
CommitTransactionCore(TransactionBuffer
transactions);
protected
override Int32
ExecuteNonQueryCore(String sqlStatement);
protected
protected
override Object
ExecuteScalarCore(String sqlStatement);
protected
protected
returningColumnNames, Int32 startIndex,
Int32 takeCount);
protected
protected
GetColumnsCore();
protected
override Int32
GetCountCore();
protected
GetFeaturesByColumnValueCore(String columnName,
String columnValue, IEnumerable<String> returningColumnNames);
protected
GetFeaturesByIdsCore(IEnumerable<String>
ids, IEnumerable<String> returningColumnNames);
protected
GetFeaturesInsideBoundingBoxCore(RectangleShape
boundingBox, IEnumerable<String> returningColumnNames);
protected
GetFeaturesOutsideBoundingBoxCore(RectangleShape
protected
virtual void OnExecutingSqlStatement(ExecutingSqlStatementMsSqlFeatureSourceEventArgs e);
protected
override void
OpenCore();
protected
SpatialQueryCore(BaseShape targetShape,
QueryType queryType, IEnumerable<String> returningColumnNames);
public
spatialDataType);
public
columns);
public
public enum MsSqlSpatialDataType {
Unknown,
Geometry,
Geography
public static class MsSqlValidatorHelper
public static void CheckSpatialDataTypeIsValid(MsSqlSpatialDataType spatialDataType, String parameterName);
public class MultipleShapeFileFeatureLayer : FeatureLayer {
public
Collection<String> GetIndexPathFilenames();
public
Collection<String> GetShapePathFilenames();
public Collection<String> GetIndexPathFileNames();
public Collection<String> GetShapePathFileNames();
public class MultipleShapeFileFeatureSource : FeatureSource {
public
public
public class NativeImageRasterLayer : RasterLayer {
public
NativeImageRasterLayer();
public
NativeImageRasterLayer(String imagePathFilename);
public
NativeImageRasterLayer(String imagePathFilename,
RectangleShape imageExtent);
public
String worldfilePathFilename);
public
override Boolean
public
InterpolationMode InterpolationMode { get; set; }
public
public
event EventHandler<StreamLoadingEventArgs>
StreamLoading;
protected
override void
public class NativeImageRasterSource : RasterSource {
public
NativeImageRasterSource();
public
NativeImageRasterSource(String imagePathFilename);
public
NativeImageRasterSource(String imagePathFilename,
public
public
Boolean IsGrayscale { get; set; }
public
Boolean IsNegative { get; set; }
public
String FileName { get; }
public
String FilePath { get; }
public
public
StreamLoading;
protected
override void
CloseCore();
protected
protected
override GeoImage
protected
override Int32
protected
override Int32
protected
virtual void OnStreamLoading(StreamLoadingEventArgs e);
protected
override void
OpenCore();
public static class NoaaRadarMonitor
public static GeoImage Bitmap GetRadarImage();
public class NoaaWeatherStationFeatureSource : FeatureSource {
public
NoaaWeatherStationFeatureSource();
public
event EventHandler<StationsUpdatedNoaaWeatherStationFeatureSourceEventArgs>
StationsUpdated;
public
event EventHandler<StationsUpdatingNoaaWeatherStationFeatureSourceEventArgs>
StationsUpdating;
protected
override void
CloseCore();
protected
protected
GetColumnsCore();
protected
override Int32
GetCountCore();
protected
protected override WellKnownType GetFirstFeaturesWellKnownTypeCore();
protected
virtual void OnStationsUpdated(StationsUpdatedNoaaWeatherStationFeatureSourceEventArgs
e);
protected
virtual void OnStationsUpdating(StationsUpdatingNoaaWeatherStationFeatureSourceEventArgs
e);
protected
override void
OpenCore();
public class OpenStreetMapLayer : Layer {
public
OpenStreetMapLayer(IWebProxy webProxy);
{ get; set; }
public OpenStreetMapLayer(WebProxy webProxy);
public class OracleFeatureSource : FeatureSource {
protected
public class PlatformGeoCanvas : GeoCanvas {
public
public
override Boolean
HasKeyColor { get; }
public
CompositingQuality CompositingQuality {
get; set; }
public
public
SmoothingMode SmoothingMode { get; set; }
public
TextRenderingHint TextRenderingHint { get; set; }
public
override Stream
GetStreamFromGeoImage(GeoImage image);
protected
override void
BeginDrawingCore(Object nativeImage,
RectangleShape worldExtent, GeographyUnit drawingMapUnit);
protected
override void
DrawAreaCore(IEnumerable<ScreenPointF[]>
screenPoints, GeoPen outlinePen,
GeoBrush fillBrush, DrawingLevel drawingLevel, Single xOffset, Single
yOffset, PenBrushDrawingOrder penBrushDrawingOrder);
protected
override void
DrawEllipseCore(ScreenPointF screenPoint,
height, GeoPen outlinePen, GeoBrush fillBrush, DrawingLevel
drawingLevel, Single xOffset, Single yOffset, PenBrushDrawingOrder
protected
override void
DrawLineCore(IEnumerable<ScreenPointF>
screenPoints, GeoPen linePen, DrawingLevel drawingLevel, Single xOffset, Single
yOffset);
protected
override void
DrawScreenImageCore(GeoImage image,
Single centerXInScreen, Single centerYInScreen, Single widthInScreen, Single heightInScreen, DrawingLevel
drawingLevel, Single xOffset, Single yOffset, Single
rotateAngle);
protected
override void
DrawScreenImageWithoutScalingCore(GeoImage
image, Single centerXInScreen, Single centerYInScreen, DrawingLevel drawingLevel, Single xOffset, Single
yOffset, Single rotateAngle);
protected
override void
DrawTextCore(String text, GeoFont font, GeoBrush
fillBrush, GeoPen haloPen, IEnumerable<ScreenPointF> textPathInScreen,
protected
override void
EndDrawingCore();
protected
override void
FlushCore();
protected
override Single
GetCanvasHeightCore(Object nativeImage);
protected
override Single
GetCanvasWidthCore(Object nativeImage);
protected
override DrawingRectangleF
MeasureTextCore(String text, GeoFont font);
protected override GeoImage ToGeoImageCore(Object nativeImage);
protected
override Object
ToNativeImageCore(GeoImage image);
public
static MemoryStream
ConvertGeoImageToMemoryStream(GeoImage image);
public
static MemoryStream
ConvertGeoImageToMemoryStream(GeoImage image,
GeoImageFormat imageFormat);
public
static void FillBackground(GeoImage image, GeoBrush
brush);
public class PointStyle : PointBaseStyle
public
override Boolean
IsDefault { get; }
public static class PointStyles
WorldStreetsPointStyles as it has updated and better looking styles.")]
WorldMapKitPointStyles as it has updated and better looking styles.")]
public static PointStyle Capital1
{ get; }
public static PointStyle Capital2 { get; }
[ObsoleteAttribute("We suggest you use the new static class WorldMapKitPointStyles
public static PointStyle Capital3
{ get; }
public static PointStyle City1
{ get; }
public static PointStyle City2
{ get; }
public static PointStyle City3
{ get; }
public static PointStyle City4
{ get; }
public static PointStyle City5
{ get; }
public static PointStyle City6 { get;
public static PointStyle City7
{ get; }
public abstract class PositionStyle
: Style {
public
override Boolean
IsDefault { get; }
protected
void DrawMask(LabelingCandidate
labelingCandidate, GeoCanvas canvas,
public static class PrinterHelper
public
PrinterHelper();
public enum PrinterTextHorizontalAlignment {
Left,
Center,
Right
public class Proj4Projection : Projection, IDisposable
protected
override Boolean
CanReproject { get; }
public void Dispose();
protected
public Proj4MemoryMode MemoryMode { get; set; }
public class QueryTools {
public enum RangeCheckingInclusion {
IncludeValue,
ExcludeValue
public abstract class RasterLayer
: Layer {
public
Double ScaleFactor { get; set; }
public abstract class RasterSource
public
public static class RestrictionValidatorHelper
public static void CheckRestrictionModeIsValid(RestrictionMode restrictionMode, String parameterName);
public static void CheckRestrictionStyleIsNotConflicted(RestrictionStyle restrictionStyle, IEnumerable<Style> customStyles);
public static void CheckRestrictionStyleIsValid(RestrictionStyle restrictionStyle, String parameterName);
public class RingShape : AreaBaseShape
public
Boolean IsCounterClockwise();
public class RtreeSpatialIndex : SpatialIndex, IDisposable
public RtreeSpatialIndex(String pathFilename pathFileName);
public
RtreeSpatialIndex(String pathFilename,
public
Boolean HasIdx { get; }
public GeoFileReadWriteMode RtreeSpatialIndexReadWriteMode
public
public
void DeleteRecord(BaseShape shape);
public
RectangleShape GetBoundingBox();
public
Collection<String> GetFeatureIdsIntersectingBoundingBox(RectangleShape rectangleShape, Double screenWidth, Double
screenHeight, Int32 simplifyPixelBufferSize,
Collection<RectangleShape> dimensionlessBoxes);
public
void RefreshCache();
public static void CreatePointSpatialIndex(String pathFilename pathFileName);
public static void CreatePointSpatialIndex(String pathFilename pathFileName, RtreeSpatialIndexPageSize pageSize);
public static void CreatePointSpatialIndex(String pathFilename pathFileName, RtreeSpatialIndexPageSize pageSize, RtreeSpatialIndexDataFormat dataFormat);
public static void CreateRectangleSpatialIndex(String pathFilename pathFileName);
public static void CreateRectangleSpatialIndex(String pathFilename pathFileName, RtreeSpatialIndexPageSize pageSize);
public static void CreateRectangleSpatialIndex(String pathFilename pathFileName, RtreeSpatialIndexPageSize pageSize, RtreeSpatialIndexDataFormat dataFormat);
public RtreeSpatialIndex(String pathFileName, RtreeSpatialIndexReadWriteMode
readWriteMode);
set; }
public struct ScreenPoint {
public
ScreenPoint(Int32 x, Int32 y);
public
Int32 X { get;
public
Int32 Y { get;
public
override Boolean
Equals(Object obj);
public
override Int32
GetHashCode();
public
override String
ToString();
public
static Boolean
operator==(ScreenPoint screenPoint1,
ScreenPoint screenPoint2);
public
static Boolean
operator!=(ScreenPoint screenPoint1,
public class ShapeFileFeatureLayer : FeatureLayer {
public
ShapeFileFeatureLayer(String shapePathFilename,
public
String indexPathFilename, GeoFileReadWriteMode readWriteMode);
public
String indexPathFilename, GeoFileReadWriteMode readWriteMode, Encoding encoding);
public GeoFileReadWriteMode ShapeFileReadWriteMode
public
String IndexPathFilename { get; set; }
public
String ShapePathFilename { get; set; }
public ShapeFileFeatureLayer(String shapePathFilename, ShapeFileReadWriteMode readWriteMode);
public ShapeFileFeatureLayer(String shapePathFilename, String indexPathFilename, ShapeFileReadWriteMode readWriteMode, Encoding encoding);
public ShapeFileFeatureLayer(String shapePathFilename, String indexPathFilename, ShapeFileReadWriteMode readWriteMode);
public override Boolean CanDrawProgressively
{ get; }
protected
override void DrawProgressivelyCore(GeoCanvas canvas, Collection<SimpleCandidate>
labelsInAllLayers);
public String IndexPathFileName { get; set; }
public String ShapePathFileName { get; set; }
public class ShapeFileFeatureSource : FeatureSource {
public
ShapeFileFeatureSource(String shapePathFilename,
public
public
public
public
protected
public ShapeFileFeatureSource(String shapePathFilename, ShapeFileReadWriteMode readWriteMode);
public ShapeFileFeatureSource(String shapePathFilename, String indexPathFilename, ShapeFileReadWriteMode readWriteMode, Encoding encoding);
public ShapeFileFeatureSource(String shapePathFilename, String indexPathFilename, ShapeFileReadWriteMode readWriteMode);
public IEnumerable<String> GetFeatureIdsForDrawingProgressively(RectangleShape boundingBox, Double screenWidth, Double
screenHeight, Projection projection,
Boolean isPoint);
protected
GetFeatureIdsForDrawingProgressivelyCore(RectangleShape
boundingBox, Double screenWidth, Double screenHeight, Projection
projection, Boolean isPoint);
public enum ShapeFileSortingMode {
Geohash
//removed
members:
GeoHash
public static class ShapefileValidatorHelper
public static void CheckDbfColumnsAreEmpty(IEnumerable<DbfColumn> dbfColumns, String parameterName);
public static void CheckShapeFileIsEditable(ShapeFileType shapeFileType, String parameterName);
public static void CheckShapeFileIsWriteable(GeoFileReadWriteMode readWriteMode, String parameterName);
public static void CheckShapeFileTypeIsSupported(ShapeFileType shapeFileType, String parameterName);
public static void CheckShapeFileTypeIsValid(ShapeFileType shapeFileType, String parameterName);
public static void CheckSqlStatementIsSupported(String sqlStatement);
public static class SqlTypesGeometryHelper
public
static Boolean
IsSqlTypesAvailable();
public static Boolean IsValid(BaseShape shape baseShape);
public static BaseShape MakeValid(BaseShape shape baseShape);
public static BaseShape Union(IEnumerable<BaseShape> shapes baseShapes);
public class StationsUpdatedNoaaWeatherStationMonitorEventArgs
: EventArgs {
public Dictionary<String,Feature> ConcurrentDictionary WeatherStations { get; }
public class StationsUpdatingNoaaWeatherStationFeatureSourceEventArgs
: EventArgs {
public
StationsUpdatingNoaaWeatherStationFeatureSourceEventArgs();
public
Boolean Cancel { get; set; }
public class StreamLoadingEventArgs : EventArgs {
public
StreamLoadingEventArgs(String alternateStreamName,
Stream alternateStream, GeoFileMode fileMode, GeoFileReadWriteMode readWriteMode);
public
String streamType, Stream alternateStream, GeoFileMode fileMode, GeoFileReadWriteMode readWriteMode);
public GeoFileMode FileMode FileMode
{ get; set; }
public
GeoFileReadWriteMode ReadWriteMode { get; set; }
public StreamLoadingEventArgs(String alternateStreamName, Stream alternateStream, FileMode fileMode, FileAccess
fileAccess);
public StreamLoadingEventArgs(String alternateStreamName, String streamType, Stream
public FileAccess FileAccess { get; set; }
public abstract class Style
public
virtual Boolean
IsDefault { get; }
public class TabFeatureLayer : FeatureLayer {
public TabFeatureLayer(String tabPathFilename tabPathFileName);
public
TabFeatureLayer(String tabPathFilename,
public GeoFileReadWriteMode TabFileReadWriteMode
public static void BuildIndexFile(String tabPathFilename tabPathFileName);
public static void BuildIndexFile(String tabPathFilename tabPathFileName,
public static void CreateTabFile(String tabPathFilename tabPathFileName,
IEnumerable<TabDbfColumn> databaseColumns,
IEnumerable<Feature> features, OverwriteMode overwriteMode);
IEnumerable<Feature> features, OverwriteMode overwriteMode, Encoding encoding);
public TabFeatureLayer(String tabPathFileName, TabFileReadWriteMode readWriteMode);
public class TabFeatureSource : FeatureSource {
public TabFeatureSource(String tabPathFilename tabPathFileName);
public
TabFeatureSource(String tabPathFilename,
public TabFeatureSource(String tabPathFileName, TabFileReadWriteMode readWriteMode);
public static class TextStyles
WorldStreetsTextStyles as it has updated and better looking styles.")]
WorldMapKitTextStyles as it has updated and better looking styles.")]
public static TextStyle Antarctical(String textColumnName);
[ObsoleteAttribute("We suggest you use the new static class WorldStreetsTextStyles
public static TextStyle Canal1(String textColumnName);
public static TextStyle Capital1(String textColumnName);
public static TextStyle Capital2(String textColumnName);
public static TextStyle Capital3(String textColumnName);
public static TextStyle City1(String textColumnName);
public static TextStyle City2(String textColumnName);
public static TextStyle City3(String textColumnName);
public static TextStyle City4(String textColumnName);
public static TextStyle City5(String textColumnName);
public static TextStyle City6(String
textColumnName);
public static TextStyle City7(String textColumnName);
public static TextStyle ContestedBorder1(String textColumnName);
public static TextStyle ContestedBorder2(String textColumnName);
public static TextStyle Country1(String textColumnName);
public static TextStyle Country2(String textColumnName);
public static TextStyle County1(String textColumnName);
public static TextStyle County2(String textColumnName);
public static TextStyle Crop1(String textColumnName);
public static TextStyle DegreeLine1(String textColumnName);
public static TextStyle Equator1(String textColumnName);
public static TextStyle Evergreen1(String textColumnName);
public static TextStyle Evergreen2(String textColumnName);
public static TextStyle Forest1(String textColumnName);
public static TextStyle Grass1(String textColumnName);
public static TextStyle Highway1(String textColumnName);
public static TextStyle Highway2(String textColumnName);
public static TextStyle Highway3(String
textColumnName);
public static TextStyle Highway4(String textColumnName);
public static TextStyle Highway5(String textColumnName);
public static TextStyle InternationalBorder1(String textColumnName);
public static TextStyle InternationalBorder2(String textColumnName);
public static TextStyle Interstate1(String textColumnName);
public static TextStyle Interstate2(String textColumnName);
public static TextStyle Interstate3(String textColumnName);
public static TextStyle Interstate4(String textColumnName);
public static TextStyle LocalRoad1(String textColumnName);
public static TextStyle LocalRoad2(String textColumnName);
public static TextStyle LocalRoad3(String textColumnName);
public static TextStyle LocalRoad4(String textColumnName);
public static TextStyle MajorRoad1(String
textColumnName);
public static TextStyle MajorRoad2(String textColumnName);
public static TextStyle MajorRoad3(String textColumnName);
public static TextStyle MajorRoad4(String textColumnName);
public static TextStyle MajorStreet1(String textColumnName);
public static TextStyle MajorStreet2(String textColumnName);
public static TextStyle MajorStreet3(String textColumnName);
public static TextStyle Military1(String
textColumnName);
public static TextStyle NoData1(String textColumnName);
public static TextStyle Park1(String textColumnName);
public static TextStyle Pipeline1(String
textColumnName);
public static TextStyle Pipeline2(String textColumnName);
public static TextStyle Pipeline3(String textColumnName);
public static TextStyle Railway1(String textColumnName);
public static TextStyle Railway2(String textColumnName);
public static TextStyle Railway3(String textColumnName);
public static TextStyle Railway4(String textColumnName);
public static TextStyle River1(String textColumnName);
public static TextStyle River2(String textColumnName);
public static TextStyle RiverIntermittent1(String textColumnName);
public static TextStyle Sand1(String textColumnName);
public static TextStyle SeaIce1(String textColumnName);
public static TextStyle SecondaryRoad1(String textColumnName);
public static TextStyle SecondaryRoad2(String textColumnName);
public static TextStyle SnowIce1(String
textColumnName);
public static TextStyle State1(String textColumnName);
public static TextStyle State2(String textColumnName);
public static TextStyle StateBorder1(String textColumnName);
public static TextStyle Swamp1(String textColumnName);
public static TextStyle Swamp2(String textColumnName);
public static TextStyle Tundra1(String textColumnName);
public static TextStyle Urban1(String textColumnName);
public static TextStyle Urban2(String textColumnName);
public static TextStyle Utility1(String textColumnName);
public static TextStyle Utility2(String textColumnName);
public static TextStyle Utility3(String textColumnName);
public static TextStyle Water1(String textColumnName);
public static TextStyle Water2(String textColumnName);
public static TextStyle WaterIntermittent1(String textColumnName);
public static TextStyle Wildlife1(String textColumnName);
public abstract class TileCache
public GeoImage Bitmap LoadingTileImage
{ get; }
{ get; }
public virtual String CacheId
{ get; set; }
public
void SaveTiles(GeoImage
image, RectangleShape imageExtent);
public
image, RectangleShape imageExtent,
Boolean saveContainedCellsOnly);
public void SaveTiles(Bitmap
bitmap, RectangleShape bitmapExtent);
bitmap, RectangleShape bitmapExtent,
public class TiledWmsLayer : Layer
public
TiledWmsLayer(IEnumerable<Uri> serverUris,
public
IWebProxy webProxy, String clientId, String
privateKey);
{ get; set; }
public TiledWmsLayer(IEnumerable<Uri> serverUris, WebProxy webProxy, String
public TiledWmsLayer(IEnumerable<Uri> serverUris, WebProxy webProxy);
public class TiledWmsRasterSource : RasterSource {
public
TiledWmsRasterSource(IEnumerable<Uri>
serverUris, IWebProxy webProxy);
public
serverUris, IWebProxy webProxy, String clientId, String
privateKey);
{ get; set; }
public TiledWmsRasterSource(IEnumerable<Uri> serverUris, WebProxy webProxy, String
public TiledWmsRasterSource(IEnumerable<Uri> serverUris, WebProxy webProxy);
public class TinyGeoFeatureLayer : FeatureLayer {
public TinyGeoFeatureLayer(String tinyGeoPathFilename tinyGeoPathFileName);
public TinyGeoFeatureLayer(String tinyGeoPathFilename tinyGeoPathFileName,
String password);
public
String TinyGeoPathFilename { get; set; }
public static void CreateTinyGeoFile(String tinyGeoPathFilename tinyGeoPathFileName,
String shapePathFilename shapePathFileName,
GeographyUnit unitOfData, IEnumerable<String> columnNames);
GeographyUnit unitOfData, ReturningColumnsType returningColumnType);
GeographyUnit unitOfData, ReturningColumnsType returningColumnType, Double precisionInMeter);
GeographyUnit unitOfData, ReturningColumnsType returningColumnType, String password);
GeographyUnit unitOfData, IEnumerable<String> columnNames, String password);
GeographyUnit unitOfData, IEnumerable<String> columnNames, Double precisionInMeter);
GeographyUnit unitOfData, ReturningColumnsType returningColumnType, String password, Double
precisionInMeter);
GeographyUnit unitOfData, IEnumerable<String> columnNames, String password, Double
precisionInMeter);
precisionInMeter, Encoding shapeEncoding);
public static void DecryptTinyGeoFile(String encryptedTinyGeoPathFilename encryptedTinyGeoPathFileName,
String decryptedTinyGeoPathFilename decryptedTinyGeoPathFileName,
String password);
public static void EncryptTinyGeoFile(String unencryptedTinyGeoPathFilename unencryptedTinyGeoPathFileName,
String password);
public static Double GetOptimalPrecision(String shapePathFilename shapePathFileName,
GeographyUnit unitOfData, DistanceUnit returningDistanceUnit, TinyGeoPrecisionMode precisionMode);
public String TinyGeoPathFileName { get; set; }
public class TinyGeoFeatureSource : FeatureSource {
public TinyGeoFeatureSource(String tinyGeoPathFilename tinyGeoPathFileName);
public TinyGeoFeatureSource(String tinyGeoPathFilename tinyGeoPathFileName,
String password);
public
precisionInMeter);
precisionInMeter);
String password);
String password);
public static class UnmanagedAssembliesHelper
public
static String
GetAssemblyPathFilename(String directoryName,
String assemblyName, PclPlatform platform);
public static String GetGeoRasterWrapperAssemblyName();
public static String GetMapSuiteGeoRasterAssemblyName();
public static String GetMapSuiteGeoTiffAssemblyName();
public static String GetMapSuiteProjectionAssemblyName();
GetPossibleDependencyFolders();
GetPossibleDependencyFoldersAboveASpecifiedVersion(Int32 versionNumber);
public static String GetProj4ExtensionAssemblyName();
public static String GetTiffWrapperAssemblyName();
public class UnmanagedGeoTiffRasterLayer
: GeoTiffRasterLayer {
public
UnmanagedGeoTiffRasterLayer();
public
UnmanagedGeoTiffRasterLayer(String imagePathFilename);
public
UnmanagedGeoTiffRasterLayer(String imagePathFilename,
public
public
override Boolean
public class UnmanagedGeoTiffRasterSource : RasterSource : GeoTiffRasterSource
set; }
public static class UnsafeHelper
public
static void CopyImage(GeoImage source, Bitmap
target, Rectangle targetRectangle);
public
static void CopyImage(GeoImage source, Graphics
target, Rectangle sourceRectangle,
Rectangle targetRectangle, CopyPixelOperation copyPixelOperation);
public static GeoImage Bitmap FastLoadImageFromFile(String pathFilename pathFileName);
public
static Int16 GetAsyncKeyState(Keys vKey);
public static void CopyImage(Bitmap source, Graphics
public static void CopyImage(Bitmap source, Bitmap
target, Rectangle r);
public static class ValidatorHelper
public static void CheckAreaUnitIsValid(AreaUnit areaUnit, String
parameterName);
public static void CheckAreIntegerStrings(IEnumerable<String> ids, String parameterName);
public static void CheckBufferCapTypeIsValid(BufferCapType bufferCapType, String parameterName);
public static void CheckBuildIndexModeIsValid(BuildIndexMode buildIndexMode, String parameterName);
public static void CheckCanModifyColumnStructure(Boolean canModifyColumnStructure);
public static void CheckCanParseStringToDouble(String value, String
parameterName);
public static void CheckCanvasHeightIsLargerThanZero(Double canvasHeight, String
parameterName);
public static void CheckCanvasWidthIsLargerThanZero(Double canvasWidth, String
parameterName);
public static void CheckColumnNameIsInFeature(String columnName, IEnumerable<Feature>
features);
public static void CheckConnectionStringIsNotNull(String connectionString);
public static void CheckCustomStyleDuplicates(AreaStyle defaultAreaStyle, LineStyle defaultLineStyle, PointStyle defaultPointStyle, TextStyle defaultTextStyle, Collection<Style> customStyles, Boolean isActive);
public static void CheckDateTimeIsInRange(DateTime inputDate, String
parameterName, DateTime minDate,
RangeCheckingInclusion includeMinValue,
DateTime maxDate, RangeCheckingInclusion includeMaxValue);
public static void CheckDbfColumnDecimalLengthIsValid(DbfColumnType columnType, Int32 decimalLength);
public static void CheckDistanceUnitIsValid(DistanceUnit distanceUnit, String parameterName);
public static void CheckDrawingLevelIsValid(DrawingLevel drawingLevel, String parameterName);
public static void CheckDrawingLineCapIsValid(DrawingLineCap drawingLineCap, String parameterName);
public static void CheckDrawingLineJoinIsValid(DrawingLineJoin drawingLineJoin, String parameterName);
public static void CheckExtentIsValid(RectangleShape extent, String parameterName);
public static void CheckFeatureColumnValueContainsColon(String value, String
parameterName);
public static void CheckFeatureIsValid(Feature feature);
public static void CheckFeatureIsValid(Feature feature, String
parameterName);
public static void CheckFeatureSourceCanExecuteSqlQuery(Boolean canExecuteSqlQuery);
public static void CheckFeatureSourceCollectionIsNotEmpty(Collection<FeatureSource> featureSources);
public static void CheckFeatureSourceIsEditable(Boolean isEditable);
public static void CheckFeatureSourceIsInTransaction(Boolean isInTransaction);
public static void CheckFeatureSourceIsNotInTransaction(Boolean isInTransaction);
public static void CheckFeatureSourceIsOpen(Boolean isOpen);
public static void CheckFileIsExist(String pathFilename);
public static void CheckFileIsNotExist(String pathFilename);
public static void CheckGeoCanvasIsInDrawing(Boolean isDrawing);
public static void CheckGeoDashCapIsValid(GeoDashCap geoDashCap, String parameterName);
public static void CheckGeographyUnitIsMeter(GeographyUnit geographyUnit, String parameterName);
public static void CheckGeographyUnitIsValid(GeographyUnit geographyUnit, String parameterName);
public static void CheckGeoImageIsValid(GeoImage image, String
parameterName, GeoCanvas canvas);
public static void CheckGroupLayerIsNotEmpty(GeoCollection<Layer> layers);
public static void CheckHtmlColorIsValid(String htmlColor, String
parameterName);
public static void CheckIconImageAndIconFilePathAreInvalid(String iconFilePath, GeoImage
iconImage);
public static void CheckIEnumerableIsNotNullNorEmpty(IEnumerable values, String
parameterName, String exceptionMessage);
public static void CheckImageFormatIsValid(String imageFormat, Collection<String>
outputFormats, String exceptionMessage);
public static void CheckImageFormatSupport(String imageFormat);
public static void CheckImageIsNotNullInPointStyle(GeoImage image);
public static void CheckInputValueIsInRange(Double inputValue, String
parameterName, Double minValue, Double maxValue);
parameterName, Double minValue, RangeCheckingInclusion includeMinValue, Double maxValue, RangeCheckingInclusion
includeMaxValue);
includeMaxValue, String exceptionMessage);
public static void CheckInputValueIsLargerThan(Double inputValue, String
parameterName, Double minValue, RangeCheckingInclusion includeMinValue);
public static void CheckInputValueIsLargerThanZero(Double value, String
parameterName);
public static void CheckInputValueIsLessThan(Double inputValue, String
parameterName, Double maxValue, RangeCheckingInclusion includeMaxValue);
public static void CheckInputValueIsNotNaNNorInfinity(Double value, String
parameterName);
public static void CheckInputValueIsValidDecimalDegree(Double value, String
parameterName);
public static void CheckItemInCollection(String item, Collection<String>
items, String exceptionMessage);
public static void CheckItemsInCollection(Collection<String> items, Collection<String> itemCollection, String exceptionMessage);
public static void CheckLatitudeIsInRange(Double latitude, String
parameterName);
public static void CheckLayerHasBoundingBox(Boolean hasBoundingBox);
public static void CheckLayerIsNotOpenedNorDrawing(Boolean isOpenOrDrawing);
public static void CheckLayerIsOpened(Boolean isOpen);
public static void CheckLineDashStyleIsValid(LineDashStyle lineDashStyle, String parameterName);
public static void CheckLongIsNotGreaterThanUInt32MaxValue(Int64 value);
public static void CheckLongitudeIsInRange(Double longitude, String
parameterName);
public static void CheckNumberIsByte(Int32 number, String
paramterName);
public static void CheckObjectIsNotNull(Object parameterObject, String parameterName);
public static void CheckObjectIsNotNull(Object parameterObject, String parameterName, String exceptionMessage);
public static void CheckObjectIsTargetType(Object objectToTest, Type
targetType, String operationName);
public static void CheckObjectsAreNotAllNull(Object firstObject, Object
secondObject, String firstParameterName,
String secondParameterName);
public static void CheckOverwriteModeIsValid(OverwriteMode overwriteMode, String parameterName);
public static void CheckPanDirectionIsValid(PanDirection panDirection, String parameterName);
public static void CheckPointSymbolTypeIsValid(PointSymbolType symbolType, String parameterName);
public static void CheckPointTypeIsValid(PointType pointType, String
parameterName);
public static void CheckProjectionIsOpen(Boolean isOpen);
public static void CheckProjectionParametersStringIsWGS84(String projectionParametersString, String parameterName);
public static void CheckQueryTypeIsValid(QueryType queryType, String
parameterName);
public static void CheckRandomColorTypeIsValid(RandomColorType colorType, String parameterName);
public static void CheckRasterLayerHasProjectionText(Boolean hasProjectionText);
public static void CheckRasterSourceHasProjectionText(Boolean hasProjectionText);
public static void CheckRasterSourceIsOpen(Boolean isOpen);
public static void CheckRebuildRecordIdModeIsValid(BuildRecordIdMode rebuildRecordIdMode, String parameterName);
public static void CheckReturningColumnsTypeIsValid(ReturningColumnsType returningColumnsType, String parameterName);
public static void CheckRingOrderIsValid(RingOrder ringOrder, String
parameterName);
public static void CheckRtreeSpatialIndexIsOpen(Boolean isOpen);
public static void CheckScaleIsLargerThanZero(Double imageScale, String
parameterName);
public static void CheckScaleIsValid(Double scale, String
parameterName);
public static void CheckShapeIsAreaBaseShape(BaseShape shape);
public static void CheckShapeIsLineBaseShape(BaseShape shape);
public static void CheckShapeIsMultipointShape(BaseShape shape);
public static void CheckShapeIsPointShape(BaseShape shape);
public static void CheckShapeIsValid(BaseShape shape, String
parameterName);
public static void CheckShapeIsValidForOperation(BaseShape shape);
public static void CheckShapeValidationModeIsValid(ShapeValidationMode shapeValidationMode, String parameterName);
public static void CheckSimplificationTypeIsValid(SimplificationType simplificationType, String parameterName);
public static void CheckSpatialIndexIsDeletable(Boolean isDeletable);
public static void CheckStartingPointIsValid(StartingPoint startingPoint, String parameterName);
public static void CheckStatus();
public static void CheckStreamIsWritable(Stream stream, String
parameterName);
public static void CheckStringIsNotNullNorEmpty(String value, String
parameterName);
public static void CheckStringIsNotNullNorEmptyForOperation(String value, String
exceptionMessage);
public static void CheckStringIsNotNullNorWhiteSpace(String value, String
parameterName);
public static void CheckStringIsValidDecimalDegree(String value, String
parameterName);
public static void CheckTypeIsSupport(Object instance, String
typeName);
public static void CheckUriIsValid(Uri uri);
public static void CheckWkbByteOrderIsValid(WkbByteOrder wkbByteOrder, String parameterName);
public static void CheckWkbIsValid(Byte[] wkb, String
parameterName);
public static void CheckWktIsValid(String wkt, String
parameterName);
public static void CheckZoomLevelSetIsValid(ZoomLevelSet zoomLevelSet, String parameterName);
[SerializableAttribute]
public class WarningsUpdatedNoaaWeatherWarningsMonitorEventArgs
: EventArgs {
public Dictionary<String,List<Dictionary<String,String>>>
ConcurrentDictionary WeatherWarnings { get; }
public class WfsFeatureLayer : FeatureLayer {
{ get; set; }
public
static String
GetCapabilities(Uri serverUri, IWebProxy webProxy);
public
GetLayers(Uri serverUri, IWebProxy webProxy);
public static String GetCapabilities(Uri serverUri, WebProxy
webProxy);
GetLayers(Uri serverUri, WebProxy webProxy);
public class WfsFeatureSource : FeatureSource {
{ get; set; }
public
static String
public
webProxy);
public class WkbFileFeatureLayer : FeatureLayer {
public
WkbFileFeatureLayer(String wkbPathFilename,
public GeoFileReadWriteMode WkbFileReadWriteMode
public WkbFileFeatureLayer(String wkbPathFilename, WkbFileReadWriteMode readWriteMode);
[ObsoleteAttribute("This method is obsolete and might be removed in or
after Version 10.0. Please call CreateWkbFile(string pathFilename, WkbFileType
wkbFileType, IEnumerable<FeatureSourceColumn> columns,
IEnumerable<Feature> features) instead.")]
public static void CreateWkbFile(String pathFilename, WkbFileType
columns);
public class WkbFileFeatureSource : FeatureSource {
public
WkbFileFeatureSource(String wkbPathFilename,
public WkbFileFeatureSource(String wkbPathFilename, WkbFileReadWriteMode readWriteMode);
columns);
public enum WkbShapeType {
Point,
LineString,
Polygon,
Multipoint,
Multiline,
Multipolygon,
GeometryCollection
public struct WmsLayerStyle {
public
String Abstract { set; }
public
String Name { get;
set; }
public
String Title { set;
public
WmsStyleLegend LengendUrl;
public
WmsOnlineResource StyleSheetUrl;
public struct WmsOnlineResource {
public
WmsOnlineResource(String onlineResource,
String type);
public
String OnlineResource { get; set; }
public
String Type { get;
set; }
public
override Boolean
Equals(Object obj);
public
override Int32
GetHashCode();
public class WmsRasterLayer : RasterLayer {
public
WmsRasterLayer(Uri uri, IWebProxy proxy);
{ get; set; }
public WmsRasterLayer(Uri uri, WebProxy
proxy);
public class WmsRasterSource : RasterSource {
public
WmsRasterSource(Uri uri, IWebProxy proxy);
{ get; set; }
public WmsRasterSource(Uri uri, WebProxy
proxy);
public class WmsServerLayer {
public
WmsServerLayer();
public
Boolean NoSubsets { get; set; }
public
Boolean Opaque { get; set; }
public
Boolean Queryable { get; set; }
public
Double MaxScale { get; set; }
public
Double MinScale { get; set; }
public
Int32 Cascaded { get; set; }
public
Int32 FixedHeight { get; set; }
public
Int32 FixedWidth { get; set; }
public
RectangleShape BoudingBox { get; set; }
public
String Abstract { get; set; }
public
String Name { get;
set; }
public
String Title { get;
set; }
public
String[] Crs { get;
set; }
public
String[] KeyWords { get; set; }
public
WmsLayerStyle[] Styles { get; set; }
public
WmsServerLayer[] ChildLayers { get; set; }
public struct WmsStyleLegend {
public
Int32 Height { set;
public
Int32 Width { set;
public
WmsOnlineResource OnLineResource;
public class WmtsLayer : Layer
public
WmtsLayer(IEnumerable<Uri> serverUris,
public
IWebProxy webProxy, WmtsSeverEncodingType wmtsSeverEncodingType);
{ get; set; }
public WmtsLayer(IEnumerable<Uri> serverUris, WebProxy webProxy);
public WmtsLayer(IEnumerable<Uri> serverUris, WebProxy webProxy, WmtsSeverEncodingType
[ObsoleteAttribute("This class is obsolete and might be removed in or
after Version 11.0. Please use WorldStreetsAreaStyles class instead.")]
public static class WorldMapKitAreaStyles
after Version 11.0. Please use WorldStreetAndImageryLayer class instead.")]
public class WorldMapKitLayer : Layer {
public
WorldMapKitLayer(WorldMapKitLayerType layerType,
privateKey);
{ get; set; }
public WorldMapKitLayer(WorldMapKitLayerType layerType, WebProxy webProxy, String
clientId, String privateKey);
public WebProxy Proxy { get;
set; }
[ObsoleteAttribute("This enum is obsolete and might be removed in or
public enum WorldMapKitLayerType {
after Version 11.0. Please use WorldStreetsLineStyles class instead.")]
public static class WorldMapKitLineStyles
[ObsoleteAttribute("This class is obsolete and might be removed in or after
Version 11.0. Please use WorldStreetAndImageryMapType class instead.")]
public enum WorldMapKitMapType {
after Version 11.0. Please use WorldStreetsPointStyles class instead.")]
public static class WorldMapKitPointStyles
after Version 11.0. Please use WorldStreetAndImageryProjection class
instead.")]
public enum WorldMapKitProjection {
after Version 11.0. Please use WorldStreetsTextStyles class instead.")]
public static class WorldMapKitTextStyles
after Version 11.0. Please use WorldStreetsAndImageryTileMode class
instead.")]
public enum WorldMapKitTileMode {
public enum WorldStreetsAndImageryMapType {
Road,
AerialWithLabels,
Aerial
public enum WorldStreetsAndImageryProjection {
Default,
DecimalDegrees,
SphericalMercator
public class WorldStreetsAndImageryRasterLayer : RasterLayer {
public
WorldStreetsAndImageryRasterLayer();
public
WorldStreetsAndImageryRasterLayer(String
public
WorldStreetsAndImageryRasterLayer(IWebProxy
webProxy, String clientId, String privateKey);
public
BitmapTileCache TileCache { get; set; }
public
override Boolean
public
Double LowerThreshold { get; set; }
public
Double UpperThreshold { get; set; }
public
Int32 TimeoutInSecond { get; set; }
public
IWebProxy WebProxy { get; set; }
public
String ClientId { get; set; }
public
String PrivateKey { get; set; }
public
WorldStreetsAndImageryMapType MapType {
get; set; }
public
WorldStreetsAndImageryProjection Projection
{ get; set; }
public
WorldStreetsAndImageryTileMode TileMode
{ get; set; }
public
void ClearCache();
public
Collection<String> GetRequestUrl(RectangleShape worldExtent, Int32 canvasWidth, Int32
canvasHeight);
public
Collection<String> GetServerCrss();
public
Collection<String> GetServerExceptionFormats();
public
Collection<String> GetServerLayerNames();
public
Collection<String> GetServerOutputFormats();
public
Collection<String> GetServerStyleNames();
public
String GetServiceVersion();
public
event EventHandler<SendingWebRequestEventArgs>
SendingWebRequest;
public
event EventHandler<SentWebRequestEventArgs>
SentWebRequest;
protected
override Boolean
IsOpenCore { get; }
protected
override void
CloseCore();
protected
override void
protected
override void
DrawExceptionCore(GeoCanvas canvas,
Exception e);
protected
void DrawImage(GeoCanvas
labelsInAllLayers);
protected
override ThreadSafetyLevel
GetThreadSafetyLevelCore();
protected
static Boolean
IsExtentWithinThreshold(RectangleShape currentExtent,
Double upperThreshold, Double lowerThreshold, Int32 canvasWidth, GeographyUnit
mapUnit);
protected
static Boolean
mapUnit, Single dpi);
protected
virtual void OnSendingWebRequest(SendingWebRequestEventArgs e);
protected
virtual void OnSentWebRequest(SentWebRequestEventArgs e);
protected
override void
OpenCore();
public class WorldStreetsAndImageryRasterSource : RasterSource {
public
WorldStreetsAndImageryRasterSource();
public
WorldStreetsAndImageryRasterSource(Uri uri,
IWebProxy proxy);
public
Collection<String> ActiveLayerNames
{ get; }
public
Collection<String> ActiveStyleNames
{ get; }
public
Dictionary<String,String> Parameters
{ get; }
public
public
IWebProxy Proxy { get; set; }
public
public
String Crs { get;
set; }
public
public
canvasHeight);
public
public
public
public
public
public
public
SendingWebRequest;
public
SentWebRequest;
protected
override RectangleShape
GetBoundingBoxCore();
protected
override GeoImage
protected
override Int32
protected
override Int32
protected
protected
protected
override void
OpenCore();
protected
WebResponse SendWebRequest(WebRequest webRequest);
protected
virtual WebResponse
SendWebRequestCore(WebRequest webRequest);
public enum WorldStreetsAndImageryTileMode {
MultiTile,
SingleTile
public static class WorldStreetsAreaStyles
public static AreaStyle Aerodrome();
public static AreaStyle Apron();
public static AreaStyle Attraction();
public static AreaStyle BaseLand();
public static AreaStyle Basin();
public static AreaStyle Beach();
public static Style Building();
public static Style BuildingShadow(Single width, Single
xOffsetInPixel, Single yOffsetInPixel);
public static AreaStyle Cemetery();
public static AreaStyle Commercial();
public static AreaStyle Common();
public static AreaStyle DogPark();
public static AreaStyle Farmland();
public static AreaStyle Forest();
public static AreaStyle Garden();
public static AreaStyle Golfcourse();
public static AreaStyle Grass();
public static AreaStyle Grassland();
public static AreaStyle Heath();
public static AreaStyle Helipad();
public static AreaStyle Industrial();
public static AreaStyle Landfill();
public static AreaStyle Marina();
public static AreaStyle Meadow();
public static AreaStyle Military();
public static AreaStyle Mud();
public static AreaStyle NationalPark();
public static AreaStyle NatureReserve();
public static AreaStyle Orchard();
public static AreaStyle Park();
public static AreaStyle Parking();
public static AreaStyle Pier();
public static AreaStyle Pitch();
public static AreaStyle Playground();
public static AreaStyle PowerStation();
public static AreaStyle ProtectedArea();
public static AreaStyle Quarry();
public static AreaStyle Railway();
public static AreaStyle RecreationGround();
public static AreaStyle Residential();
public static AreaStyle Retail();
public static AreaStyle Runway();
public static AreaStyle Sand();
public static AreaStyle School();
public static AreaStyle Scrub();
public static AreaStyle SportsCenter();
public static AreaStyle Stadium();
public static AreaStyle SwimmingPool();
public static AreaStyle Track();
public static AreaStyle VillageGreen();
public static AreaStyle Vineyards();
public static AreaStyle Water();
public static AreaStyle WaterPark();
public static AreaStyle Wetland();
public static AreaStyle Wood();
public static AreaStyle Zoo();
public static class WorldStreetsLineStyles
public static LineStyle Apron(Single outerWidth);
public static LineStyle Boundary(Single outerWidth);
public static LineStyle BoundaryCity(Single outerWidth);
public static LineStyle BoundaryCounty(Single outerWidth);
public static LineStyle BoundaryMinor(Single outerWidth);
public static LineStyle BoundaryNational(Single outerWidth);
public static LineStyle BoundaryState(Single outerWidth);
public static LineStyle Bridge(Single outerWidth);
public static LineStyle CableCar(Single outerWidth);
public static LineStyle Highway(Single outerWidth);
public static LineStyle MiniRail(Single outerWidth, Single
innerWidth, Single centerWidth);
public static LineStyle MinorRoadFill(Single width);
public static LineStyle MinorRoadOutline(Single width);
public static LineStyle Monorail(Single outerWidth, Single
public static LineStyle MotorwayFill(Single width);
public static LineStyle MotorwayLinkFill(Single width);
public static LineStyle MotorwayLinkOutline(Single width);
public static LineStyle MotorwayOutline(Single width);
public static LineStyle OneWay(String columnName, String
columnValue, String iconPath);
public static LineStyle Pier(Single outerWidth);
public static LineStyle PowerLine(Single outerWidth);
public static LineStyle PrimaryFill(Single width);
public static LineStyle PrimaryLinkFill(Single width);
public static LineStyle PrimaryLinkOutline(Single width);
public static LineStyle PrimaryOutline(Single width);
public static LineStyle Rail(Single outerWidth, Single
public static LineStyle RoadFill(Single width);
public static LineStyle RoadOutline(Single width);
public static LineStyle Runway(Single outerWidth);
public static LineStyle StepsFill(Single width);
public static LineStyle StepsOutline(Single width);
public static LineStyle Subway(Single outerWidth, Single
public static LineStyle Taxiway(Single outerWidth);
public static LineStyle TrunkFill(Single width);
public static LineStyle TrunkLinkFill(Single width);
public static LineStyle TrunkLinkOutline(Single width);
public static LineStyle TrunkOutline(Single width);
public static LineStyle Tunnel(Single width);
public static LineStyle Water(Single outerWidth);
public static class WorldStreetsPointStyles
public static PointStyle AerowayAerodrome(String iconPath);
public static PointStyle AerowayGate(String iconPath);
public static PointStyle AerowayHelipad(String iconPath);
public static PointStyle AerowayTerminal(String iconPath);
public static PointStyle AmenityBar(String iconPath);
public static PointStyle AmenityBench(String iconPath);
public static PointStyle AmenityBicycleParking(String iconPath);
public static PointStyle AmenityBicycleRental(String iconPath);
public static PointStyle AmenityBiergarten(String iconPath);
public static PointStyle AmenityBusStation(String iconPath);
public static PointStyle AmenityCafe(String iconPath);
public static PointStyle AmenityCarRental(String iconPath);
public static PointStyle AmenityCasino(String iconPath);
public static PointStyle AmenityCinema(String iconPath);
public static PointStyle AmenityClock(String iconPath);
public static PointStyle AmenityCollege(String iconPath);
public static PointStyle AmenityCourtHouse(String iconPath);
public static PointStyle AmenityDentist(String iconPath);
public static PointStyle AmenityDoctors(String iconPath);
public static PointStyle AmenityDrinkingWater(String iconPath);
public static PointStyle AmenityEmbassy(String iconPath);
public static PointStyle AmenityFastFood(String iconPath);
public static PointStyle AmenityFastFoodPizza(String iconPath);
public static PointStyle AmenityFireStation(String iconPath);
public static PointStyle AmenityFountain(String iconPath);
public static PointStyle AmenityFuel(String iconPath);
public static PointStyle AmenityFuelLpg(String iconPath);
public static PointStyle AmenityHospital(String iconPath);
public static PointStyle AmenityHospitalEmergency(String iconPath);
public static PointStyle AmenityIceCream(String iconPath);
public static PointStyle AmenityLibrary(String iconPath);
public static PointStyle AmenityNursingHome(String iconPath);
public static PointStyle AmenityParking(String iconPath);
public static PointStyle AmenityParkingCarPaid(String iconPath);
public static PointStyle AmenityParkingDisabled(String iconPath);
public static PointStyle AmenityParkingPrivate(String iconPath);
public static PointStyle AmenityPharmacy(String iconPath);
public static PointStyle AmenityPharmacyDispencing(String iconPath);
public static PointStyle AmenityPlaceOfWorship(String iconPath);
public static PointStyle AmenityPlaceOfWorshipBuddhist(String iconPath);
public static PointStyle AmenityPlaceOfWorshipChristian(String iconPath);
public static PointStyle AmenityPlaceOfWorshipHindu(String iconPath);
public static PointStyle AmenityPlaceOfWorshipIslamic(String iconPath);
public static PointStyle AmenityPlaceOfWorshipJain(String iconPath);
public static PointStyle AmenityPlaceOfWorshipJewish(String iconPath);
public static PointStyle AmenityPlaceOfWorshipShinto(String iconPath);
public static PointStyle AmenityPlaceOfWorshipSikh(String iconPath);
public static PointStyle AmenityPolice(String iconPath);
public static PointStyle AmenityPostBox(String iconPath);
public static PointStyle AmenityPostOffice(String iconPath);
public static PointStyle AmenityPrison(String iconPath);
public static PointStyle AmenityPub(String iconPath);
public static PointStyle AmenityRecycling(String iconPath);
public static PointStyle AmenityRestaurant(String iconPath);
public static PointStyle AmenitySchool(String iconPath);
public static PointStyle AmenityShelter(String iconPath);
public static PointStyle AmenityTaxi(String iconPath);
public static PointStyle AmenityTelephone(String iconPath);
public static PointStyle AmenityTheatre(String iconPath);
public static PointStyle AmenityToilets(String iconPath);
public static PointStyle AmenityToiletsDisabilityAccess(String iconPath);
public static PointStyle AmenityToiletsGenderAccessMen(String iconPath);
public static PointStyle AmenityToiletsGenderAccessWomen(String iconPath);
public static PointStyle AmenityTownHall(String iconPath);
public static PointStyle AmenityUniversity(String iconPath);
public static PointStyle AmenityVendingMachine(String iconPath);
public static PointStyle AmenityVeterinary(String iconPath);
public static PointStyle AmenityWasteDisposal(String iconPath);
public static PointStyle BarrierBlock(String iconPath);
public static PointStyle BarrierBollard(String iconPath);
public static PointStyle BarrierCattleGrid(String iconPath);
public static PointStyle BarrierCycleBarrier(String iconPath);
public static PointStyle BarrierEntrance(String iconPath);
public static PointStyle BarrierGate(String iconPath);
public static PointStyle BarrierKissingGate(String iconPath);
public static PointStyle BarrierLiftGate(String iconPath);
public static PointStyle BarrierStile(String iconPath);
public static PointStyle BarrierTollbooth(String iconPath);
public static PointStyle Ford(String iconPath);
public static PointStyle HighwayBusStop(String iconPath);
public static PointStyle HighwayMiniRoundaboutAnticlockwise(String iconPath);
public static PointStyle HighwayMiniRoundaboutClockwise(String iconPath);
public static PointStyle HighwayTrafficSignals(String iconPath);
public static PointStyle HistoricBattlefield(String iconPath);
public static PointStyle HistoricCastle(String iconPath);
public static PointStyle HistoricMemorial(String iconPath);
public static PointStyle HistoricMonument(String iconPath);
public static PointStyle HistoricRuins(String iconPath);
public static PointStyle HistoricWayside_Shrine(String iconPath);
public static PointStyle HistoricWaysideCross(String iconPath);
public static PointStyle HistoricWreck(String iconPath);
public static PointStyle LeisureMarina(String iconPath);
public static PointStyle LeisureSlipway(String iconPath);
public static PointStyle LeisureStadium(String iconPath);
public static PointStyle ManMadeCrane(String iconPath);
public static PointStyle ManMadeLighthouse(String iconPath);
public static PointStyle ManMadeMineshaft(String iconPath);
public static PointStyle ManMadeMineshaftAbandoned(String iconPath);
public static PointStyle ManMadeWaterTower(String iconPath);
public static PointStyle ManMadeWindmill(String iconPath);
public static PointStyle MilitaryBunker(String iconPath);
public static PointStyle NaturalCave(String iconPath);
public static PointStyle NaturalPeak(String iconPath);
public static PointStyle NaturalWoodConiferous(String iconPath);
public static PointStyle NaturalWoodDeciduous(String iconPath);
public static PointStyle NaturalWoodMixed(String iconPath);
public static PointStyle OfficeEstateAgent(String iconPath);
public static PointStyle PowerPlantCoal(String iconPath);
public static PointStyle PowerPlantGas(String iconPath);
public static PointStyle PowerPlantHydro(String iconPath);
public static PointStyle PowerPlantSolar(String iconPath);
public static PointStyle PowerPlantWind(String iconPath);
public static PointStyle PowerPole();
public static PointStyle PowerSubStation(String iconPath);
public static PointStyle PowerTower(String iconPath);
public static PointStyle RailwaySubway(String iconPath);
public static PointStyle RailwayTramStop(String iconPath);
public static PointStyle ShopAlcohol(String iconPath);
public static PointStyle ShopBakery(String iconPath);
public static PointStyle ShopBicycle(String iconPath);
public static PointStyle ShopBooks(String iconPath);
public static PointStyle ShopButcher(String iconPath);
public static PointStyle ShopCar(String iconPath);
public static PointStyle ShopCarRepair(String iconPath);
public static PointStyle ShopClothes(String iconPath);
public static PointStyle ShopComputer(String iconPath);
public static PointStyle ShopConfectionery(String iconPath);
public static PointStyle ShopConvenience(String iconPath);
public static PointStyle ShopCopyshop(String iconPath);
public static PointStyle ShopDepartmentStore(String iconPath);
public static PointStyle ShopDoItYourself(String iconPath);
public static PointStyle ShopFlorist(String iconPath);
public static PointStyle ShopGardenCentre(String iconPath);
public static PointStyle ShopGift(String iconPath);
public static PointStyle ShopGreengrocer(String iconPath);
public static PointStyle ShopHairdresser(String iconPath);
public static PointStyle ShopHearingAids(String iconPath);
public static PointStyle ShopHifi(String iconPath);
public static PointStyle ShopJewelry(String iconPath);
public static PointStyle ShopKiosk(String iconPath);
public static PointStyle ShopLaundry(String iconPath);
public static PointStyle ShopMobliePhone(String iconPath);
public static PointStyle ShopMotorcycle(String iconPath);
public static PointStyle ShopMusicalInstrument(String iconPath);
public static PointStyle ShopNewsagent(String iconPath);
public static PointStyle ShopOptician(String iconPath);
public static PointStyle ShopPet(String iconPath);
public static PointStyle ShopSupermarket(String iconPath);
public static PointStyle ShopTobacco(String iconPath);
public static PointStyle ShopToys(String iconPath);
public static PointStyle ShopVideo(String iconPath);
public static PointStyle SportArchery(String iconPath);
public static PointStyle SportBaseball(String iconPath);
public static PointStyle SportCanoe(String iconPath);
public static PointStyle SportClimbing(String iconPath);
public static PointStyle SportCricket(String iconPath);
public static PointStyle SportDiving(String iconPath);
public static PointStyle SportGolf(String iconPath);
public static PointStyle SportGymnastics(String iconPath);
public static PointStyle SportHorseRacing(String iconPath);
public static PointStyle SportIceStock(String iconPath);
public static PointStyle SportMotor(String iconPath);
public static PointStyle SportShooting(String iconPath);
public static PointStyle SportSkiing(String iconPath);
public static PointStyle SportSoccer(String iconPath);
public static PointStyle SportSwimming(String iconPath);
public static PointStyle SportSwimmingCovered(String iconPath);
public static PointStyle SportTennis(String iconPath);
public static PointStyle TourismAlpineHut(String iconPath);
public static PointStyle TourismArtwork(String iconPath);
public static PointStyle TourismAttraction(String iconPath);
public static PointStyle TourismCampSite(String iconPath);
public static PointStyle TourismCaravanSite(String iconPath);
public static PointStyle TourismChalet(String iconPath);
public static PointStyle TourismHostel(String iconPath);
public static PointStyle TourismHotel(String iconPath);
public static PointStyle TourismInformation(String iconPath);
public static PointStyle TourismInformationGuidepost(String iconPath);
public static PointStyle TourismInformationMap(String iconPath);
public static PointStyle TourismMotel(String iconPath);
public static PointStyle TourismMuseum(String iconPath);
public static PointStyle TourismPicnicStie(String iconPath);
public static PointStyle TourismThemePark(String iconPath);
public static PointStyle TourismViewpoint(String iconPath);
public static PointStyle TourismZoo(String iconPath);
public static PointStyle WaterwayWeir(String iconPath);
public static class WorldStreetsTextStyles
public static TextStyle GeneralPurpose(String labelColumnName, Single fontSize);
public static TextStyle MotorwayRoadSheild(String nameColumnName, Single fontSize);
public static TextStyle Poi(String labelColumnName, Single fontSize, Int32
yOffsetInPixel);
public static TextStyle PrimaryRoadSheild(String nameColumnName, Single fontSize);
public static TextStyle TrunkRoadSheild(String nameColumnName, Single fontSize);
public static TextStyle Water(String nameColumnName, Single fontSize);
public enum WrappingWorldDirection {
West,
East
public class AppliedFiltersFeatureSourceEventArgs; //removed
public class ApplyingFiltersFeatureSourceEventArgs; //removed
public class BoundarySolutionsParcelFeatureLayer; //removed
public class BoundarySolutionsParcelFeatureSource; //removed
public class CloudFileFeatureLayer; //removed
public class CloudFileFeatureSource; //removed
public sealed enum CloudFileShapeType;
//removed
public class DbfLinkRecords; //removed
public class DbfLinkSource; //removed
public sealed enum DbfReadWriteMode;
//removed
public class ExecutingSqlStatementMsSql2008FeatureSourceEventArgs;
//removed
public class GdiPlusGeoCanvas; //removed
public class GdiPlusRasterLayer; //removed
public class GdiPlusRasterSource;
//removed
public sealed enum GeoTiffLibraryType;
//removed
public static class Geohash;
//removed
public class GraticuleAdornmentLayer; //removed
public class InMemoryBitmapTileCache; //removed
public sealed enum KmlFileReadWriteMode;
//removed
public class LayerDefinition; //removed
public class LinkRecord; //removed
public abstract class LinkRecords;
//removed
public class LinkSource; //removed
public class ManagedGeoTiffRasterSource; //removed
public class ManagedProj4Projection; //removed
public class MapEngine; //removed
public class MsSql2008FeatureLayer; //removed
public class MsSql2008FeatureSource; //removed
public sealed enum Proj4MemoryMode;
//removed
public sealed enum RtreeSpatialIndexReadWriteMode;
//removed
public class S57FeatureLayer; //removed
public class S57FeatureSource; //removed
public sealed enum ShapeFileReadWriteMode;
//removed
public sealed enum SpatialDataType;
//removed
public class StyleDefinition; //removed
public sealed enum TabFileReadWriteMode;
//removed
public sealed enum TextHorizontalAlignment;
//removed
public class UpdatingStatusCloudFileFeatureSourceEventArgs;
//removed
public sealed enum WkbFileReadWriteMode;
//removed
} //end of namespace ThinkGeo.MapSuite.Core
