map_suite_main_page
Welcome to the ThinkGeo Wiki
The ThinkGeo Wiki is the central and official source of documentation, sample code and learning material for Map Suite users. It contains resources such as API reference, QuickStart Guides to get you started, sample projects with source code you can learn from, change logs for each version, and more.
If you are using Map Suite 9.0 or previous versions of Map Suite product, please go to MapSuite 9.0 Wiki. The current page is for Map Suite 10.0 and future versions. It has different assemblies, licensing strategy and ways of distribution, and more. although the majority of previous built code should work without modification assuming the new namespaces are added. For guidance on upgrading your existing code to Map Suite 10, please check out MapSuite 10 Upgrade Guide.
Products & Services
The wiki's resources are categorized by product. So you can easily find the information you need for the Map Suite products you're working with. The products run on one or more platforms; the key features, which are shared by different products, runs on different platforms as well. Please check platform coverage for the details.
For Mobile Platforms
For Desktop Platforms
Build Windows client apps using WPF
Build Windows client apps using Windows Forms, running on Windows and Linux/Mac(through Mono).
For Web Platforms
Build REST based web services for JS/HTML5 Web applications. Running on Windows and Linux/Mac(through Mono).
Build traditional ASP.NET Web Forms mapping applications, running on Windows and Linux/Mac(through Mono).
For Servers
Cloud server which can be accessed from any REST capable client.
Adds turn-by-turn routing and directions
Convert addresses to coordinates and vice-versa
map_suite_main_page.1489566871.txt.gz · Last modified: 2017/03/15 08:34 by marklee
