This guide shows how to manage Map Suite projects and issues in Jira. ThinkGeo Jira also has Curtus View projects on it, and this guide only cares about Map Suite Projects and issues.
This section introduces how the Map Suite projects are organized.
After signing in ThinkGeo JIRA, goto Projects/View all projects and you will see all the projects and categories.
Project types:
Categories:
We don't create a new project every often. When a new project launches, One of us including (Howard, Johnny or Mark) will create one for your need. So please don't touch the Create new project button unless one of us asks you to do it for now.
Everyone in ThinkGeo need to create a new task depending on the project you belongs to. We have different auth to manage the tasks. Generally works as following. (We could add more items in this section later)
Let's take a bug report from forum for example. In the morning, reviews the forum and notices a bug in Android Edition report from customer. If it is worth to fix, we want to record this bug in our Jira system, so that we could find it back for the next release log. So the first thing is to navigate to a corresponding project.
Now that, we could see a board of Android projects. It contains 6 columns which apply the same project template like the other projects.
A JIRA workflow is the set of statuses and transitions that an issue goes through during its life cycle. The resources in this section will help you extend workflows in JIRA. For example, you could create custom elements (functions, validators, etc) that can be added to workflows.
Below is our currect workflow:
Backlog is where the initial task should be. We could put any idea in this column. It is like a bucket, you can throw anything you think it is worth to do.
TODO is a filtered tasks we decide to work with. Your team leader decides what tasks should be in this column.
In Progress holds all the tasks that are in progress. Technically, one guy must have only one task in this column. You cannot work on two issues at the same time right? If yes, please re-consider if the task is created proper.
Once your task is complete from In Progress column, it is not mean this task is done. In another word, you need to ask your leader or the task assigner to review and verify if this is what he wants. In this step, your task will have two directions to go.
Let's continue. Click the Create button on the navigation bar to create an issue. There are some options to be aware of.
Then click Create button and the task is created.
Before a sprint starts, you need to enter the Original Estimates of your issues. And as you work on the issues during the sprint, you need to adjust the Remaining Estimates as necessary.
Once you have started to work on a specific issue, you need to log your work by following these steps:
As we are going to use JIRA for all the issues, we must follow this workflow when using JIRA.
