map_suite_ios_edition_samples_layers
Map Suite iOS Edition Samples Layers
Explore all the different types of layers and data formats you can use to build up your map.
ENC Viewer for displaying S-57 (*.000) File
GPS EXchange Format FeatureLayer
Maritime S57 FeatureLayer
Build Custom Shapefile Indexes
CAD FeatureLayer
TAB FeatureLayer With Embed Style
Compass
File Geodatabase
Video Overview
Hook Up External Data to Shapefile
Isolines
Isolines with Kriging
MapShapes
Notes from the developer:
Mini Map Adornment Layer
Multi Geo Raster Layer
Multi Index
North Arrow
Rotating the map:
Displaying the North Arrow:
Oledb Point FeatureSource
Oledb FeatureSource
Scale Bar
SQLInMemoryLayer
Styles with InMemoryFeatureLayer
Swine Flu
On the web site
Watermark Adornment Layer
WMTS Layer
Zedgraph
LEAD Technologies Inc. V1.01
map_suite_ios_edition_samples_layers.1442541114.txt.gz · Last modified: 2015/09/18 01:51 by admin
