map_suite_ios_edition_quick_start_guide
Map Suite iOS Edition Quick Start Guide
The Map Suite iOS Edition illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports iOS Edition 9.0.0.0 and higher, and will show you how to create an iOS application using Map Suite iOS Edition.
If you want to build an Android application using the standard Map Suite Android Edition product, please see the Android QuickStart Guide instead.
Before we get started, make sure you've installed the ThinkGeo Product Center and that you've either started an evaluation or activated a full license of Map Suite iOS Edition. By default, this will install the Map Suite iOS Edition 9.0 assemblies to C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite iOS.
Download the Sample
Setting up the Environment
Please following our iOS Edition Installation Guide for Xamarin iOS development environment.
Let's start by creating a new iOS Universal project in Microsoft Visual Studio (2012 or newer) named HelloWorld (see Figure 1). We can create the project with .NET Framework 4.5 or higher.
QSG_iOS_Img01.png|Figure 1. Creating a new project in the Visual Studio IDE.
The project HelloWorld is created in a new solution called HelloWorld. The wizard creates a single iOS Application.
Next we need to prepare our map data. Create an AppData folder and put the map data under it. Make sure the resources’ build action is Content (see Figure 2).
QSG_iOS_PrepareData.jpg|Figure 2. Add resources and set build action to Content.
Build Host Settings
In Windows for Visual Studio 2012 or newer, Go to Tools > Options in Visual Studio and open the Xamarin > iOS Settings panel to access the iOS Mac Build Host settings:
 Figure 3. Accessing the iOS Mac Build Host settings.
You can change the Mac Build Host by clicking the Find Mac Build Host button. The following screen is displayed to update the Mac Build Host:
 Figure 4. Updating the Mac Build Host.
Note: The version of Xamarin.iOS being used with VisualStudio must be the same as on the Mac. The simplest method to keep them in sync is to have both machines running on the same branch (e.g. both on the Stable release branch).
Enter the PIN number generated from Mac Xamarin.iOS
Active iPhoneSimulator platform in Configuration Manager:
In Mac, we need to open Xamarin.Host to pair.
Our App can run on the Simulator we selected:
Adding the Map View to our Controller
We need to add ProtableCore.dll and iOSEdition.dll to the reference. Right-click the Reference in Solution Explorer and select “Add Reference”, navigate to the <kbd>C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite iOS\Current Version\Managed Assemblies</kbd> folder and select “MapSuitePortableCore.dll” and “iOSEdition.dll”.
Note: Although it is not a ThinkGeo assembly, we also need to add “System.Windows.dll ” to the references. System.Windows can be found on the .NET tab of the Add Reference dialog. If we don't do this, we'll get the following error when we compile the project: “The type 'System.Collections.Specialized.INotifyCollectionChanged' is defined in an assembly that is not referenced. We must add a reference to assembly 'System.Windows, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes'.”
QSG_iOS_AddSystemWindows.png|Figure 3. Add System.Windows Reference.
The next step is to create Map view in HelloWorldViewController ViewDidLoad override method, and define it as “mapView”.
Every Content View Hierarchy has a corresponding View Controller to power user interaction. The role of the View Controller is to manage the Views in the Content View Hierarchy. The View Controller is not part of the Content View Hierarchy, and it's not an element in the interface. Rather, it provides the code that powers the user's interactions with the objects on the screen.
<source lang=“csharp”> public override void ViewDidLoad() {
   base.ViewDidLoad();
   MapView mapView = new MapView(View.Frame);
   View.AddSubview(mapView);
} </source>
Now we have our “iOSEdition.dll” and “MapSuitePortableCore.dll” referenced and a MapView added.
Map Suite iOS "Hello World" Sample
Map Suite Android "Hello World"
The first step in creating our “Hello World” sample application is to set references to the
MapSuite.Core
and
MapSuite.iOSEdition
workspaces at the very top of our code, since we'll use many classes within them. Set the reference like this:
<source lang=“csharp”> using ThinkGeo.MapSuite.Core; using ThinkGeo.MapSuite.iOSEdition; </source>
Display World Map
Now, Let's add a base overlay to display the world map witch called “WorldMapKitOverlay”.
          base.ViewDidLoad();
          View.Add(mapView);
          <nowiki>//</nowiki> Set the Map Unit to DecimalDegrees, the Shapefile’s unit of measure.
          mapView.MapUnit = GeographyUnit.DecimalDegree;
          <nowiki>//</nowiki> Create a WorldMapKitOverlay.
          WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay();
          <nowiki>//</nowiki> Add a WorldMapKitOverlay.
          mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay);
          <nowiki>//</nowiki> Set a proper extent for the map. The extent is the geographical area you want it to display.
          mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26);
          mapView.Refresh();
</source>
QSG_iOS_Img10.png|Figure 3. A simple map of Europe.
Shapefiles
ShapeFileFeatureLayers
Map
Styles
PresetZoomLevels
PresetZoomLevels has a very useful property called
ZoomLevel.ApplyUntilZoomLevel
, which you can easily use to extend your ZoomLevels. Let's say you want a particular style to be visible at ZoomLevel03 through ZoomLevel10. To make that work, simply code as follows:
<source lang=“csharp”> capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; </source>
In creating our “Hello World” sample application, our first step is to set references to the
MapSuite.Core
and
MapSuite.iOSEdition
*worldwide country borders (Countries02.shp)
(NOTE: The data used here can be found in the attached sample above in the “\AppData” folder. The data files' build action should be “Content”.)
Our next step is to define and add our Layers. Here is the code to use for our example. All of the following code can be placed in the
ViewDidLoad
override method.
  base.ViewDidLoad();
  View.Add(mapView);
  <nowiki>//</nowiki> Create a new Layer and pass the path to a Shapefile into its constructor.
  ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"AppData/Countries02.shp");
  <nowiki>//</nowiki> Set the worldLayer with a preset Style, as AreaStyles.Country1 has YellowGreen background and black border, our worldLayer will have the same render style.
  <nowiki>//</nowiki> This setting will apply from ZoomLevel01 to ZoomLevel20, which means the map will be rendered in the same style, no matter how far we zoom in or out.
  <nowiki>//</nowiki> Create a new Layer Overlay to hold the layer we just created
  <nowiki>//</nowiki> Add the shapefile layer to the layer overlay
  <nowiki>//</nowiki> Add the layerOverlay to map.
  mapView.Overlays.Add(layerOverlay);
  <nowiki>//</nowiki> We now need to call the Refresh() method of the Map view so that the Map can redraw based on the data that has been provided.
  mapView.Refresh();
} </source>
If you compile and run what you have now, your map should look like the one below. (see Figure 4).
QSG_iOS_Img08.png|Figure 4. A Simple map of Europe.
NOTE: It is important that the MapUnit property of a Map object be set using the
GeographyUnit
Enumeration. This is because the coordinates stored in a Shapefile can be in decimal degrees (a format of latitude and longitude), feet, meters, or another unit system, and our map has no way to know what the Shapefile's unit of measurement is until we tell it. This information is normally found somewhere in the Shapefile's documentation (also referred to as its metadata), or within its supplemental data file, as discussed in the section on Shapefiles. It may also come as a separate .txt, .xml, or .html file that begins with the same file name as the main Shapefile.
#World country borders (“Countries02.shp”) #World capitals (“WorldCapitals.shp”)
  base.ViewDidLoad();
  View.Add(mapView);
  ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(@"AppData/WorldCapitals.shp");
  <nowiki>//</nowiki> Similarly, we use the presetPointStyle for cities.
  <nowiki>//</nowiki> This setting also applies from ZoomLevel01 to ZoomLevel20, so city symbols will be rendered in the same style, no matter how far we zoom in or out.
  <nowiki>//</nowiki> We need to add both of the new layers to the Layer OverLay.
  mapView.Refresh();
} </source>
QSG_iOS_Img09.png|Figure 5. A map of Europe with the additional borders and capitals layers displayed.
How to Use TextStyle
  base.ViewDidLoad();
  View.Add(mapView);
  <nowiki>//</nowiki> This setting also applies from ZoomLevel01 to ZoomLevel20, which means city symbols will be rendered in the same style no matter how far we
  <nowiki>//</nowiki>zoom in or out.
  <nowiki>//</nowiki> We create a new Layer for labeling the capitals.
  ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(@"AppData/WorldCapitals.shp");
  <nowiki>//</nowiki> We use the preset TextStyle. Here we pass in "CITY_NAME", the name of the field containing the values we want to label the map with.
  <nowiki>//</nowiki> Since the map is drawn with tiles, the label needs to draw on the margin to make sure the text is complete after joining the tiles together.
  <nowiki>//</nowiki> Change the number below (to 0, for example) to better understand how this works.
  mapView.Refresh();
} </source>
The result should look like this (Figure 6):
QSG_iOS_Img11.png|Figure 6. Europe map with TextStyle applied.
  base.ViewDidLoad();
  View.Add(mapView);
  <nowiki>//</nowiki> We can customize our own Style. Here we pass in a color and a size.
  <nowiki>//</nowiki> The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, it will no longer be visible.
  <nowiki>//</nowiki> The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, it will no longer be visible.
  <nowiki>//</nowiki> We can customize our own TextStyle. Here we pass in the font, size, style and color.
  <nowiki>//</nowiki> The TextStyle we set here is available from ZoomLevel01 to ZoomLevel05.
  <nowiki>//</nowiki> The TextStyle we set here is available from ZoomLevel06 to ZoomLevel20.
  mapView.Refresh();
} </source>
QSG_iOS_Img12.png|Figure 7. Map of Europe before zooming in.
QSG_iOS_Img13.png|Figure 8. Map of Europe after zooming in.
Summary
#It is of the utmost importance that the units (feet, meters, decimal degrees, etc.) be set properly for the Map control, based on the requirements of your data. #Shapefiles provide the data used by a Map control to render a map. #A Map is the basic control that contains all the other objects used to indicate how the map should be rendered. #A Map has one-to-many Layers. A Layer correlates one-to-one with a Shapefile (.shp). #A Layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges (upper and lower scales) of when a Layer should be shown or hidden.
<br>
filelinkDownload Sample Code From This Exercise (1.5 MB)
Map Suite iOS Edition iOS GIS .NET
map_suite_ios_edition_quick_start_guide.1441788490.txt.gz · Last modified: 2015/09/09 08:48 by admin
