This is a complete list of the methods exposed in the Map Suite GPS Tracking Server web portal web services. These services allow you to manipulate your Map Suite GPS Tracking Server web portal accounts, users, departments, devices and more.
The web service APIs are divided into two groups: Account APIs and Installation APIs. The scope of the Account APIs is a single account within your Map Suite GPS Tracking Server system; these allow you to manipulate that account's devices, users, departments and so on. The Installation APIs, by contrast, have a scope encompassing the entire GPS Tracking Server system. These give you access to creation and deletion of accounts and frontend language packs on the server.
Parameters:
securityKey | Required, user ID |
accountID | Required, Account ID |
Return value: String
Function description: Gets an organization from an account.
Parameters:
userName | Required, user name for authentication |
password | Required, password for authentication |
Function description: Gets all organizations from an account.
Parameters:
orgID | Required, Organization ID |
Function description: Gets an organization.
Parameters:
accountID | Required, account ID |
orgName | Required, organization name |
Description | Organization description |
mapDataID | Required, map Data ID |
timeZone | Required, time zone of the organization's location |
metric | Required, selects whether the organization's unit system is metric or imperial |
status | Required, organization status, must be ACTIVE or INACTIVE, default is ACTIVE |
externalID | Reserved field |
Return value: OrganizationID
Function description: Creates an organization.
Parameters:
orgID | Required, organization ID |
description | Organization description |
manager | Manager of the organization |
imageName | The path of the organization image |
mapDataID | Required, map data ID |
Function description: Edits an organization.
Parameters:
Function description: Deletes an organization in the system.
Parameters:
deviceID | Required, device ID |
Function description: Adds a device to an organization.
Parameters:
carrierID | Required, carrier ID |
Function description: Adds a carrier to an organization.
Parameters:
monitorID | Required, monitor ID |
Function description: Adds a monitor to an organization.
Parameters:
Function description: Gets the carriers in an organization.
Parameters:
Function description: Gets the devices in an organization.
Parameters:
Function description: Gets the monitors in an organization.
Parameters:
Function description: Deletes a carrier from an organization.
Parameters:
Function description: Deletes a device from an organization.
Parameters:
Function description: Deletes a monitor from an organization.
Parameters:
Function description: Gets all available map data for an account.
Parameters:
adminUserName | Required, admin user name for authentication |
adminUserName | Required, admin password for authentication |
name | Required, Monitor name |
description | Monitor description |
userName | Required, user name |
password | Required, password |
entryReference |
Dashboard or Map Area|
status | Required, monitor status, must be ACTIVE or INACTIVE, default is ACTIVE |
Return value: MonitorID
Function description: Creates a monitor.
adminPassword | Required, admin password for authentication |
monitorID | Monitor ID |
name | Required, monitor name |
entryReference |
Function description: Edits a monitor.
Parameters:
MonitorID | Required, monitor ID |
Function description: Deletes a monitor from the system.
Parameters:
Function description: Gets a monitor.
Parameters:
Function description: Gets monitors from an account.
Parameters:
Function description: Gets monitors from an organization.
Parameters:
Function description: Gets users from an account.
Parameters:
userID | Required, user ID |
Function description: Gets a user.
Parameters:
status | Required, user status, must be ACTIVE or INACTIVE, default is ACTIVE |
entryReference |
firstName | First name |
lastName | Last name |
emailAddress | Email address |
activateDate | Activation date |
deactiveDate | Deactivation date |
allowMultipleSessions | Whether to enable multiple sessions, which allow the same user to be logged in more than once simultaneously |
checkMessageInterval | Check message interval |
Return value: UserID
Function description: Creates a user.
Parameters:
entryReference |
Function description: Edits a user.
Function description: Deletes a user from the system.
newPassword | Required, new password |
Function description: Change a user's password.
Parameters:
username | Required, the user name to check for |
Function description: Checks whether a specified username is in use.
Parameters:
emailAddress | Required, the email address to check for |
Return value: bool
Function description: Checks whether a specified user email address is in use.
Parameters:
organizationID | Required, organization ID |
Function description: Gets the devices from an organization.
Parameters:
accountid | Required, account ID |
Function description: Gets the devices from an account.
Parameters:
Function description: Gets all devices from an organization.
Parameters:
Function description: Gets the device categories.
Parameters:
Function description: Gets a device.
Parameters:
deviceName | Required, device name |
description | Device description |
topSpeed | Required, top speed |
status | Required, device status, must be ACTIVE or INACTIVE, default is ACTIVE |
imei | Required, International Mobile Equipment Identifier (IMEI) or Electronic Identifier (EID) of the wireless modem |
cannedMessage |
way communication|
deviceCategoryID | Device category ID |
colorCode | Choose a color to associate with the device, default is a random color |
Return value: DeviceID
Function description: Creates a device.
Parameters:
DeviceID | Required, device ID |
cannedMessage |
way communication|
Function description: Edits a carrier.
Parameters:
Function description: Delete a device from the system.
Parameters:
Function description: Gets the carriers from an account.
Parameters:
Function description: Gets the carriers from an organization.
Parameters:
Function description: Gets a carrier's device.
Parameters:
Function description: Gets a carrier.
Parameters:
carrierName | Required, carrier name |
carrierPin | Carrier's personal identification number, the default value is 0000 |
status | Required, carrier status, must be ACTIVE or INACTIVE, default is ACTIVE |
Return value: CarrierID
Function description: Creates a carrier.
Parameters:
description | Required, description of the carrier |
otherInformation | Other information about the carrier, HTML supported. Will be displayed in a popup bubble on the tracking screen. |
Parameters:
Function description: Deletes a carrier from the system.
Parameters:
Function description: Assigns a device to a carrier.
Parameters:
Function description: Disassociates a device from a carrier.
Parameters:
serverity | Required, serverity level |
Function description: Loads an event response for an account.
Parameters:
serverity | Required, serverity |
Function description: Loads an event response for an organization.
Parameters:
additionalEmailAddresses | Required |
alertPopupAction | Required, popup action |
alertThreshold | Required, alert threshold |
friendlyName | Required, friendly name |
iconPath | Required |
noisePath | Required |
overridden | Required |
overrides | Required |
repeat | Required |
sendEmail | Required |
severityColor | Required |
Function description: Edits an event response for an account.
Parameters:
repeat | Required |
Function description: Edits an event response for an organization.
Parameters:
adminUserName | Required, user name for authentication |
adminPassword | Required, password for authentication |
IMEI | Required, Device IMEI |
locationID | Required, New Guid |
logTime | Required, GPS date time of message |
yPoint | Required, Latitude |
xPoint | Required, Longitude |
altitude | Required, altitude |
speed | Required, device speed |
travelDirection | Required, Travel Direction |
speedUncertainty | Required, Speed Uncertainty or not |
responseCode | Required |
assistanceUsed | Required |
Return value: LocationID
Function description: Create a location for device.
Parameters:
deviceID | Required |
Function description: Get current location for the device.
Parameters:
lsessionD | Required |
Function description: Get locations for the session.
Parameters:
installUserName | Required, installer user name for authentication |
installPassword | Required, installer password for authentication |
adminUserName | Required, admin user name for the account |
adminPassword | Required, admin password |
accountName | Required, account name |
status | Required, account status, must be ACTIVE or INACTIVE, default is ACTIVE |
activateDate | Account activation date |
deactivateDate | Account deactivation date |
manageSecurity | Can manage security or not |
manageBrand | Can manage brand or not |
processLocationInfo | Can process LocationInformation of map or not in account level |
termsOfUse | Can use terms of use or not |
orgLimit |
1 (unlimited)|
monitorLimit |
1 (unlimited)|
carrierLimit |
1 (unlimited)|
deviceLimit |
1 (unlimited)|
targetLimit |
1 (unlimited)|
areaLimit |
1 (unlimited)|
securityPath |
Factor Authentication is enabled in Account General Settings, the security binary path will be used to judge whether or not this account is TwoFactorSecurity Valid when a user logs in.|
Return value: AccountID
Function description: Creates an account at the installer level.
Parameters:
Function description: Checks to see whether the account exists in the system.
Parameters:
Function description: Gets all of the accounts under this installation.
Parameters:
manageBrand | Can manage branding or not |
processLocationInfo | Can process LocationInformation of the map at the account level or not |
termsOfUse | Can apply Terms of Use or not |
orgLimit |
1 (unlimited)|
monitorLimit |
1 (unlimited)|
carrierLimit |
1 (unlimited)|
deviceLimit |
1 (unlimited)|
targetLimit |
1 (unlimited)|
areaLimit |
1 (unlimited)|
securityPath |
Function description: Edits an account at the installer level.
Parameters:
Function description: Deletes an account in the system at the installer level.
Parameters:
Function description: Gets a list of languages available in the installation.
Parameters:
languageID | Required, language ID |
Function description: Gets a language.
Parameters:
Function description: Gets a list of the available system languages.
Parameters:
Function description: Deletes a language.
Parameters:
languageName | Required, language name |
isSystem | Required |
Status | Required, status |
Function description: Creates a new language.
Parameters:
Function description: Edits a language.
Parameters:
Function description: Sets the language for a user.
