map_suite_gps_tracking_server_web_portal_quick_start_guide
Map Suite GPS Tracking Server Web Portal Quick Start Guide
This Quick Start guide is designed to help you start using your Map Suite GPS Tracking Server's web portal. The web portal is the web-based interface that you (and/or your customers) can use to visually track and manage assets, wherever they are located. This guide will introduce you to the common features that you'll be using most often and will walk you through some simple first-time tasks.
An outline of the topics that are covered by this guide:
  1. Logging into the system
  2. Using the Tracking Screen to locate your assets
  3. Creating a geofence
  4. Sending a test alert
  5. Creating a simulated tracking session
  6. Getting familiar with the Dashboard
  7. Adding a new GPS tracking device to your system
The Map Suite GPS Tracking Server Quick Start Guide is available in the following formats:
Download Formats
PDF
Microsoft Word (zipped)
map_suite_gps_tracking_server_web_portal_quick_start_guide.1441867898.txt.gz · Last modified: 2015/09/10 06:51 by admin
