If you are developing a custom device listener for your Map Suite GPS Tracking Server, the best way to start is by downloading one of these sample listeners that we've prepared to help guide you through the process. You can use any of our sample listeners as a base to develop you own custom listener for any device you wish.
You'll need Microsoft Visual Studio 2008 or higher to open the development solutions contained in each sample listener package. These samples were developed against the Device Gateway SDK for .NET, the files for which are also included with each sample listener.
Listener | Description |
Simple Sample Listener | Shows how to build your own TCP listener using the Gateway SDK. |
TCP Sample Listener | A simple, bare-bones listener that demonstrates the basics of working with the Gateway SDK. |
UDP Sample Listener | Shows how to build your own UDP listener using the Gateway SDK. |
Web Sample Listener | Shows how to build a simple web-based listener using the Gateway SDK. |
NMEA Web Sample Listener | Shows how to build a web-based listener to receive an NMEA string via the Gateway SDK. |
Two-Way Communication Sample Listener | Shows how the Map Suite GPS Tracking Server's two-way communication works using the Gateway SDK. |
If you're developing a custom device listener with our Gateway SDK and are experiencing difficulties getting your device to post data to your Map Suite GPS Tracking Server, check the Gateway Message Log. Once you enter the associated account's API key and the device ID, you'll be able to see a complete log of all successful and unsuccessful communications between the Gateway and your device. This is extremely helpful in diagnosing and correcting communication problems.
Check the installation and setup instructions that came with your purchase of the Map Suite GPS Tracking Server for details on how to access the Gateway Message Log, as its exact location depends on your server configuration.
