map_suite_gps_tracking_server_gateway_sdk_for_.net
Map Suite GPS Tracking Server Gateway SDK for .NET
The Device Gateway SDK is an API wrapper for .NET developers that enables fast and simple device listener development for the Map Suite GPS Tracking Server. Designed for use with Microsoft Visual Studio 2008 or higher, the Gateway SDK is added as a reference within your project and automates most of the communication between your Map Suite GPS Tracking Server's Device Gateway and your device listener.
Download the Gateway SDK for .NET
Getting Started
If you are developing a custom device listener with the Gateway SDK, the best way to start is by downloading one of the sample listeners that we've developed to help guide you through the process. You can use any of our sample listeners as a base to develop your own custom listener for any device you wish.
Reference Documentation
The Gateway SDK pacakge comes with a compiled help manual (in CHM format) that you can use for reference.
Listener Debugging
If you're developing a custom device listener with our Gateway SDK and are experiencing difficulties getting your device to post data to your Map Suite GPS Tracking Server, check the Gateway Message Log. Once you enter the associated account's API key and the device ID, you'll be able to see a complete log of all successful and unsuccessful communications between the Gateway and your device. This is extremely helpful in diagnosing and correcting communication problems.
Check the installation and setup instructions that came with your purchase of the Map Suite GPS Tracking Server for details on how to access the Gateway Message Log, as its exact location depends on your server configuration.
map_suite_gps_tracking_server_gateway_sdk_for_.net.txt · Last modified: 2015/09/25 03:29 by admin
