Please note that you will need an evaluation (or full version) of both Map Suite Geocoder and Map Suite Desktop Edition to build and run these samples.
The Geocoder Data Reducer is a utility that allows you to create a new smaller geocoder index for specific states in the United States. You simply specify the directory of ThinkGeo full Geocoder Index files, select the states you want to reduce it to, the output folder, and the utility will create the new reduced index. Depending on the state the process may take up to a couple of hours to process.
