Version 10.5.0
Release date: 04/01/2019
  • Added support of new class ThinkGeoCloudVectorMapsOverlay to consume Vector Tiles from ThinkGeo Cloud
  • Enhanced to support sending web request event and sent web request event for ThinkGeoCloudMapsOverlay
  • Enhanced to rename ThinkGeoCloudMapsOverlay to ThinkGeoCloudRasterMapsOverlay and ThinkGeoCloudMapsMapType to ThinkGeoCloudRasterMapsMapType
  • Fixed a bug that default ThinkGeo Cloud Maps server URLs need get updated
  • Fixed a bug that memory leak in AdornmentOverlay in certain scenario
  • Fixed a bug that map met exception when tile cache is set to null for ThinkGeoCloudMapsOverlay
  • Fixed a bug that overlay reorder after refresh in certain scenario
ThinkGeo.MapSuite Namespace:
  • Added support of Skia as the drawing engine to improve the performance.
  • Added support of semantic cartography schema – StyleJSON to design the map.
  • Added support of vector tile based *.MbTiles format.
  • Added support of ThinkGeoCloudRasterMapsLayer
  • Added support of high resolution for PlatformGeoCanvas, it mainly works for iOS edition
  • Enhanced to support parse special node in capability XML contains two spaces for WMTSLayer, generally Oracle export this type XML
  • Enhanced to support “ScaleFactor” property, it shows the high resolution value, it mainly works for iOS edition
  • Enhanced to support drawing halo pen dasharray on SkiaGeoCanvas
  • Enhanced to support both meter and decimal degree for NauticalCharts
  • Enhanced to support use ThinkGeoCloudRasterMapsLayer in iOS and Android edition
  • Fixed a bug that print google map to pdf tile unmatch
  • Fixed a bug that BuildingAreaStyle don't works follow design
  • Fixed a bug that OSM Buildings Url need get updated
  • Fixed a bug that some geotiff files looks jump when pan on map after set projection
  • Fixed a bug that text style don't works for wrapping lines in certain scenario
  • Fixed a bug that wrong boundary limit for Proj4Projection in certain scenario
  • Fixed a bug that the width or height value maybe equal zero when calling ToScreenCoordinate for GeoTiff
  • Fixed a bug that projection cannot handle parameter correct in certain scenario
  • Fixed a bug that PlatformGeocanvas throw format exception in certain scenario
  • Fixed a bug that GetDrawingExtent function loss precision in certain scenario
  • Fixed a bug that MapType is invalid when initializing ThinkGeoCloudRasterMapsLayer
  • Fixed bugs that some geotiff files cannot load correct
Version 10.4.0
Release date: 12/10/2018
  • Added new class ThinkGeoCloudMapsOverlay to support new ThinkGeo Cloud Map
  • Enhanced to use more accurate exception information
  • Enhanced to support WrapDateLine for ThinkGeoCloudMapsOverlay
  • Fixed a bug the BackgroundOverlay doesn't works correct
  • Fixed a bug the map flicker when zoom out in certain scenario
  • Fixed a bug the ThinkGeoCloudMapsOverlay throw exception after applying ClientId/ClientSecret
  • Fixed a bug the ThinkGeoCloudMapsOverlay generate incorrect route in certain scenario
  • Fixed a bug the ThinkGeoCloudMapsOverlay render two types tiles at the same after switch MapType to transparent background
  • Fixed a bug the ClassBreaks in ClassBreakMarkerStyle doesn't works correct
  • Added new overloading method for DrawText in GeoCanvas class
  • Enhanced to get better performance for data drawing when shape file contains many inner rings in polygon
  • Enhanced to support Esri srid input for Proj4Projection
  • Enhanced to support Esri coordinate system when create table for FileGeoDatabase
  • Enhanced to use more accurate exception information and exception type
  • Fixed a bug map throw null reference exception in certain scenario
  • Fixed a bug the Sqlite R Tree calculate different result in Windows and Linux
  • Fixed a bug some special invalid saturation and luminance values for GeoColor can pass our validation
  • Fixed a bug vector data won't render all shapes if the width is too big
  • Fixed a bug XyzFileBitmapTileCache lose cache ID in certain scenario
  • Fixed a bug GettingTileCache event won't be fired in correct step
  • Fixed a bug the overlays don't match when print to PDF
  • Fixed a bug white line shows for WMTSlayer
  • Fixed a bug exception is thrown when met invalid tile in WMTSlayer
  • Fixed a bug failed to load dll in FileGeoDatabase for asp.net scenario
  • Fixed a bug ECW render distorted image in special zoomlevel
  • Fixed a bug GeoTiff image jump in certain scenario
Version 10.3.0
Release date: 7/26/2018
  • Improved GoogleMapsOverlay performance when using single tile mode
Version 10.2.0
Release date: 10/27/2017
  • Supported 3D rendering for buildings(Overlay level)
  • Fixed a bug where marker will be fuzzy in certain scenarios
  • Fixed a bug where Wpf application throw null exception and stop work after few minutes in certain scenarios
Version 10.1.0
Release date: 06/21/2017
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
Version 5.0.0.0
Release date: 5/16/2011
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added OSM overlay.
  • Added ClusterPointStyle
map_suite_desktop_for_wpf_features_bug_fixes_change_log.1554277792.txt.gz · Last modified: 2019/04/03 07:49 by tgwikiupdate
