Version 10.3.0
Release date: 7/26/2018
  • Improved GoogleMapsOverlay performance when using single tile mode
  • Fixed a bug that WMS Client doesn't deal with exception of WMS Server not available
ThinkGeo.MapSuite Namespace:
Version 10.2.0
Release date: 10/27/2017
  • Supported 3D rendering for buildings(Overlay level)
  • Fixed a bug where marker will be fuzzy in certain scenarios
  • Fixed a bug where Wpf application throw null exception and stop work after few minutes in certain scenarios
Version 10.1.0
Release date: 06/21/2017
Version 10.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
Version 5.0.0.0
Release date: 5/16/2011
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added OSM overlay.
  • Added ClusterPointStyle
map_suite_desktop_for_wpf_features_bug_fixes_change_log.1532597475.txt.gz · Last modified: 2018/07/26 09:31 by tgwikiupdate
