Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • ?? Fixed a bug in Refresh(Enumerable).
  • Fixed a tile cache bug when the ?? MapType changed.
  • ?? Fixed the wrong zoomlevel on openstreetmap.
  • ?? Fixed the issue about the layers moving out of position when change the extent during the panning operation.
  • ?? Added Cancel property to SendingWebRequestEventArgs and apply it to OSMOverlay and TiledOverlay.
  • ?? Fixed the white lines issue between the tiles.
  • ?? Fixed a bug where stop the panning timer before drawing tileoverlay.
  • ??Fixed requiredParameters bug when the Layer type is OSMWorldMapKitLayer and mapType is AerialWithLabels
  • ??Fixed format issue when converting string to double and int.
ThinkGeo.MapSuite Namespace:
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
Version 5.0.0.0
Release date: 5/16/2011
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added OSM overlay.
  • Added ClusterPointStyle
map_suite_desktop_for_wpf_features_bug_fixes_change_log.1489719855.txt.gz · Last modified: 2017/03/17 03:04 by tgwikiupdate
