Version 10.0.0.0
Release date: 02/16/2017
Map Suite 10.0 New Features:
  • Synchronize the Core APIs across all Map Suite product line.
  • Allow to use Map Suite product without installer.
  • Simplified the license process.
  • Split the original MapSuite Core assembly by functionality. It allows users to embed required assemblies into their projects.
  • Create a BareBone version package for Map Suite products to allow user to create app with minimum size.
  • Create a Standard version package for Map Suite products to transfer user’s existing project to 10.0 easily.
  • Fixed a bug in Refresh(Enumerable).
  • Fixed a bug for map resizemode PreserveExtent.
  • Fixed a bug that memory leak caused by unbind events.
  • Enhanced the file license.
  • Fixed a bug where the tilecache is incorrect when MapType changed.
  • Fixed draw line bug.
  • Fixed a bug that exception make application crash for BingMapsOverlay.
  • Refine the logic for drawing tile to skip obsoleted tiles
  • Fixed the UriTile SingleTile NullReferenceException
  • Fixed TileMatrices out of range bug
  • Fixed the wrong zoomlevel on openstreetmap.
  • Fixed the issue about the layers moving out of position when change the extent during the panning operation.
  • Fixed the GoogleMapsOverlay draws the tiles incorrectly.
  • Fixed a GoogleMapsOverlay tile cache bug.
  • Added Cancel to SendingWebRequestEventArgs and apply it to OSMOverlay and TiledOverlay.
  • Fixed white lines.
  • Fixed a bug where stop the panning timer before drawing tileoverlay.
  • Added Language property into GoogleMapsOverlay
  • Fixed a bug that losing the tag value while editing
  • Fixed OutOfRangeException for PanZoomBarMapTool.
  • Fixed a bug where Workaround for solve the issue when user quickly zoom, and network is slow, the system will save empty tile image.
  • Fixed requiredParameters bug when the Layer type is OSMWorldMapKitLayer and mapType is AerialWithLabels
  • Fixed format issue when converting string to double and int.
ThinkGeo.MapSuite Namespace:
  • Added style sheets support.
Version 9.0.0.0
Release date: 06/24/2015
  • Added Leader Lines.
Version 8.0.0.160
Release date: 11/17/2014
Version 8.0.0.0
Release date: 06/06/2014
Version 7.0.0.0
Release date: 06/03/2013
Version 6.0.0.0
Release date: 05/14/2012
Version 5.5.0.49
Release date: 12/31/2011
Version 5.5.0.0
Release date: 11/14/2011
  • Added the IsoLine Support.
Version 5.0.0.55
Release date: 7/7/2011
Version 5.0.0.0
Release date: 5/16/2011
  • Removed the Obsolete APIs.
Version 4.5.0.0
Release date: 11/01/2010
  • Added OSM overlay.
  • Added ClusterPointStyle
map_suite_desktop_for_wpf_features_bug_fixes_change_log.1488791284.txt.gz · Last modified: 2017/03/06 09:08 by tgwikiupdate
