The Winforms QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This QuickStart Guide supports Map Suite 10.0.0.0 and higher and will show you how to create a Winforms application.
If you want to build a WPF application, please see the WPF QuickStart Guide instead.
The purpose of this guide is to help you quickly get started building your own spatially aware applications. Like any new software, there is some learning to be done. How do we start to learn how to take advantage of the power of Map Suite? The best way is to make a sample application with it.
Let's start by creating a new Windows Forms Application in Microsoft Visual Studio (2015 or newer) named HelloWorld (see Figure 1). We can create the project with .NET Framework 4.5 or higher.
After you created a HelloWorld project, we will see a project in the solution, please see Figure 2.
You need to add the NuGet package for Map Suite Desktop to the “Hello World” project. Right-click the Reference in Solution Explorer and select “Manage NuGet Packages” (See Figure 3).
Figure 3. Refer to Manage NuGet Packages.
You can see the NuGet Package management start page in our Microsoft Visual Studio main window.
Ensure that “Browse” is selected and then type “Desktop” in the search box then press enter. You should see a package list (See Figure 4) in the main window.
In that package list, please select “MapSuiteDesktopForWinForms-BareBone” package and click the “Install” button in the right panel.
Figure 4. Refer to MapSuiteDesktopForWinForms-BareBone.
Click “OK” if the message box like Figure 5 pops up.
Once the package is installed, you can see the message “Successfully installed
'MapSuiteDesktopForWinForms-BareBone 10.0.0' to HelloWorld” in your Microsoft Visual Studio Output box.
Some Desktop assemblies have been added into the project references. (See Figure 6).
Figure 6. NuGet installation result.
In addition to the “MapSuiteDesktopForWinForms-BarBone” package, you also need two other packages named “ThinkGeo.MapSuite.Layers.ShapeFile” and “ThinkGeo.MapSuite.Styles.WorldStreets” to implement our “HelloWorld” application. Type “shapefile” into the search box and select the “ThinkGeo.MapSuite.Layers.ShapeFile” package to add it to the package list. Installing the package is the same as the steps for “MapSuiteDesktopForWinForms-BarBone” package. (See Figure 7).
Figure 7. NuGet ShapeFile installation.
Type “styles.worldstreets” into the search box and select the “ThinkGeo.MapSuite.Styles.WorldStreets” package
in the package list. Install this package following the same steps. (See Figure 8).
Figure 8. NuGet WorldStreets installation.
1. When you first open Microsoft Visual Studio after installing Map Suite, you may not see the controls in the Toolbox. You will need to follow these steps to add the controls. Hover over Toolbox and right click anywhere on list of controls. You will get a pop-up menu. Select “Choose Items…” (See Figure 9)
Figure 9.Configure a nuget package address.
2. A dialogue box named “Choose Toolbox Items” will appear. You will need to select the .NET Framework Components tab and then click the Browse button. Finally navigate to the MapSuiteDesktopForWinForms-BareBone.10.0.0 Nuget package installation folder and select the “ThinkGeo.MapSuite.WinForms.dll” file.
Figure 10.Add ThinkGeo.MapSuite.WinForms.dll to .Net Framework Components.
3. You should now have the Map Control available in your Toolbox as shown in Figure 11 below.
Draw the Map control on the form by clicking on the WinformsMap Control object in the Toolbox and then dragging and dropping (using the left mouse button) to the form. You can resize the map if you desire. You can leave the name of the Map control as winformsMap1. Our map will display in this object.
In creating your “Hello World” sample application, your first step is to set some references at the very top of your code as you will use many classes within that. Open the “Form1.cs” in the project and click the form in the opened design box to move to the “View Code” of the form. Add the references like this:
using ThinkGeo.MapSuite; using ThinkGeo.MapSuite.WinForms; using ThinkGeo.MapSuite.Layers; using ThinkGeo.MapSuite.Styles; using ThinkGeo.MapSuite.Shapes;
Our next step is to define and add our Layers. Here is the code to use for our example. All of the following code can be placed in the Form1_Load event of the form.
private void Form1_Load(object sender, EventArgs e) { // Set the Map Unit. The reason for setting it to DecimalDegrees is that is what the shapefile’s unit of measure is inherently in. winformsMap1.MapUnit = GeographyUnit.DecimalDegree; // We create a new Layer and pass the path to a Shapefile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"../../Data/Countries02.shp"); AreaStyle areaStyle = new AreaStyle(); areaStyle.FillSolidBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; // Set the worldLayer with a preset Style. worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; // This setting will apply from ZoonLevel01 to ZoomLevel20, that means we can see the world the same style with ZoomLevel01 all the time no matter how far we zoom out/in. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // Create a new Layer Overlay to hold the layer we just created LayerOverlay layerOverlay = new LayerOverlay(); // Add the shapefile layer to the layer overlay layerOverlay.Layers.Add(worldLayer); // We need to add the layer overlay to Map. winformsMap1.Overlays.Add(layerOverlay); // Set a proper extent for the Map. winformsMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26); // We now need to call the Refresh() method of the Map control so that the Map can redraw based on the data that has been provided. winformsMap1.Refresh(); }
Now it's time to press F5 to start the application. If you have not setup a developer license, Map Suite Product Center will pop up, and you need to generate your developer license by steps like active account → activate or start evaluation → continue debugging → get runtime license. For more details, please refer to (http://wiki.thinkgeo.com/wiki/map_suite_developer_license_guide).
Once developer license is ready, run the application, your map should look like the one below. (see Figure 12).
Figure 12. A Simple map of Europe.
NOTE: It is important that the MapUnit property of a Map object be set using the GeographyUnit Enumeration. This is because Shapefiles only store binary vector coordinates, which can be in DecimalDegree, feet, meters, etc., and our map has no idea about what the unit of measurement is until we set it. This information is normally found somewhere in the documentation or within the supplemental data file as discussed in the section on Shapefiles.
private void Form1_Load(object sender, EventArgs e) { winformsMap1.MapUnit = GeographyUnit.DecimalDegree; ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"../../Data/Countries02.shp"); AreaStyle areaStyle = new AreaStyle(); areaStyle.FillSolidBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp"); // Similarly, we use the presetPointStyle for cities. PointStyle pointStyle = new PointStyle(); pointStyle.SymbolType = PointSymbolType.Square; pointStyle.SymbolSolidBrush = new GeoSolidBrush(GeoColor.StandardColors.White); pointStyle.SymbolPen = new GeoPen(GeoColor.StandardColors.Black, 1); pointStyle.SymbolSize = 6; capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = pointStyle; // This setting also applies from ZoonLevel01 to ZoomLevel20, that means we can see city symbols the same style with ZoomLevel01 all the time. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); // We need to add both of the new layers to the Layer OverLay. layerOverlay.Layers.Add(capitalLayer); winformsMap1.Overlays.Add(layerOverlay); winformsMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26); winformsMap1.Refresh(); }
And the result is as following (Figure 13):
TextStyle are used to label items on map. As every Shapefile has a relative .dbf file, which includes descriptions for every record, the most common way to use TextStyles is for labeling. For example, WorldCapital Shapefile's corresponding .dbf file contains the field “CITY_NAME”. We can use this field to label the cities on our map.
private void Form1_Load(object sender, EventArgs e) { winformsMap1.MapUnit = GeographyUnit.DecimalDegree; ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"../../Data/Countries02.shp"); AreaStyle areaStyle = new AreaStyle(); areaStyle.FillSolidBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp"); // Similarly, we use the presetPointStyle for cities. PointStyle pointStyle = new PointStyle(); pointStyle.SymbolType = PointSymbolType.Square; pointStyle.SymbolSolidBrush = new GeoSolidBrush(GeoColor.StandardColors.White); pointStyle.SymbolPen = new GeoPen(GeoColor.StandardColors.Black, 1); pointStyle.SymbolSize = 6; PointStyle stackStyle = new PointStyle(); stackStyle.SymbolType = PointSymbolType.Square; stackStyle.SymbolSolidBrush = new GeoSolidBrush(GeoColor.StandardColors.Maroon); stackStyle.SymbolPen = new GeoPen(GeoColor.StandardColors.Transparent, 0); stackStyle.SymbolSize = 2; pointStyle.CustomPointStyles.Add(stackStyle); capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = pointStyle; // This setting also applies from ZoonLevel01 to ZoomLevel20, that means we can see city symbols the same style with ZoomLevel01 all the time. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We create a new Layer for labeling the capitals. ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp"); // We use the preset TextStyle. Here we passed in the “CITY_NAME”, which is the name of the field we want to label on map. GeoFont font = new GeoFont("Arial", 9, DrawingFontStyles.Bold); GeoSolidBrush txtBrush = new GeoSolidBrush(GeoColor.StandardColors.Maroon); TextStyle textStyle = new TextStyle("CITY_NAME", font, txtBrush); textStyle.XOffsetInPixel = 0; textStyle.YOffsetInPixel = -6; capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = textStyle; capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // As the map is drawn by tiles, it needs to draw on the margin to make sure the text is complete after we joining the tiles together. // Change the number to another one (for example 0) and you can see the difference expecially when panning. LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); layerOverlay.Layers.Add(capitalLayer); layerOverlay.Layers.Add(capitalLabelLayer); winformsMap1.Overlays.Add(layerOverlay); winformsMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26); winformsMap1.Refresh(); }
The result is as following (Figure 13):
Figure 13. Europe map with TextStyle.
private void Form1_Load(object sender, EventArgs e) { winformsMap1.MapUnit = GeographyUnit.DecimalDegree; ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(@"../../Data/Countries02.shp"); AreaStyle areaStyle = new AreaStyle(); areaStyle.FillSolidBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp"); PointStyle pointStyle = new PointStyle(); pointStyle.SymbolType = PointSymbolType.Square; pointStyle.SymbolSolidBrush = new GeoSolidBrush(GeoColor.StandardColors.White); pointStyle.SymbolPen = new GeoPen(GeoColor.StandardColors.Black, 1); pointStyle.SymbolSize = 6; PointStyle stackStyle = new PointStyle(); stackStyle.SymbolType = PointSymbolType.Square; stackStyle.SymbolSolidBrush = new GeoSolidBrush(GeoColor.StandardColors.Maroon); stackStyle.SymbolPen = new GeoPen(GeoColor.StandardColors.Transparent, 0); stackStyle.SymbolSize = 2; pointStyle.CustomPointStyles.Add(stackStyle); // We can customize our own Style. Here we passed in a color and a size. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimpleCircleStyle(GeoColor.StandardColors.White, 7, GeoColor.StandardColors.Brown); // The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, the appearance we set here will not be visible anymore. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = pointStyle; // The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, the appearance we set here will not be visible any more. capitalLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp"); // We can customize our own TextStyle. Here we passed in the font, the size, the style and the color. GeoFont font = new GeoFont("Arial", 9, DrawingFontStyles.Bold); GeoSolidBrush txtBrush = new GeoSolidBrush(GeoColor.StandardColors.Maroon); TextStyle textStyle = new TextStyle("CITY_NAME", font, txtBrush); textStyle.XOffsetInPixel = 0; textStyle.YOffsetInPixel = -6; capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyles.CreateSimpleTextStyle("CITY_NAME", "Arial", 8, DrawingFontStyles.Italic, GeoColor.StandardColors.Black, 3, 3); // The TextStyle we set here is available from ZoomLevel01 to ZoomLevel05. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLabelLayer.ZoomLevelSet.ZoomLevel06.DefaultTextStyle = textStyle; // The TextStyle we set here is available from ZoomLevel06 to ZoomLevel20. capitalLabelLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; LayerOverlay layerOverlay = new LayerOverlay(); layerOverlay.Layers.Add(worldLayer); layerOverlay.Layers.Add(capitalLayer); layerOverlay.Layers.Add(capitalLabelLayer); winformsMap1.Overlays.Add(layerOverlay); winformsMap1.CurrentExtent = new RectangleShape(0, 78, 30, 26); winformsMap1.Refresh(); }
Can you imagine what the map will look like now? Below is the result. At first it appears like figure 15, and the map changes to figure 8 as you zoom in.
Figure 15. Europe Map with two ZoomLevels, before Zoom In.
Figure 16. Europe Map with two ZoomLevels, after Zoom In.
At this moment, we have complete our scenario, the next thing we want to do is to make it run on another machine which doesn’t have developer license. Runtime license is the one we are looking for. Here is a guide to generate a runtime license to satisfy it, please refer to (http://wiki.thinkgeo.com/wiki/map_suite_runtime_license_guide_for_desktop ) for details.
Because Desktop Edition uses multi-threading internally for drawing, if you want to change an overlay after the map is initialized, you need to lock the overlay first to avoid threading conflicts. For more information, please have a look at our “How Do I?” sample applications that come with the product.
