map_suite_desktop_for_winforms_all_samples
Table of Contents
WinForms Samples
QuickstartSample-forWinForms
The Winforms QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This QuickStart Guide supports Map Suite 10.0.0.0 and higher and will show you how to create a Winforms application.
Screenshot
View this sample on Github
Vehicle Tracking Sample Template for WinForms
Screenshot
Us Earthquake Statistics Sample Template for WinForms
Screenshot
Draw Custom Exception Sample for WinForms
Screenshot
Stream Loading For Gdi Plus Raster Layer Sample for WinForms
Screenshot
Feature Ids To Exclude Sample for WinForms
Screenshot
Dragging Vertex Sample for WinForms
The purpose of today’s project is not so much as show a new technology as to show an improvement in an existing one. We are already familiar with EditInteractiveOverlay with projects such as “Dragged PointStyle with Label”, “Snap To Layer” and “Snapping to Vertex”. But those projects showed EditInteractiveOverlay on small shapes. Using EditIntercticeOverlay on complex shapes became not very responsive. We improved that and now you can drag, resize, rotate and drag individual vertex of a complex polygon made of thousand of vertices with good responsiveness as you can see in this example.
Screenshot
Editing Rectangles Sample for WinForms
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes, rather than polygon shapes, by setting special column values. For features (both *Well Known Text* and *Well Known Binary*), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
Screenshot
Distance Query On Projected Layers Sample for WinForms
This sample shows how to use the method GetFeaturesWithDistanceOf when the data is projected. We just input the unit which is projected to, do not need to mind what the real unit is for the internal data before projection. It works fine with Map Suite Assemblies 4.5.54.0 or later.
Screenshot
GPS to Google Map Desktop Sample for WinForms
This project shows how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
Screenshot
Track Overlay With Esc Sample for WinForms
Screenshot
Multiple Labels Sample for WinForms
Screenshot
Create GRID Sample for WinForms
Screenshot
Line Style With Increment Sample for WinForms
In this WinForms desktop project, we show how to create a custom LineStyle for showing distance increment at a regular interval (every tenth kilometer). Having this LineStyle can be very handy when dealing with line networks, such as roads or railways.
Screenshot
Dragged Point Style Sample for WinForms
In this project, we focus our attention on how to control the style of the control points. You will see how to override the DrawCore function of EditInteractiveOverlay.
Screenshot
Dragging Icon Sample for WinForms
Screenshot
Ecw Sample for WinForms
The Ecw Sample template represents an ECW file for drawing on the map.
ECW: ECW is a wavelet image compression system developed by ER Mapper.It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales. It is very popular in the GIS community.
Screenshot
MrSid Sample for WinForms
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. In order to run this sample, development build 10.0.0.0 or later is required.
This sample includes a map with MrSID as base overlay, the MrSID shows the image data of the world range.
Screenshot
Known issue: The screenshot is taken under Linux, but it not well tested, maybe sometimes runs to exception.
Graphic Logo Adornment Sample for WinForms
Screenshot
Select Vertices Sample for WinForms
Screenshot
Labeling Based On Size Sample for WinForms
This project shows some advanced uses of the ClassBreakStyle to show how to label countries based on the area. You will notice that we also take advantage of the various zoom level sets for labeling purposes. The result is an eye pleasing labeling of the countries, with the size proportionate to the countries’ area, with more countries' labels appearing as you zoom in.
Screenshot
Kml Extension Sample Sample for WinForms
Screenshot
Lat Long Graticule Sample for WinForms
Screenshot
US Demographic Map Sample Template for WinForms
Screenshot
Custom Track Line Sample for WinForms
Screenshot
Custom Track Polygon Sample for WinForms
Learn how to extend the TrackInteractiveOverlay to add behaviors, like deleting the last added vertex when right-clicking the track line.
Screenshot
Open Street Map Sample for WinForms
OpenStreetMap (OSM) is a collaborative project to create free geographic data for the entire world. It can be thought of as a “Free Wiki World Map”. The latest version of MapSuite now supports this.
Screenshot
Intersect Line Sample for WinForms
Screenshot
Get Features Clicked On Sample for WinForms
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinates needs to be set so that the feature gets selected within a constant distance in screen coordinates to where the user clicked, regardless of the zoom level.
Screenshot
Screenshot
Centering On Moving Vehicle With Tolerance Sample for WinForms
Screenshot
Dynamic Track Shapes Sample for WinForms
This Desktop project shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked.
Screenshot
Detect GPS Desktop Sample for WinForms
Screenshot
Geocoding Samples for WinForms
[Sample Data Download](http://wiki.thinkgeo.com/wiki/_media/geocoding_hodoisamples_data.zip)
The Map Suite Geocoder “How Do I?” solution offers a series of useful how-to examples for using the Map Suite Geocoder component. The bundled solution comes with a small set of sample data from Chicago, IL and demonstrates geocoding, reverse geocoding, batch geocoding, use of fuzzy matching logic, getting the closest street number to a point, and much more. Full source code is included in both C==== and VB.NET languages; simply select your preferred language to download the associated solution.
Screenshot
Jpeg2000 Sample for WinForms
The Jpeg2000 Sample template represents a .JP2 (JPEG2000) image type to be drawn on the map.
Screenshot
Edit Geometry Of Shapefile Sample for WinForms
The purpose of this sample is to show how to update the geometry of a feature of a shapefile in one step. This sample is useful for anyone wanting to actualize the geometry part of its data. You can see how only a few lines of code are necessary for this process, and that the spatial index gets automatically updated after calling the committing the change.
Screenshot
Earth Quakes Heat Map Sample for WinForms
Screenshot
Screenshot
Site Selection Sample Template for WinForms
Screenshot
Create Inner Ring Sample for WinForms
In this Desktop project we create inner rings for a polygon, based on another polygon, using the GetDifference method. We also learn how to perform a Union on a collection of polygons, and how to set up the TrackEnded event.
To use this app, you need to track a polygon, double click to end it, and it will create an inner ring based on the unioned result of the polygons that are completely within the tracked polygon. You can look at the TrackEnded event handler to see all the different operations that are taking place for that task.
Screenshot
Dragged Point Style Advanced Sample for WinForms
This project is an example of how extensible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key, and how to have the vertex snap to any feature.
Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can easily be implemented by inheriting from EditInteractiveOverlay.
Screenshot
Routing Sample for WinForms
[Sample Data Download](http://wiki.thinkgeo.com/wiki/_media/routing/routing_howdoi_samples_data.zip)
The Map Suite Routing “How Do I?” solution offers a series of useful how-to examples for using the Map Suite Routing extension. The bundled solution comes with a small set of routable street data from Austin, TX and demonstrates simple routing, avoiding specific areas, getting turn-by-turn directions, optimizing for the Traveling Salesman Problem, and much more. Full source code is included in both C==== and VB.NET languages; simply select your preferred language to download the associated solution.
Screenshot
Dragged Point Style With Label Sample for WinForms
In this project, dedicated to EditInteractiveOverlay, you will see how easy it is to add some labeling to your dragged control point, showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the user experience, the closest point of the reference shape is also shown varying as the control point is dragged around.
Screenshot
GetZoomLevelSample-ForWinForms
This example demonstrates how to get the zoom level of the map each time we change its extent. Using custom zoom levels, you will see how to get the zoom level with its characteristics such as the upper and lower scale defining it. You can read the comments inside the project to better understand the relationship of scales with zoom levels.
Screenshot
WorldStreetsVectorLayerSDK-ForWinForms
The World Streets Vector Layer Explorer is a tool that enables you to view the SQLite World Streets data using Map Suite WinForms and provides complete performance metrics.
This project requires a full or evaluation version of Map Suite WinForms Edition.
This sample passed on Linux with Mono Runtime. On Windows platform, it is required to replace the ThinkGeo.MapSuite.Layers.SqliteForLinux with ThinkGeo.MapSuite.Layers.Sqlite package.
To run the sample, please unzip the database file at WorldStreetsVectorLayerSample/App_Data/DallasCounty-3857-20170218.zip, and change the connection string in WorldStreetsVectorLayerSample/App.config to connect database that you extracted to.
Working…
Screenshot
SqliteLayerSampleOnLinux-ForWinForms
The purpose of this sample is to show how to use SQLite as map data source.
screen
map_suite_desktop_for_winforms_all_samples.1489389516.txt.gz · Last modified: 2017/03/13 07:18 by tgwikiupdate
