The Winforms QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This QuickStart Guide supports Map Suite 10.0.0.0 and higher and will show you how to create a Winforms application.
This project shows some advanced uses of the ClassBreakStyle to show how to label countries based on the area. You will notice that we also take advantage of the various zoom level sets for labeling purposes. The result is an eye pleasing labeling of the countries, with the size proportionate to the countries’ area, with more countries' labels appearing as you zoom in.
This sample shows how to use the method GetFeaturesWithDistanceOf when the data is projected. We just input the unit which is projected to, do not need to mind what the real unit is for the internal data before projection. It works fine with Map Suite Assemblies 4.5.54.0 or later.
This Desktop project shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked.
The purpose of this sample is to show how to update the geometry of a feature of a shapefile in one step. This sample is useful for anyone wanting to actualize the geometry part of its data. You can see how only a few lines of code are necessary for this process, and that the spatial index gets automatically updated after calling the committing the change.
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinates needs to be set so that the feature gets selected within a constant distance in screen coordinates to where the user clicked, regardless of the zoom level.
This example demonstrates how to get the zoom level of the map each time we change its extent. Using custom zoom levels, you will see how to get the zoom level with its characteristics such as the upper and lower scale defining it. You can read the comments inside the project to better understand the relationship of scales with zoom levels.
In this WinForms desktop project, we show how to create a custom LineStyle for showing distance increment at a regular interval (every tenth kilometer). Having this LineStyle can be very handy when dealing with line networks, such as roads or railways.
In this Desktop project we create inner rings for a polygon, based on another polygon, using the GetDifference method. We also learn how to perform a Union on a collection of polygons, and how to set up the TrackEnded event.
To use this app, you need to track a polygon, double click to end it, and it will create an inner ring based on the unioned result of the polygons that are completely within the tracked polygon. You can look at the TrackEnded event handler to see all the different operations that are taking place for that task.
Learn how to extend the TrackInteractiveOverlay to add behaviors, like deleting the last added vertex when right-clicking the track line.
The World Streets Vector Layer Explorer is a tool that enables you to view the SQLite World Streets data using Map Suite WinForms and provides complete performance metrics.
This project requires a full or evaluation version of Map Suite WinForms Edition.
This sample passed on Linux with Mono Runtime. On Windows platform, it is required to replace the ThinkGeo.MapSuite.Layers.SqliteForLinux with ThinkGeo.MapSuite.Layers.Sqlite package.
To run the sample, please unzip the database file at WorldStreetsVectorLayerSample/App_Data/DallasCounty-3857-20170218.zip, and change the connection string in WorldStreetsVectorLayerSample/App.config to connect database that you extracted to.
Working…
This project is an example of how extensible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key, and how to have the vertex snap to any feature.
Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can easily be implemented by inheriting from EditInteractiveOverlay.
In this project, we focus our attention on how to control the style of the control points. You will see how to override the DrawCore function of EditInteractiveOverlay.
In this project, dedicated to EditInteractiveOverlay, you will see how easy it is to add some labeling to your dragged control point, showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the user experience, the closest point of the reference shape is also shown varying as the control point is dragged around.
The purpose of today’s project is not so much as show a new technology as to show an improvement in an existing one. We are already familiar with EditInteractiveOverlay with projects such as “Dragged PointStyle with Label”, “Snap To Layer” and “Snapping to Vertex”. But those projects showed EditInteractiveOverlay on small shapes. Using EditIntercticeOverlay on complex shapes became not very responsive. We improved that and now you can drag, resize, rotate and drag individual vertex of a complex polygon made of thousand of vertices with good responsiveness as you can see in this example.
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes, rather than polygon shapes, by setting special column values. For features (both *Well Known Text* and *Well Known Binary*), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
This project shows how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
The Ecw Sample template represents an ECW file for drawing on the map.
ECW: ECW is a wavelet image compression system developed by ER Mapper.It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales. It is very popular in the GIS community.
[Sample Data Download](http://wiki.thinkgeo.com/wiki/_media/geocoding_hodoisamples_data.zip)
Working…
The Jpeg2000 Sample template represents a .JP2 (JPEG2000) image type to be drawn on the map.
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. In order to run this sample, development build 10.0.0.0 or later is required.
This sample includes a map with MrSID as base overlay, the MrSID shows the image data of the world range.
OpenStreetMap (OSM) is a collaborative project to create free geographic data for the entire world. It can be thought of as a “Free Wiki World Map”. The latest version of MapSuite now supports this.
View this sample on Github ==== Routing Sample for WinForms
<img src=“https://www.iconfinder.com/icons/103529/download/png/20” align=center /> [Sample Data Download](http://wiki.thinkgeo.com/wiki/_media/routing/routing_howdoi_samples_data.zip) ====
Samples
Working…
