This project is an introduction on how to handle some basic principles of caching the map in the Desktop edition. Cache has the advantage of reusing existing images of the map when revising areas of the map that have already have been drawn. When in Snap Up mode for Zoom level snapping, cache is very handy. But it is a recommendable practice to not use it when the Zoom Level snapping mode is set to none because it can have the unintended consequence of generating an almost unlimited number of tiles. This project will be followed by other ones showing more advanced features of caching.
This sample shows how to snap to the grid dots when drawing the shapes on the map. When drawing the shape, the cursor would snap to the closet dot less than a specified tolerance. It may improve the accuracy when drawing some standard shapes.
This sample shows how you can track zoom in. this sample restrict the track zoom shape when press “Shift Key”. The restricted shape is same resolution (width/height) with map. When set the map’s snapping mode to none, the map zooms to specific zoom level without snapping Select the display area with mouse and shift.
