map_suite_desktop_edition_layers_featuresources_samples
Map Suite Desktop Edition Layers & FeatureSources Samples
Combining Overlays
Today’s project is a tool of ENC Viewer for displaying unencrypted Electronic Navigational Charts (ENCs) available in the S-57 exchange format (*.000). This tool takes use of Map Suite HydrographyExtension to display ENC data in compliance with the latest version of ECDIS Presentation Library Edition 4.0, which is defined by the International Hydrographic Organization (IHO) in the special publication S-52.
Combining Overlays
Create GRID
This samples shows how to create GRID files. A GRID is a raster format that defines a geographic space as an array of equally sized squares (cells) arranged in rows and columns. Each cell stores a numeric value that represents an attribute (such as elevation, surface slope, soil pH etc.) for that unit of space. Each GRID cell is referenced by its x, y coordinate location. Typically a GRID file is created based on some sample points with known values. In today’s sample, we take the example of creating a GRID file based on a point based shapefile representing soil pH values of some sample locations in a field. Using the Inverse Weighted Distance algorithm for interpolation, we create the GRID with the pH value for the entire extent of the field. Look at the code and comments for more details on how GRID files get generated and displayed on the map. This sample is a Desktop application but GRID can be used in all the editions of Map Suite.
Edit Attribute Of Shapefile
Edit Geometry Of Shapefile
Edit Grid File in WinForms
This WinForms project demonstrates how you can update a grid shape file using a spatial query. The elements in the file are rendered using ClassBreakStyles, and change when the values of the Features are incremented.
Graphic Logo Adornment Layer
Get Data From Server With WCF
Heat Map
Heat Map with earthquakes
Highlight at Mouse Hover
Image Stream Loading
KML Extension
Latitude Longitude Graticule
Native TAB File Suppport
Numbered Grid
ENC Viewer for displaying S-57 (*.000) File
GPS EXchange Format FeatureLayer
Maritime S57 FeatureLayer
Build Custom Shapefile Indexes
CAD FeatureLayer
TAB FeatureLayer With Embed Style
Compass
File Geodatabase
Video Overview
Hook Up External Data to Shapefile
Isolines
Isolines with Kriging
MapShapes
Notes from the developer:
Mini Map Adornment Layer
Multi Geo Raster Layer
Multi Index
North Arrow
Rotating the map:
Displaying the North Arrow:
Oledb Point FeatureSource
Oledb FeatureSource
Scale Bar
SQLInMemoryLayer
Styles with InMemoryFeatureLayer
Swine Flu
On the web site
Watermark Adornment Layer
WMTS Layer
Zedgraph
LEAD Technologies Inc. V1.01
map_suite_desktop_edition_layers_featuresources_samples.1481753322.txt.gz · Last modified: 2016/12/14 22:08 by tomtaylor
