map_suite_desktop_edition_layers_featuresources_samples
Map Suite Desktop Edition Layers & FeatureSources Samples
Combining Overlays
Today’s project is a tool of ENC Viewer for displaying unencrypted Electronic Navigational Charts (ENCs) available in the S-57 exchange format (*.000). This tool takes use of Map Suite HydrographyExtension to display ENC data in compliance with the latest version of ECDIS Presentation Library Edition 4.0, which is defined by the International Hydrographic Organization (IHO) in the special publication S-52.
Combining Overlays
Create GRID
Edit Attribute Of Shapefile
Edit Geometry Of Shapefile
Graphic Logo Adornment Layer
Create GRID
Get Data From Server With WCF
Heat Map
Heat Map with earthquakes
Highlight at Mouse Hover
Image Stream Loading
KML Extension
Latitude Longitude Graticule
Native TAB File Suppport
Numbered Grid
ENC Viewer for displaying S-57 (*.000) File
GPS EXchange Format FeatureLayer
Maritime S57 FeatureLayer
Build Custom Shapefile Indexes
CAD FeatureLayer
TAB FeatureLayer With Embed Style
Compass
File Geodatabase
Video Overview
Hook Up External Data to Shapefile
Isolines
Isolines with Kriging
MapShapes
Notes from the developer:
Mini Map Adornment Layer
Multi Geo Raster Layer
Multi Index
North Arrow
Rotating the map:
Displaying the North Arrow:
Oledb Point FeatureSource
Oledb FeatureSource
Scale Bar
SQLInMemoryLayer
Styles with InMemoryFeatureLayer
Swine Flu
On the web site
Watermark Adornment Layer
WMTS Layer
Zedgraph
LEAD Technologies Inc. V1.01
map_suite_desktop_edition_layers_featuresources_samples.1443167634.txt.gz · Last modified: 2015/09/25 07:53 by admin
