Sample:Centering And Rotating WPF
In this sample we are going to handle the common case of snapping a point to a set of features in a layer. The common case for this is snapping real-time GPS points to road layers. GPS has an error factor and it's nice to display vehicles on a map snapped to the roads they are on. It can also be used for a number of other different cases as well, such as finding not just the road position but the road name. You may display or store the road name for the trip in your database. In the sample we have set up a road layer; when you click on the map it will find the closest road segment within a tolerance and snap the point to that road. You can click repeatedly around a road and simulate GPS points coming in. Inside of the sample, we have encapsulated the functionality into a method that can easily support multiple layers, varying tolerances, and different data units.
NOAA (National Oceanic and Atmospheric Administration) makes available for the public Radar images http://radar.weather.gov/ridge/Conus/RadarImg/ Those images show the precipitation activities based on the whole range of dBz scale. (see http://en.wikipedia.org/wiki/DBZ_%28meteorology%29) You might want to keep only dBz scales superior to 20 which correspond to actual rain. You might also want to add some transparency to better show the layers below the radar image. This project shows how to filter the image for that purpose. You will see how to create a new filtered image better fit to be displayed on the map. You will find particularly interesting the power of using directly the GDI+ API which is very handy with dealing with a Map Suite GDIPlusRasterLayer.
Sample:Moving Vehicle with Label
