map_suite_desktop_edition_faq_interactiveoverlays
Map Suite Desktop Edition FAQ InteractiveOverlays
Is there a way to abort a track shape that is current drawing?
Sample: Canceling TrackOverlay
This project shows how to implement aborting a trackshape with Esc key as you could do it in MapSuite 2.x. As with Dynamic Info on TrackShape project, it shows how TrackOverlay can be extended to add some custom functionalities. You will see how to handle some events of the map such as KeyDown and how to manipulate TrackOverlay.
How do I override the default behavior of the TrackInteractiveOverlay?
Sample:Custom Track Line
Sample:Custom Track Polygon
How do I prevent a vertex from being dragged within the tolerance of another vertex while editing?
Sample:Vertex Tolerance
How do I save tracked shapes to WKT (Well Known Text)?
Sample:Tracked Shapes to WKT
How do I use the track zoom feature without the shift key?
Sample:Track Zoom In Without Shift
This project is for DesktopEdition users. In Map Suite 2.x, different modes of the map are offered to the developer to choose what kind of behavior the map has at a mouse action. In Map Suite 3.x, we went away from modes to have a more flexible model using InteracticeOverlay. By default, track zoom in is done by clicking and dragging the mouse on the map while holding the Shift key. This is very convenient but what if you want to offer the users the same experience as with 2.x, where the same mouse action has different behavior such as TrackZoomIn and Pan through the use of modes. In this project, we show how to build your own InteractiveOverlay to emulate in Map Suite 3.x the mode behavior 2.x has.
How do I snap vertices while editing?
Sample:Dragged Point Style
How do I add labels to control points while editing?
Sample:Dragged PointStyle with Label
In our series of projects dedicated to EditInteractiveOverlay, today you will see how easy it is to add some labeling to your dragged control point showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the experience of the user, the closest point of the reference shape is also shown varying as the control point is dragged around.
In the GIS field, enterprises have different needs on how they edit there data and on how smooth the editing should be allowing the maximum control and precision to the technician editing the data. This example on how to use the EditInteractiveOverlay demonstrates how powerful and flexible editing is with Map Suite map control.
How do I drag and drop icons on the map?
Sample:Dragging Icon
Sample:Dragging Icon Advanced
How do I enable snapping while editing?
Sample:Snap To Layer
Sample:Snapping to Vertex
Sample:Snapping to Layer2
The purpose of this Wpf project is to address some limitations of the class SnapToLayerEditInteractiveOverlay found in a previous sample Snap To Layer. This class allowed the snapping of the mouse pointer to the closest vertex of a polygon if it is within a set tolerance. While this worked great for simple polygons, there was a performance limitation with complex polygons made of many vertices. This Wpf sample addresses this limitation and allows responsive dragging and snapping of vertex regardless of the size of polygon to snap to.
How do I display dynamic information as track shapes are being drawn?
Sample:Dynamic Info On TrackShapes
In this example, you will see displayed in a groupbox, properties such as perimeter and area as the shape is being tracked. In this project, you will learn how to handle events such as TrackStarted, MouseMoved and TrackEnded of TrackOverlay for that purpose. Getting dynamic info of a shape being tracked can be handy in situation where before committing to get the completed shape, you want to know more about the shape. For example, if you are tracking a search zone, you get dynamically info about its area. This project will be followed by other related projects. One will show how to create one’s own inherited TrackOverlay for having the possibility to abort tracking by pressing a key. Another project will show how to display dynamic info inside the shape itself instead of using a separate control.
How do I allow users to edit rectangles?
Sample:Editing Rectangles
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes rather than polygon shapes by setting special column values. For features (Well Known Text and Binary), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
To activate the feature, you need to assign the value of the column called “Edit” to “rectangle”. The resize function will keep the ratio of width and height of the rectangle, otherwise it will use the original method. For more information you can see the discussion forum post below: http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5822/afv/topic/Default.aspx
Sample:EditOverlay Styles
How do I select features from a layer based on a user drawn track shape?
Sample:Select with Track Shape
How do I allow you to drag features based on a column value?
Sample:Select and Drag(wpf)
How do I measure a given distance using a custom ruler?
Sample:Ruler Overlay
In this Desktop project, you will learn how to extend the TrackInteractiveOverlay to create a ruler to dynamically measure the distance by tracking a line. The user needs to click and drag to see the line and distance changing just as for using a ruler. You can look the inherited RulerTrackInteractiveOverlay class to see how it was extented from TrackInteractiveOverlay.
What should be the standard size of the illustrating picture?
Sample:Select Vertices
How do I Drag/Select Vertices As Group?
Sample:Drag Select Vertices As Group
With EditInteractiveOverlay, we know how to drag a feature such as polygon as a whole. We also know how to drag an individual vertex by setting the appropriate properties. Here we go a little further and we show how to create an inherited class from EditInteractiveOverlay to implement the logic for selecting vertices and dragging them as a group. See how the protected methods MouseDownCore, MouseUpCore, MouseClickCore and MouseMoveCore were overridden for that purpose. This is a Desktop app that also applies to Wpf.
How to track Shapes to File?
Sample:Tracked Shapes to File
How to preset Vertex To Tracked Polygon?
Sample:Preset Vertex To Tracked Polygon
map_suite_desktop_edition_faq_interactiveoverlays.txt · Last modified: 2015/09/08 08:50 by admin
