The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in both C# and VB.NET, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
Today we have the Desktop version of the Web project “GPS to Google”. In this project, we show how to display on Google Map point data coming from some GPS reading in Geodetic (Longitude/Latitude). It also shows how to set the extent of the map so that it is centered on the GPS point.
Video Walkthrough
As with Dynamic Info on TrackShape project, it shows how TrackOverlay can be extended to add some custom functionalities.
You will see how to handle some events of the map such as KeyDown and how to manipulate TrackOverlay.
With EditInteractiveOverlay, we know how to drag a feature such as polygon as a whole. We also know how to drag an individual vertex by setting the appropriate properties. Here we go a little further and we show how to create an inherited class from EditInteractiveOverlay to implement the logic for selecting vertices and dragging them as a group. See how the protected methods MouseDownCore, MouseUpCore, MouseClickCore and MouseMoveCore were overridden for that purpose. This is a Desktop app that also applies to Wpf.
This project is another example of how extendible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key and have the vertex snap to any feature. Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can be easily implemented by inheriting from EditInteractiveOverlay.
In our series of projects dedicated to EditInteractiveOverlay, today you will see how easy it is to add some labeling to your dragged control point showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the experience of the user, the closest point of the reference shape is also shown varying as the control point is dragged around.
In the GIS field, enterprises have different needs on how they edit there data and on how smooth the editing should be allowing the maximum control and precision to the technician editing the data. This example on how to use the EditInteractiveOverlay demonstrates how powerful and flexible editing is with Map Suite map control.
The purpose of today’s project is not so much as show a new technology as to show an improvement in an existing one. We are already familiar with EditInteractiveOverlay with projects such as “Dragged PointStyle with Label”, “Snap To Layer” and “Snapping to Vertex”. But those projects showed EditInteractiveOverlay on small shapes. Using EditIntercticeOverlay on complex shapes became not very responsive. We improved that and now you can drag, resize, rotate and drag individual vertex of a complex polygon made of thousand of vertices with good responsiveness as you can see in this example.
To run this Desktop project, you will need the version 4.0.66.0 or later of the development daily build for MapSuiteCore and DesktopEdition dlls. And do not forget to add a reference to WindowsBase.dll.
This improvement is currently only in the development branch, it will be added to the production branch at the next major release in November.
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes rather than polygon shapes by setting special column values. For features (Well Known Text and Binary), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
To activate the feature, you need to assign the value of the column called “Edit” to “rectangle”. The resize function will keep the ratio of width and height of the rectangle, otherwise it will use the original method.
http://gis.thinkgeo.com/Support/DiscussionForums/tabid/143/aff/21/aft/5822/afv/topic/Default.aspx
In this Desktop project, you will learn how to extend the TrackInteractiveOverlay to create a ruler to dynamically measure the distance by tracking a line. The user needs to click and drag to see the line and distance changing just as for using a ruler. You can look the inherited RulerTrackInteractiveOverlay class to see how it was extented from TrackInteractiveOverlay.
This project is meant to respond to a limitation with aborting tracking a shape in the project TrackOverlay with Esc. Now we can abort the tracked shape from the first vertex being added. Notice how we used a new class CustomTrackInteractiveOverlay inheriting from TrackInteractiveOverlay for this purpose.
This sample shows how you can display multiple labels for a given point or feature. You can do this by setting a single TextStyle or multiple TextStyles. If you use a single TextStyle, you can simply use a pattern like “[ColumnName1][ColumnName2]” and when Map Suite displays the text it will combine the values of the columns in your pattern. If you use a different styling method, you will need to manually control the offset of each piece of text to avoid overlapping.
Today’s project is a tool of ENC Viewer for displaying unencrypted Electronic Navigational Charts (ENCs) available in the S-57 exchange format (*.000). This tool takes use of Map Suite HydrographyExtension to display ENC data in compliance with the latest version of ECDIS Presentation Library Edition 4.0, which is defined by the International Hydrographic Organization (IHO) in the special publication S-52.
This samples shows how to create GRID files. A GRID is a raster format that defines a geographic space as an array of equally sized squares (cells) arranged in rows and columns. Each cell stores a numeric value that represents an attribute (such as elevation, surface slope, soil pH etc.) for that unit of space. Each GRID cell is referenced by its x, y coordinate location. Typically a GRID file is created based on some sample points with known values. In today’s sample, we take the example of creating a GRID file based on a point based shapefile representing soil pH values of some sample locations in a field. Using the Inverse Weighted Distance algorithm for interpolation, we create the GRID with the pH value for the entire extent of the field. Look at the code and comments for more details on how GRID files get generated and displayed on the map. This sample is a Desktop application but GRID can be used in all the editions of Map Suite.
This WinForms project demonstrates how you can update a grid shape file using a spatial query. The elements in the file are rendered using ClassBreakStyles, and change when the values of the Features are incremented.
This is available in MapSuite Version 9.0.539.0 and later.
Video Overview
Notes from the developer:
Rotating the map:
Displaying the North Arrow:
On the web site
This project is an introduction on how to handle some basic principles of caching the map in the Desktop edition. Cache has the advantage of reusing existing images of the map when revising areas of the map that have already have been drawn. When in Snap Up mode for Zoom level snapping, cache is very handy. But it is a recommendable practice to not use it when the Zoom Level snapping mode is set to none because it can have the unintended consequence of generating an almost unlimited number of tiles. This project will be followed by other ones showing more advanced features of caching.
This sample shows you how to improve drawing accuracy. When drawing a shape on the map it allows you to snap to the closest grid item based on a specified tolerance.
This sample shows how you can track zoom in. this sample restrict the track zoom shape when press “Shift Key”. The restricted shape is same resolution (width/height) with map. When set the map’s snapping mode to none, the map zooms to specific zoom level without snapping Select the display area with mouse and shift.
This sample shows how to use the method GetFeaturesWithDistanceOf when the data is projected. We just input the unit which is projected to, do not need to mind what the real unit is for the internal data before projection. It works fine with Map Suite Assemblies 4.5.54.0 or later.
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinate needs to be set so that the feature get selected within a constant distance in screen coordinate to where the user clicked on regardless on the zoom level. This project will show how to accomplish that task regardless of the layer type (polygon, line or point based) and the zoom level of the current extent of the map. This is a Desktop project.
From the Performance Guide:
In today’s project, we learn how to extend InMemoryFeatureLayer to have the ability to display animated gif for each layer in the Desktop edition. You will notice that for now, we are limited to have one animated gif per InMemoryFeatureLayer but in the future, we will show the technique to have a different animated gif for each feature of the InMemoryFeatureLayer.
In today’s project, we are seeing a variant of the sample “Traveling Salesman Problem” of the “How Do I” samples of the Routing product. At the request of a Discussion Forum user, we added a new API to the GetRouteViaVisitStops function where now you can have distinct start and end points. For being able to run this app, you will need the version 6.0.0.0 or later.
This WinForms project demonstrates how you can update a grid shape file using a spatial query. The elements in the file are rendered using ClassBreakStyles, and change when the values of the Features are incremented.
