map_suite_deployment_guide_common_dependencies_overview
Map_Suite_Deployment_Guide_Common_Dependencies_Overview
Libraries Required for Satellite Imagery in 32 bit system. (Must be in the SYSTEMROOT) *Map Suite 6.0\MapSuiteGeoRasterx86\lti_dsdk_dll.dll *Map Suite 6.0\MapSuiteGeoRasterx86\MapSuiteEcwX86.DLL *Map Suite 6.0\MapSuiteGeoRasterx86\MapSuiteGeoRasterX86.dll *Map Suite 6.0\MapSuiteGeoRasterx86\MapSuiteMrSidsX86.DLL *msvcp71.dll *msvcr71.dll *Map Suite 6.0\MapSuiteGeoRasterx86\NCScnet.dll *Map Suite 6.0\MapSuiteGeoRasterx86\NCSEcw.dll *Map Suite 6.0\MapSuiteGeoRasterx86\NCSUtil.dll
Libraries Required for Satellite Imagery in 64 bit system. (Must be in the SYSTEMROOT) *Map Suite 6.0\MapSuiteGeoRasterx64\lti_dsdk_dll.dll *Map Suite 6.0\MapSuiteGeoRasterx64\MapSuiteEcwX64.DLL *Map Suite 6.0\MapSuiteGeoRasterx64\MapSuiteGeoRasterX64.dll *Map Suite 6.0\MapSuiteGeoRasterx64\MapSuiteMrSidsX64.DLL *msvcp71.dll *msvcr71.dll *Map Suite 6.0\MapSuiteGeoRasterx64\NCScnet.dll *Map Suite 6.0\MapSuiteGeoRasterx64\NCSEcw.dll *Map Suite 6.0\MapSuiteGeoRasterx64\NCSUtil.dll
Libraries for Postgre Support *Npgsql.dll *PostgreSpatialExtension.dll
Libraries for Zedgraph Support *ZedGraph.dll *ZedgraphStyleExtension.dll
Libraries for Projection Support. (Must be in the SYSTEMROOT) *Map Suite 6.0\MapSuiteProjectionX64.dll *Map Suite 6.0\MapSuiteProjectionX86.dll *Map Suite 6.0\Proj4ExtensionX64.dll *Map Suite 6.0\Proj4ExtensionX86.dll
Libraries for GeoTiff Support. (Must be in the SYSTEMROOT) *Map Suite 6.0\TiffWrapperX86.dll *Map Suite 6.0\TiffWrapperX64.dll *Map Suite 6.0\MapSuiteRasterTiffX86.dll *Map Suite 6.0\MapSuiteRasterTiffX64.dll
Data Folder For Prj/Proj4 Conversion Support.(Must be in the SYSTEMROOT) *Map Suite 6.0\MapSuitePrjHelper
Libaries for Fdo Data Feature Support.(The whole folder must be copied to the SYSTEMROOT\) *Map Suite 6.0\MapSuiteFdoExtensionX86\ *Map Suite 6.0\MapSuiteFdoExtensionX64\
ShapeFileFeatureSource.ExecuteQuery function isn’t supported for 64 bit system, because the Microsoft.Jet.OLEDB 4.0 isn’t supported on a 64 bit system.
In Development Branch, the dependencies under SYSTEMROOT Folders are updated to meet the latest changes, as following: Libraries Required for all the products. (Must be in the SYSTEMROOT) *SqlServerSpatial110.dll* Libraries Required for Satellite Imagery support. (Must be in the SYSTEMROOT) *Map Suite 6.0\GeoRasterX86\GeoRasterWrapperX86.dll *Map Suite 6.0\GeoRasterX86\lti_dsdk.dll *Map Suite 6.0\GeoRasterX86\lti_dsdk_cdll.dll *Map Suite 6.0\GeoRasterX86\lti_lidar_dsdk.dll *Map Suite 6.0\GeoRasterX86\NCScnet4.dll *Map Suite 6.0\GeoRasterX86\NCSEcw4_RO.dll *Map Suite 6.0\GeoRasterX86\NCSUtil4.dll *Map Suite 6.0\GeoRasterX86\tbb.dll *Map Suite 6.0\GeoRasterX64\GeoRasterWrapperX86.dll *Map Suite 6.0\GeoRasterX64\lti_dsdk.dll *Map Suite 6.0\GeoRasterX64\lti_dsdk_cdll.dll *Map Suite 6.0\GeoRasterX64\lti_lidar_dsdk.dll *Map Suite 6.0\GeoRasterX64\NCScnet4.dll *Map Suite 6.0\GeoRasterX64\NCSEcw4_RO.dll *Map Suite 6.0\GeoRasterX64\NCSUtil4.dll *Map Suite 6.0\GeoRasterX64\tbb.dll Libraries Required for Raster Projection. (Must be in the SYSTEMROOT) *Map Suite 6.0\GeoRasterProjectionX86\GeoRasterProjectionWrapperX64.dll *Map Suite 6.0\GeoRasterProjectionX86\gdal19.dll *Map Suite 6.0\GeoRasterProjectionX86\proj.dll *Map Suite 6.0\GeoRasterProjectionX64\GeoRasterProjectionWrapperX64.dll *Map Suite 6.0\GeoRasterProjectionX64\gdal19.dll *Map Suite 6.0\GeoRasterProjectionX64\proj.dll Libraries Required for Projection Support. (Must be in the SYSTEMROOT) *Map Suite 6.0\Proj4X64.dll *Map Suite 6.0\Proj4X86.dll Libraries Required for GeoTiff Support. (Must be in the SYSTEMROOT) *Map Suite 6.0\GeoTiffX86.dll *Map Suite 6.0\GeoTiffX64.dll Libraries Required for File GeoDatabase Support. (Must be in the SYSTEMROOT)* *Map Suite 6.0\FileGeoDatabaseX86\Esri.FileGDBAPI.dll *Map Suite 6.0\FileGeoDatabaseX86\FileGDBAPI.dll *Map Suite 6.0\FileGeoDatabaseX86\FileGDBAPID.dll *Map Suite 6.0\FileGeoDatabaseX86\FileGdbApiWrapperX86.dll *Map Suite 6.0\FileGeoDatabaseX64\Esri.FileGDBAPI.dll *Map Suite 6.0\FileGeoDatabaseX64\FileGDBAPI.dll *Map Suite 6.0\FileGeoDatabaseX64\FileGDBAPID.dll *Map Suite 6.0\FileGeoDatabaseX64\FileGdbApiWrapperX64.dll Libaries for Fdo Data Feature Support.(The whole folder must be copied to the SYSTEMROOT\) *Map Suite 6.0\MapSuiteFdoExtensionX86\ *Map Suite 6.0\MapSuiteFdoExtensionX64\ * From Build 6.0.35.0 in Development Branch SqlServerSpatial110.dll should be deployed accordingly under different circumstances. :Case 1: On an X86 system. ::The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\System32” folder. :Case 2: Running under X64 mode on an X64 system, ::The X64 version of SqlServerSpatial110.dll (under SqlServerTypes_X64 folder) needs to be copied to “c:\Windows\System32” :Case 3: Running under X86 mode on an X64 system. ::The X86 version of SqlServerSpatial110.dll (under SqlServerTypes_X86 folder) needs to be copied to “c:\Windows\SysWOW64” folder. From 6.0.35.0 in Development Branch, Microsoft VC 10 Runtime is required. You can install it by using the merge modules listed above, or install Microsoft's package directly from http://www.microsoft.com/en-us/download/details.aspx?id=5555 (X86) and http://www.microsoft.com/en-us/download/details.aspx?id=14632 (X64). From Build 6.0.92.0 in Development Branch
* From Build 6.0.103.0 in Development Branch From Build 6.0.159.0 in Development Branch The new Fdo dll package can be downloaded here: http://wiki.thinkgeo.com/wiki/File:MapSuiteFdoExtension2012-10-26.zip Note:** 1, Map Suite Development Branch products support both of the above dependencies structure. 2, From 6.0.100.0 in Development Branch, “Setup Unmanaged Dependencies.msi” is included in the daily build to help the user easily setup the environment.
map_suite_deployment_guide_common_dependencies_overview.1440040123.txt.gz · Last modified: 2015/09/21 02:12 (external edit)
