map_suite_core_10.6_features_bug_fixes_change_log
ThinkGeo.MapSuite Namespace:
  • Enhanced to support reprojection for Wmts.
  • Enhanced to support high resolution screen for ThinkGeoCloudRasterMapsLayer.
  • Enhanced to support high resolution screen for GoogleMapsLayer.
  • Fixed a bug that GoogleMapsLayer renders incorrect tiles when map extent is out of max extent of Google.
  • Fixed a bug that WmtsLayer can't serialize.
  • Fixed a bug that the projection don't works when FeatureSource is editing and IsTransactionLive of ShapeFileFeatureLayer is true.
  • Fixed a bug that Fdo doesn't work on the x64 target platform.
  • Fixed a bug that FikeGeoDatabase doesn't work on the x64 target platform.
  • Changed DrawingPointStyleEventArgs to DrawingDirectionPointEventArgs.
  • Added DirectionPointStyle property for LineStyline.
  • Enhanced to support ZoomLevel20 for ThinkGeoCloudMapsZoomLevelSet.
  • Improved render performance for OpenStreetMap.
  • Fixed a bug that the PDF and the Printer get different result with the Map if polygon contains inner rings.
  • Enhanced to support GeoLinearGradientBrush for Printer.
  • Enhanced to support GeoLinearGradientBrush in PDF.
  • Fixed a bug that the Direction convert to incorrect Angle in GeoLinearGradientBrush.
  • Fixed a bug. When parsing tile format tiff image, throws “Array index is out of range” exception.
  • Fixed a bug that cache expired don't works again because we need compare the UTC dateTime.
  • Enhanced to support rotation text for Cad.
  • Fixed a bug that raster layer is unmatched with vector layer when printing.
  • Fixed a bug that the projection '90091' srid can't be found from Esri projectin list.
  • Fixed a bug that GeoTiff will jump when reprojection.
  • Improved S57 index building performance.
  • Fixed a bug. When Setting the IsActive of specified zoomlevel to false, map still draw the shape follow the style of other zoomlevel.
  • Fixed a bug that QueryTool doesn't work.
  • Fixed a bug that the label is rendered at incorrect position under different DPI.
  • Improved render performance for NauticalChartsFeatureLayer.
  • Fixed a bug that RotationAngle of PointStyle doesn't work when printing map.
  • Fixed a bug resouce files of LegendAdornmentLayer can't be found.
  • Fixed a bug that zooming to deeper than level 20 OpenStreetMapsLayer throws a exception.
map_suite_core_10.6_features_bug_fixes_change_log.txt · Last modified: 2019/12/06 01:42 by tgwikiupdate
