This is the derived class of the class DbfMatchingPlugIn for matching Census Block areas.
This is the derived class of the class DbfMatchingPlugIn for matching Census Block Group areas.
This is the derived class of the class DbfMatchingPlugIn for matching Census Tracts.
This is the derived class of the class DbfMatchingPlugIn for matching counties.
This class is the derived class of the MatchingPlugin class for matching street addresses.
This class is the derived class of the MatchingPlugin class for matching IP addresses.
This is the derived class of the class MatchingPlugIn for matching PostCode.
This class implements soundex matching operations. There are two columns in the DBF file that are necessary for soundex matching. The first is the soundex value generated by certain Soundex algorithms (by default this is implemented by SimplifiedSoundex). The second is the exact value.
This class is the derived class of the class DbfMatchingPlugIn for matching states.
This class encapsulates the matching operations in a DBF dataset. This class provides functions for creating and adding records and matching for DBF index files. The DBF file could contain one key column whose column name starts with “ID_” and additional columns whose column names start with “DT_”. Each DBF file should also contain two columns named “BB_CX” and “BB_CY”, which represent the longitude and latitude. If there is bounding box information, it should consist of four columns: “BB_ULX”, “BB_ULY”, “BB_LRX”, “BB_LRY” representing upper left X, upper left Y, lower right X and lower right Y. To take advantange of binary searching, records should be sorted before insertion into the DBF file.
This class is the abstract class encapsulating matching operations. The MatchingPlugIn class is the key class in the Geocoding. It formalizes the source text using GeocoderFormalizer, tries to match in some kinds of datasets and returns a MatchResult object. MatchingPlugIn can work independently or can be combined to work together with others to accomplish complicated matching requirements.
This class implements coordinate matching functions. The CoordinatesMatchingPlugin uses serveral DBF and R-Tree index files to accomplish matching operations. street.dbf: Contains non-geographic information for streets. rt2.dbf: Contains coordinate information for streets. tlid.dbf: Contains street TIGER line ID (TLID) and index in street.dbf. Sorted by TLID. zip.dbf: Contains zip code information. rt2.ids and rt2.idx: R-Tree index files for streets by zip.
This is the derived class from the Soundex class which implements a simplfied soundex algorithm.
This class is a concrete class inherits from BitmapTileCache. In this class, the tiles will be saved in memory and it provides some properties to control it very easily.
This is the base class for NativeTileCache system which inherits from TileCache class.
This class represents a NativeImageTile, which is defined as scale, RectangleBox and a byte array for its tile bitmap.
This is the event arguments class for the AdornmentLayersDrawn event. It is raised after all of the AdornmentLayers have been drawn.
This class represents a routing algorithm that is based on the Bidirectional algorithm.
This class represents the parameters passed out through the FindingServiceArea event.
This class represents the parameters passed out through the GettingTspVisitRoute event.
This layer can show start coordinates, end coordinates, a collection of in-between stops and the resulting paths with specified styles.
This class represents the result of routing. RoutingResult is the roads collection consisting of the route, turn-by-turn directions and other information like total distance and route path.
This class represents the parameters passed out through the FindingRoute event.
This class represents the parameters passed out through the BuildingRoutingData event.
This class represents a routing algorithm that is based on the Dijkstra algorithm.
This class represents the parameters passed in through the CreatedMemberNode event.
This class represents the parameters passed in through the CreatingMemberObject event.
Indicates how the default value of a member will be dealt with by the modeler.
When applied to a method, specifies that the method is called after serialization of an object graph.
When applied to a method, specifies that the method is called before serialization of an object.
