map_suite_api
Map Suite Api
ThinkGeo.MapSuite
ThinkGeo.MapSuite.Cogo
ThinkGeo.MapSuite.Drawing
  • PlatformGeoCanvas
    WindowsLinuxMacAndroidiOS
    This class represents a canvas that is used to draw geographic shapes with GDI+.
  • GeoBrush
  • GeoCanvas
  • GeoFont
    This class represents a font that is used to label features on a GeoCanvas.
  • GeoPen
    This class represents a GeoPen, which is used to draw lines on a GeoCanvas.
  • DrawingFontStyles
    This enumeration specifies the type of font style for drawing text.
  • DrawingGraphicsUnit
    This enumeration represents the graphics unit.
  • DrawingLevel
    This enumeration represents the drawing level used in the GeoCanvas.
  • DrawingLineCap
  • DrawingLineJoin
    This enumeration specifies how to join consecutive line or curve segments.
  • DrawingPenAlignment
  • DrawingQuality
    This enumeration specifies the drawing quality of the GeoCanvas.
  • GeoBrushes
    Provides a collection of predefined GeoBrushes
  • GeoColor
  • GeoColors
    This class is a collection of predefined colors
  • GeoDashCap
  • GeographicColors
    This class is a convenient way to access a predefined set of geographic colors.
  • GeoHatchBrush
    This class represents a brush that fills with various patterns.
  • GeoHatchStyle
  • GeoLinearGradientBrush
  • GeoLinearGradientDirection
    Specifies the direction of a linear gradient.
  • GeoPens
    Provides a collection of predefined GeoPens
  • GeoSolidBrush
  • GeoTextureBrush
  • GeoWrapMode
  • LineDashStyle
    This enumeration specifies the style of dashed lines drawn with a GeoPen object.
  • PenBrushDrawingOrder
    This enumeration determines whether the brush or the pen draws first.
  • RandomColorType
    Defines values represent which kind of color will use for randomly.
  • SimpleColors
    This class is a convenient way to access a predefined set of simple colors.
  • StandardColors
    This class is a convenient way to access a predefined set of standard colors.
ThinkGeo.MapSuite.Geocoding
  • DbfMatchingPluginReadWriteMode
    WindowsLinuxMac
    The ReadWrite mode for DbfMatingPlugin.
  • MatchMode
    WindowsLinuxMac
    This enumeration defines two kinds of match status.
  • CensusBlockDbfMatchingPlugin
    WindowsLinuxMac
    This is the derived class of the class DbfMatchingPlugIn for matching Census Block areas.
  • CensusBlockGroupDbfMatchingPlugin
    WindowsLinuxMac
    This is the derived class of the class DbfMatchingPlugIn for matching Census Block Group areas.
  • CensusTractsDbfMatchingPlugin
    WindowsLinuxMac
    This is the derived class of the class DbfMatchingPlugIn for matching Census Tracts.
  • CountyDbfMatchingPlugin
    WindowsLinuxMac
    This is the derived class of the class DbfMatchingPlugIn for matching counties.
  • CustomStreetMatchingPlugin
    WindowsLinuxMac
    This class is the derived class of the MatchingPlugin class for matching street addresses.
  • IPAddressMatchingPlugin
    WindowsLinuxMac
    This class is the derived class of the MatchingPlugin class for matching IP addresses.
  • PostcodeDbfMatchingPlugin
    WindowsLinuxMac
    This is the derived class of the class MatchingPlugIn for matching PostCode.
  • SoundexDbfMatchingPlugin
    WindowsLinuxMac
    This class implements soundex matching operations. There are two columns in the DBF file that are necessary for soundex matching. The first is the soundex value generated by certain Soundex algorithms (by default this is implemented by SimplifiedSoundex). The second is the exact value.
  • CityDbfMatchingPlugin
    WindowsLinuxMac
    This is the derived class of the class DbfMatchingPlugIn for matching cities.
  • StateDbfMatchingPlugin
    WindowsLinuxMac
    This class is the derived class of the class DbfMatchingPlugIn for matching states.
  • ZipDbfMatchingPlugin
    WindowsLinuxMac
    This class implements functions for matching zip codes.
  • DbfMatchingPluginColumn
    WindowsLinuxMac
    This structure represents the DBF column definition.
  • DbfMatchingPluginColumnType
    WindowsLinuxMac
    This enumeration represents the column type in the DBF.
  • StreamLoadingEventArgs
    WindowsLinuxMac
    This class represents the event arguments for the StreamLoading event.
  • Geocoder
    WindowsLinuxMac
    This class is the base class for Geocoding.
  • GeocoderMatch
    WindowsLinuxMac
    This class represents single match result.
  • DbfMatchingPlugin
    WindowsLinuxMac
    This class encapsulates the matching operations in a DBF dataset. This class provides functions for creating and adding records and matching for DBF index files. The DBF file could contain one key column whose column name starts with “ID_” and additional columns whose column names start with “DT_”. Each DBF file should also contain two columns named “BB_CX” and “BB_CY”, which represent the longitude and latitude. If there is bounding box information, it should consist of four columns: “BB_ULX”, “BB_ULY”, “BB_LRX”, “BB_LRY” representing upper left X, upper left Y, lower right X and lower right Y. To take advantange of binary searching, records should be sorted before insertion into the DBF file.
  • MatchingPlugin
    WindowsLinuxMac
    This class is the abstract class encapsulating matching operations. The MatchingPlugIn class is the key class in the Geocoding. It formalizes the source text using GeocoderFormalizer, tries to match in some kinds of datasets and returns a MatchResult object. MatchingPlugIn can work independently or can be combined to work together with others to accomplish complicated matching requirements.
  • CoordinatesMatchingPlugin
    WindowsLinuxMac
    This class implements coordinate matching functions. The CoordinatesMatchingPlugin uses serveral DBF and R-Tree index files to accomplish matching operations. street.dbf: Contains non-geographic information for streets. rt2.dbf: Contains coordinate information for streets. tlid.dbf: Contains street TIGER line ID (TLID) and index in street.dbf. Sorted by TLID. zip.dbf: Contains zip code information. rt2.ids and rt2.idx: R-Tree index files for streets by zip.
  • StreetMatchingPlugin
    WindowsLinuxMac
  • SimplifiedSoundex
    WindowsLinuxMac
    This is the derived class from the Soundex class which implements a simplfied soundex algorithm.
  • Soundex
    WindowsLinuxMac
    This class is the abstract class for Soundex algorithm.
  • UsaGeocoder
    WindowsLinuxMac
    This class is for United States Geocoding.
ThinkGeo.MapSuite.Jeffersonian
ThinkGeo.MapSuite.Layers
ThinkGeo.MapSuite.Portable
ThinkGeo.MapSuite.Routing
ThinkGeo.MapSuite.Serialize
ThinkGeo.MapSuite.Shapes
  • AreaBaseShape
  • BaseShape
    The abstract class from which area shapes, line shapes, and point shapes inherit from.
  • LineBaseShape
  • PointBaseShape
  • AreaUnit
    Units describing various ways you can measure areas.
  • BufferCapType
  • Conversion
    This static class provides a conversion method to go to and from different units.
  • DecimalDegreesHelper
  • DegreesMinutesSeconds
    This structure represents a degrees, minutes and seconds value.
  • DistanceUnit
    Units describing various ways you can measure lengths.
  • DrawingRectangle
    This structure represents the drawing of a rectangle in screen coordinates.
  • DrawingRectangleF
  • EllipseShape
  • Feature
  • LineShape
  • MultilineShape
  • MultipointShape
    This class represents one or more point shapes.
  • MultipolygonShape
  • PanDirection
    This enumeration defines panning directions.
  • PointShape
  • PolygonShape
  • Proj4Projection
  • Projection
  • RectangleShape
  • ReturningColumnsType
    This enumeration provides some options when querying a feature.
  • RingShape
    This class represents a closed ring of points.
  • ScreenPoint
  • ScreenPointF
  • ShapeValidationMode
    This enumeration describes the type of validation test to run on shapes.
  • ShapeValidationResult
  • ExtentHelper
    This static class exposes a number of helpful methods when dealing with extents.
  • MapResizeMode
    The enumeration represents which mode will use for map resize.
  • SimplificationType
    Specifies which algorthm will be use to simplify.
  • StartingPoint
    An enumeration describing the place to start on a line when doing certain operations.
  • Vertex
  • WellKnownType
    This describes a set of enumerations that list the valid types of geometries.
  • WkbByteOrder
    This enumeration represents the byte order that well-known binary will be written in.
ThinkGeo.MapSuite.Styles
map_suite_api.1483065844.txt.gz · Last modified: 2016/12/30 02:44 (external edit)
