map_suite_android_edition_quick_start_guide
Map Suite Android Edition Quick Start Guide
The Map Suite Android Edition illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Android Edition 9.0.0.0 and higher, and will show you how to create an Android application using Map Suite Android Edition.
If you want to build an iOS application using the standard Map Suite iOS Edition product, please see the iOS QuickStart Guide instead.
Before we get started, make sure you've installed the ThinkGeo Product Center and that you've either started an evaluation or activated a full license of Map Suite Android Edition. By default, this will install the Map Suite Android Edition 9.0 assemblies to C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Android.
Download the Sample
Setting up the Environment
Please follow our Android Edition Installation Guide for Xamarin Android development environment.
Let's start by creating a new Android project in Microsoft Visual Studio (2012 or newer) named HelloWorld (see Figure 1). We can create the project with .NET Framework 4.5.
The project HelloWorld is created in a new solution called HelloWorld. The wizard creates a single Android Application. Choose Android version (4.0.3 or higher) for the project:
Next we need to prepare our map data. There are two ways to copy data to phone or tablet. The first way is using android ddms tool. We can find the tool under “android-sdk\tools\ddms.bat”.
Create a new folder under sdcard named “Android Sample”.
One is under our application, like “/data/data/HelloWorld.HelloWorld/AppData/”.
protected override void OnCreate(Bundle bundle)
    base.OnCreate(bundle);
    SetContentView(Resource.Layout.Main);
    // Copy the required Shapefiles to Device.
    string targetDirectory = (@"/mnt/sdcard/Android.Sample/GetStarted/");
    CopySampleData(targetDirectory);
This method will copy data to the target path, if the folder does not exist. Foo|Error
private void CopySampleData(string targetDirectory)
	if (!Directory.Exists(targetDirectory))
		Directory.CreateDirectory(targetDirectory);
		foreach (string filename in Assets.List("AppData"))
			Stream stream = Assets.Open("AppData/" + filename);
			FileStream fileStream = File.Create(Path.Combine(targetDirectory, filename));
			stream.CopyTo(fileStream);
			fileStream.Close();
			stream.Close();
Adding the Map View to our App
We need to add ProtableCore.dll and AndroidEdition.dll to the references. Right-click the Reference in Solution Explorer and select “Add Reference”, navigate to the C:\Program Files (x86)\ThinkGeo\Map Suite 9.0\Map Suite Android\Current Version\Managed Assemblies folder, and select “MapSuitePortableCore.dll” and “AndroidEdition.dll”.
Note: Although it is not a ThinkGeo assembly, you also need to add “System.Windows.dll ” to the references. System.Windows can be found on the .NET tab of the Add Reference dialog. If you don't do this, you will get the following error when you compile the project:“The type 'System.Collections.Specialized.INotifyCollectionChanged' is defined in an assembly that is not referenced. You must add a reference to assembly 'System.Windows, Version=2.0.5.0, Culture=neutral, PublicKeyToken=7cec85d7bea7798e, Retargetable=Yes'.”
<?xml version="1.0" encoding="utf-8"?>
<LinearLayout xmlns:android="http://schemas.android.com/apk/res/android"
    android:orientation="vertical"
    android:layout_width="fill_parent"
    android:layout_height="fill_parent">
    <thinkgeo.mapsuite.androidedition.MapView
        android:id="@+id/MapView"
        android:layout_height="fill_parent"/>
</LinearLayout>
Now we have our “AndroidEdition.dll” and “MapSuitePortableCore.dll” referenced and a MapView added.
Map Suite Android "Hello World" Sample
The first step in creating our “Hello World” sample application is to set references to the MapSuite.Core and MapSuite.AndroidEdition workspaces at the very top of our code, since we'll use many classes within them. Set the reference like this:
using ThinkGeo.MapSuite.Core;
using ThinkGeo.MapSuite.AndroidEdition;
Display World Map
Now, Let's add a base overlay to display the world map witch called “WorldMapKitOverlay”.
    // Get MapView From Activity's View.
    MapView mapView = FindViewById<MapView>(Resource.Id.MapView);
    // Set the Map Unit to DecimalDegrees, the Shapefile’s unit of measure.
    mapView.MapUnit = GeographyUnit.DecimalDegree;
    // Create a WorldMapKitOverlay.
    WorldMapKitOverlay worldMapKitOverlay = new WorldMapKitOverlay();
    // Add a WorldMapKitOverlay.
    mapView.Overlays.Add("WorldMapKit", worldMapKitOverlay);
    // Set a proper extent for the map. The extent is the geographical area you want it to display.
    mapView.CurrentExtent = new RectangleShape(5, 78, 30, 26);
Figure 3. A simple map of Europe.
Shapefiles
Map Suite Android Edition 9.0 supports multiple kinds of data sources. Here we will provide an introduction to Shapefiles, which we will use in this Quick Start Guide.
ShapeFileFeatureLayers
Map
Styles
PresetZoomLevels
worldLayer.ZoomLevelSet.ZoomLevel03.DefaultAreaStyle = AreaStyles.Country1;
worldLayer.ZoomLevelSet.ZoomLevel03.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level10;
Display Countries On Map
  • Worldwide country borders (Countries02.shp)
Our next step is to define and add our layers. All of our sample code is placed in the OnCreate method of the MainActivity.cs. So our MapView can load and render the data, we can add logic to check the data to avoid coping it every time.
    // Copy the required shapefiles to Device.
    ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "cntry02.shp"));
    // Set the worldLayer with a preset Style, as AreaStyles.Country1 has a YellowGreen background and black border, our worldLayer will have the same render style.
    // This setting will apply from ZoomLevel01 to ZoomLevel20, which means the map will be rendered with the same style no matter how far we zoom in or out.
    // We need to create a LayerOverlayer to add the world layer.
    LayerOverlay overlay = new LayerOverlay();
    overlay.Opacity = 0.8;
    overlay.Layers.Add(worldLayer);
    mapView.Overlays.Add("Countries02", overlay);
Figure 4. A simple map of Europe.
NOTE: It is important that the MapUnit property of a Map object be set using the
GeographyUnit
Enumeration. This is because the coordinates stored in a Shapefile can be in decimal degrees (a format of latitude and longitude), feet, meters, or another unit system, and our map has no way to know what the Shapefile's unit of measurement is until we tell it. This information is normally found somewhere in the Shapefile's documentation (also referred to as its metadata), or within its supplemental data file, as discussed in the section on Shapefiles. It may also come as a separate .txt, .xml, or .html file that begins with the same file name as the main Shapefile.
  1. World country borders (“Countries02.shp”)
  2. World capitals (“WorldCapitals.shp”)
    ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "capital.shp"));
    // These settings will apply from ZoomLevel01 to ZoomLevel20, which means city symbols will be rendered in the same style, no matter how far we zoom in or out.
    // We need to add both of the new layers to the Map's Static Overlay.
    overlay.Layers.Add(capitalLayer);
How to Use TextStyle
    ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(Path.Combine(targetDirectory, "capital.shp"));
    // We use the preset TextStyle. Here we pass in the “CITY_NAME”, the name of the field containing the values we want to label the map with.
    // As the map is drawn by tiles, it needs to draw on the margin to make sure the text is complete after joining the tiles together.
    // Change the number below (to 0, for example) to better understand how this works.
    // Add the label layer to LayerOverlay.
    overlay.Layers.Add(capitalLabelLayer);
    // We can customize our own Style. Here we pass in a color and size.
    // The Style we set here is available from ZoomLevel01 to ZoomLevel05. That means if we zoom in a bit more, it will no longer be visible.
    // The Style we set here is available from ZoomLevel06 to ZoomLevel20. That means if we zoom out a bit more, it will no longer be visible.
    // We can customize our own TextStyle. Here we pass in the font, size, style and color.
Figure 7. Map of Europe before zooming out.
Figure 8. Map of Europe after zooming out.
Summary
  1. It is of the utmost importance that the units (feet, meters, decimal degrees, etc.) be set properly for the Map control, based on the requirements of your data.
  3. A Map is the basic control that contains all the other objects used to indicate how the map should be rendered.
  4. A Map has one-to-many Layers. A Layer correlates one-to-one with a Shapefile (.shp).
  5. A Layer can have one-to-many ZoomLevels. ZoomLevels help to define ranges (upper and lower scales) of when a Layer should be shown or hidden.
Download Sample Code From This Exercise (1.5 MB)
map_suite_android_edition_quick_start_guide.1441967437.txt.gz · Last modified: 2015/09/11 10:30 by admin
