map_suite_all_samples
Map Suite All Samples
Mobile for Android Samples
Learn about all the capabilities of Map Suite for Android by browsing all of our samples on GitLab
Mobile for iOS Samples
Learn about all the capabilities of Map Suite for iOS by browsing all of our samples on GitLab
Desktop for WinForms Samples
Quickstart Sample for WinForms
The Winforms QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This QuickStart Guide supports Map Suite 10.0.0.0 and higher and will show you how to create a Winforms application.
Please refer to Wiki for the details.
Screenshot
View this sample on Gitlab
Display Cad File Sample for WinForms
Screenshot
Routing Sample for WinForms
Sample Data Download
Screenshot
Open Street Map Sample for WinForms
OpenStreetMap (OSM) is a collaborative project to create free geographic data for the entire world. It can be thought of as a “Free Wiki World Map”. The latest version of MapSuite now supports this.
Screenshot
Use Wpf Map Control Sample for WinForms
The wpf map control supports multi-thread to render map, so it performs better than winforms map control. This sample demonstrates how you can use wpf map control in your winforms applications.
Screenshot
Building 3D Style Sample for WinForms
This project shows to create simulated 3D buildings with WinForms Map control and shapefile.
Screenshot
World Streets Layer SDK On Windows for WinForms
The World Streets Vector Layer Explorer is a tool that enables you to view the SQLite World Streets data using Map Suite WinForms and provides complete performance metrics.
This project requires a full or evaluation version of Map Suite WinForms Edition.
This sample passed on Linux with Mono Runtime. On Windows platform, it is required to replace the ThinkGeo.MapSuite.Layers.SqliteForLinux with ThinkGeo.MapSuite.Layers.Sqlite package.
To run the sample, please unzip the database file at WorldStreetsLayerSample/App_Data/DallasCounty-3857-20170218.zip, and change the connection string in WorldStreetsLayerSample/App.config to connect database that you extracted to.
Working…
Screenshot
ThinkGeo Cloud Vector Maps Sample for Winforms
This sample demonstrates how you can draw the map with Vector Tiles requested from ThinkGeo Cloud Services in your Map Suite GIS applications, with any style you want from StyleJSON (Mapping Definition Grammar). It will show you how to use the XyzFileBitmapTileCache and XyzFileVectorTileCache to improve the performance of map rendering. It supports have 3 built-in default map styles and more awasome styles from StyleJSON file you passed in, by 'Custom': - Light - Dark - TransparentBackground - Custom
Screenshot
Routing Data Explorer Sample for Wpf
How to use this tool:
1. Load rtg data:  Click menu “File→Load” browse to a rtg file. You also require a shapefile for the routing source file in the same folder, otherwise it display message “Could not find shp file in the same folder where you seleted”. 2. Start routing:
Screenshot
View this sample on Github
Rendering Points Performance Test Sample for WinForms
1. In Map Suite, a shape (a shape object inherited from the BaseShape class such as PointShape, LineShape, etc) is heavier than a feature. You can treat a feature as a holder of a byte array (Well Known Binary), it’s lightweight and doesn’t have too many methods to manipulate its core data (Well Known Binary). Shape, however, is heavy, it provides all the info as well as methods against the data. You can cast from a feature to a shape and vice versa.
1. To update a feature, usually, we need to convert a feature to a shape, update the shape and then convert it back to a feature. This will create a new shape and a new feature, which is more straightforward but the cost is high. Below is a method updating a point feature by adding 1 to its X and Y.
       private void UpdateFeatureThroughShape(Feature feature)
            byte[] wkb = feature.GetWellKnownBinary();
            PointShape pointShape = new PointShape(wkb);
            pointShape.X += 1;
            pointShape.Y += 1;
            feature = pointShape.GetFeature();
3. You can update a feature by directly updating its WKB. The following method updates a point feature by adding 1 to its X and Y. It’s the most efficient way where we manipulate a byte array without creating any new object. It is not straightforward and you need to have a deep understanding of the format of WKB. That’s what we are doing in this sample. We will add more APIs to Feature to make it straightforward and efficient.
       private void UpdateFeatureThroughWKB(Feature feature)
            double x = BitConverter.ToDouble(wkb, 5);
            double y = BitConverter.ToDouble(wkb, 13);
            BitConverter.GetBytes(x + 1).CopyTo(wkb, 5);
            BitConverter.GetBytes(y + 1).CopyTo(wkb, 13);
            feature.SetWellKnownBinary(wkb);
4. The “Grid size in Pixel” textbox let you set the size of the grid in which up to one point can be displayed, the bigger the grid is, the more sparse the points will be. This is an optimization with which we can avoid showing too many points on the map. Play with it and you can see the performance differences.
Screenshot
Hello World Sample for WinForms
This sample shows you how to get started building your first application with the Map Suite Desktop for WinForms 10.0.0.
Screenshot
Line Style With Increment Sample for WinForms
In this WinForms desktop project, we show how to create a custom LineStyle for showing distance increment at a regular interval (every tenth kilometer). Having this LineStyle can be very handy when dealing with line networks, such as roads or railways.
Screenshot
Overlays Sample for WinForms
1. Google Maps
2. Bing Maps
3. World Kit Maps
4. Open street Maps
It can display different styles of maps by setting the map type.
Screenshot
World Streets Layer SDK On Linux for WinForms
Working…
Screenshot
Edit Grid Layer Sample for WinForms
This WinForms project demonstrates how you can update a grid shape file using a spatial query. The elements in the file are rendered using ClassBreakStyles, and change when the values of the Features are incremented.
We have dramatically improved the performance for GridFeatureLayer on MapSuite10.0. The performance compare is as below:
Feature Count                             Version   Times(ms)
1164800                                       Old           13105
1164800                           New           3735
11680 Old 188
11680 New 175
Screenshot
Display Wms Raster Layer Sample for WinForms
Screenshot
Stream Loading For Native Image Sample for WinForms
Screenshot
Here Real Time Traffic Sample for WinForms
This sample demonstrates how you use HERE Real-time Traffic to render map in your Map Suite GIS applications. Before running this sample, you need to config “AppId” and “AppCode” in App.Config. If you have ESRI or Here developer account, you can generate them on Here's official Web Site.
HERE Real-time Traffic provides the closest thing to a live depiction of the road. It identifies where, when and why traffic congestion occurs, and delivers up-to-the-minute information on the road conditions and incidents that could set a driver back.
This HereRealTimeTrafficLayer is supported in all of the Map Suite controls such as WPF, Web, MVC and WebAPI.
Screenshot
Detect Gps Sample for WinForms
Screenshot
Custom Track Polygon Sample for WinForms
Learn how to extend the TrackInteractiveOverlay to add behaviors, like deleting the last added vertex when right-clicking the track line.
Screenshot
US Demographic Map Sample for WinForms
Screenshot
Drag Icon Sample for WinForms
Screenshot
Snap To Layer Sample for WinForms
Screenshot
Track Overlay With Esc Sample for WinForms
Screenshot
Shapefile Encryption Sample for WinForms
Screenshot
Get Zoom Level Sample for WinForms
This example demonstrates how to get the zoom level of the map each time we change its extent. Using custom zoom levels, you will see how to get the zoom level with its characteristics such as the upper and lower scale defining it. You can read the comments inside the project to better understand the relationship of scales with zoom levels.
Screenshot
Snapping To Vertex Sample for WinForms
Screenshot
Edit Rectangles Sample for WinForms
This sample shows how to extend the EditInteractiveOverlay rectangles as shapes, rather than polygon shapes, by setting special column values. For features (both *Well Known Text* and *Well Known Binary*), the concept of a rectangle is not supported and typically rectangles are handled as polygons. This feature allows users to modify the rectangle but requires that the modification keep a rectangular form. The rectangle doesn't need to be straight as long as all of the corner angles are at 90 degrees relative to each other.
Screenshot
Create Inner Ring Sample for WinForms
In this Desktop project we create inner rings for a polygon, based on another polygon, using the GetDifference method. We also learn how to perform a Union on a collection of polygons, and how to set up the TrackEnded event.
To use this app, you need to track a polygon, double click to end it, and it will create an inner ring based on the unioned result of the polygons that are completely within the tracked polygon. You can look at the TrackEnded event handler to see all the different operations that are taking place for that task.
Screenshot
Routing Index Generator Sample for WinForms
The Map Suite Routing Index Generator is a utility that will allow you to generate routing index files (“.rtg” and “.rtx”) from World Streets .sqlite database. These routing index files will be used by the Map Suite Routing Extension in order to calculate routes and driving directions. This utility allows you to specify things that one-way road information, as well as configuring the road speed and type of routes you would like to calculate. It is easily extendable to allow you to add code to deal with other routing situations.
Screenshot
Jpeg2000 Sample for WinForms
The Jpeg2000 Sample template represents a .JP2 (JPEG2000) image type to be drawn on the map.
Screenshot
Graphic Logo Adornment Sample for WinForms
Screenshot
Nldas Ascii Grid Layer Sample for WinFoms
This WinForms project demonstrates how you can create a North American Land Data Assimilation System (NLDAS) grid layer. In this sample, you can find what NLDAS grid cells are fully contained in a given Shape file and what cells are partially contained. For each partially contained cell we can calculate what percent of the cell area is contained within the ShapeFile. Please refer to NLDAS grid for details.
Screenshot
Multiple Labels Sample for WinForms
Screenshot
Distance Query On Projected Layers Sample for WinForms
This sample shows how to use the method GetFeaturesWithDistanceOf when the data is projected. We just input the unit which is projected to, do not need to mind what the real unit is for the internal data before projection. It works fine with Map Suite Assemblies 4.5.54.0 or later.
Screenshot
Ecw Sample for WinForms
The Ecw Sample template represents an ECW file for drawing on the map.
ECW: ECW is a wavelet image compression system developed by ER Mapper.It allows you to combine and compress large sets of satellite images into a single file. The images can be accessed very quickly at a variety of scales. It is very popular in the GIS community.
Screenshot
Site Selection Sample for WinForms
Screenshot
Select At Track Shape Sample for WinForms
Screenshot
Drag Point Advanced Sample for WinForms
This project is an example of how extensible EditInteractiveOverlay is for the editing needs of the user. You can see how to change the styles of the vertex being dragged based on the Shift key, and how to have the vertex snap to any feature.
Thanks to the protected override functions such as KeyDownCore, KeyUpCore, MouseUpCore and DrawCore, these functionalities can easily be implemented by inheriting from EditInteractiveOverlay.
Screenshot
Drag Point With Label Sample for WinForms
In this project, dedicated to EditInteractiveOverlay, you will see how easy it is to add some labeling to your dragged control point, showing dynamic information. Here we show how to display the distance from the dragged control point to the closest point of a reference shape. Also, to augment the user experience, the closest point of the reference shape is also shown varying as the control point is dragged around.
Screenshot
Mr Sid Sample for WinForms
MrSID (pronounced Mister Sid) is an acronym that stands for multiresolution seamless image database. In order to run this sample, development build 10.0.0.0 or later is required.
This sample includes a map with MrSID as base overlay, the MrSID shows the image data of the world range.
Screenshot
Known issue: The screenshot is taken under Linux, but it not well tested, maybe sometimes runs to exception.
Drag Point Sample for WinForms
In this project, we focus our attention on how to control the style of the control points. You will see how to override the DrawCore function of EditInteractiveOverlay.
Screenshot
Cluster Point Sample for WinForms
ClusterPointStyle is integrated into Map Suite's styles. In this project you will see how to use the ClusterPointStyle for clustering various features into one. Sometimes, the map may have too many features which are stacked on top of each other making the map illegible at higher zoom levels. Clustering is a useful technique as it allows you to group together various features into one labeled symbol with the count of all the features.
Screenshot
Heat Map Sample for WinForms
Screenshot
ThinkGeo Cloud Maps Sample for WinForms
Screenshot
Tracked Shapes To WKT Sample for WinForms
Screenshot
Screenshot
Dynamic Track Shapes Sample for WinForms
This Desktop project shows how to handle TrackOverlay to obtain dynamic information about the shape being tracked.
Screenshot
Geocoding Sample for WinForms
Screenshot
Labeling Based On Size Sample for WinForms
This project shows some advanced uses of the ClassBreakStyle to show how to label countries based on the area. You will notice that we also take advantage of the various zoom level sets for labeling purposes. The result is an eye pleasing labeling of the countries, with the size proportionate to the countries’ area, with more countries' labels appearing as you zoom in.
Screenshot
Track Zoom In Without Shift Key Sample for WinForms
Screenshot
Centering On Moving Vehicle With Tolerance Sample for WinForms
Screenshot
Native Tab File Support Sample for WinForms
Screenshot
Multi Geo Raster Layer Sample for WinForms
Screenshot
Get Features Clicked On Sample for WinForms
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinates needs to be set so that the feature gets selected within a constant distance in screen coordinates to where the user clicked, regardless of the zoom level.
Screenshot
ThinkGeo Cloud Maps Sample for Android
Screenshot
ThinkGeo Cloud Maps Sample for iOS
Screenshot
Select And Drag Feature Sample for Wpf
Screenshot
ThinkGeo Cloud Maps Sample for Mvc
Screenshot
Display ThinkGeo Cloud Maps Sample for JavaScript
Screenshot
Preset Vertex To Tracked Polygon Sample for WinForms
Screenshot
Us Earthquake Statistics Sample for WinForms
Screenshot
How Do I Sample for WinForms
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples.
Screenshot
Kml Sample for WinForms
Screenshot
Intersect Line Sample for WinForms
Screenshot
Dragging Icon Advanced Sample for WinForms
Screenshot
Desktop for Wpf Samples
Quickstart Sample for WPF
Description
This Quickstart Sample will guide you through the process of creating a sample application and will help you become familiar with creating maps with ThinkGeo UI. This sample project supports ThinkGeo UI 12.0.0.0 and higher and will show you how to create a WPF application using the ThinkGeo UI Desktop for WPF control.
Quick Start Video:
- ThinkGeo UI WPF Quick Start in VS Code - Part 1 - Basemap
- ThinkGeo UI WPF Quick Start in VS Code - Part 2 - Adding a ShapeFile
Please refer to our Wiki for more details.
Screenshot
About the Code
ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer(@"../../Data/WorldCapitals.shp");
textStyle.XOffsetInPixel = 0;
Getting Help
About ThinkGeo
ThinkGeo is a GIS (Geographic Information Systems) company founded in 2004 and located in Frisco, TX. Our clients are in more than 40 industries including agriculture, energy, transportation, government, engineering, software development, and defense.
Quickstart Sample for Wpf
The Map Suite WPF QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This QuickStart Guide supports Map Suite 10.0.0.0 and higher and will show you how to create a WPF application using Map Suite WPF components.
Screenshot
Nautical Charts Viewer Sample for Wpf
ThinkGeo Nautical Charts is a standalone Nuget Package which works with ThinkGeo 10.X Desktop/Web products. It reads and displays S-57 Electronic Navigational Charts(ENC) from International Hydrographic Organization(IHO), it also reads the style info defined in an S-52 file.
This sample happens to be written for WPF but the Nautical Charts Package works for Web project as well. Download and open it in Visual Studio, hit F5 and Bang, you are good to go. After you have the charts viewer running, use File → Open to load an S-57 data, (it can be downloaded from NOAA’s website), the nautical charts will then appear on the map (it generates an index file the first time the data is loaded).
ThinkGeo uses a default style which can be easily modified. Nautical Charts Viewer provide the ability to switch the map between 5 modes: Day Bright, Day Black, Day White, Dusk and Night. It has 3 verbose mode of “All”, “Standard” and “Base”. It can switch boundaries between dashed line and triangles, it can show/hide different labeling, show different languages, etc. If you are a developer, dig in the code and you can see it’s as simple as creating a layer and set up the properties like following, and it can do more than it shows in this sample
Screenshot
Vehicle Tracking Sample for Wpf
Screenshot
Display Iso Lines Sample for Wpf
Screenshot
Overlays Sample for Wpf
1. Google Maps
2. Bing Maps
3. ThinkGeo Cloud Maps
4. Open street Maps
It can display different styles of maps by setting the map type. Note: you do need to have Bing Maps API key and Google Maps API key to be able to use these two basemaps.
Screenshot
Map Suite GIS Editor
Map Suite GIS Editor for Windows lets you design stunning maps, perform geo-analysis and visualize your data. Powerful enough for professional GIS technicians yet accessible enough for nearly anyone who needs to create a map. The GIS Editor is designed as a single-application solution to all of your GIS visualization needs. Now it is open source and free. You can use the Map Suite GIS Editor to: - Quickly build maps using simple and intuitive tools - Visualize data, statistics and trends geographically - Design, style and label rich and detailed maps - Integrate data from a variety of sources, including Web Map Services - Draw right on the map, edit and create feature data - Make your maps publication-ready with titles, legends and annotations You can do all of this without wading through stacks of cryptic toolbars or scouring nested menus. The GIS Editor's simple ribbon bar interface puts its full complement of GIS tools at your fingertips in an easy-to-understand way. Wizards make short work of batch geoprocessing, geocoding and re-projection operations. And with the built-in Data Repository, you can keep all of your data close at hand, regardless of where it lives.
Looking for a customized GIS Editor or custom plug-ins? Please contact sales@thinkgeo.com for more details.
Screenshot
How Do I Sample for Wpf
Description
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in C#, these samples are designed to hit all the highlights of Map Suite, from simply adding a layer to a map to performing spatial queries and applying a thematic style. Consider this collection your “encyclopedia” of all the Map Suite basics and a great starting place for new users.
Screenshot
About the Code
Working…
Getting Help
About ThinkGeo
Map Touch Sample for Wpf
Map Suite WPF Edition supports touch events. This sample shows how to add a marker to map by MapTap event.
Screenshot
Screenshot
About the Code
Map1.ZoomLevelSet = new PrinterZoomLevelSet(Map1.MapUnit, PrinterHelper.GetPointsPerGeographyUnit(Map1.MapUnit));
PrinterInteractiveOverlay printerOverlay = new PrinterInteractiveOverlay();
Map1.InteractiveOverlays.Add("PrintPreviewOverlay", printerOverlay);
Map1.InteractiveOverlays.MoveToBottom("PrintPreviewOverlay");
PagePrinterLayer pagePrinterLayer = new PagePrinterLayer(PrinterPageSize.AnsiA, PrinterOrientation.Portrait);
pagePrinterLayer.Open();
printerOverlay.PrinterLayers.Add("PageLayer", pagePrinterLayer);
Getting Help
About ThinkGeo
Building 3D Layer Sample for Wpf
This project shows to create simulated 3D buildings on WPF map control and OsmBuildingOnlineServiceFeatureLayer.
Screenshot
Screenshot
ThinkGeo Cloud Maps Sample for Wpf
Screenshot
Screenshot
Zoom To Full Extent Wpf Sample for Wpf
This is a simple project that shows how to set the current extent based on a collection of layers. You can use this technique for the common task of having the map set to the full extent. Instead of having to manually set the full extent, you can pass all the layers you want the full extent to be based on.
Screenshot
Place search world reverse geocoding sample for Wpf
In this sample, we show how you can use Map Suite World Reverse Geocoding SDK to turn a geographic location into meaningful addresses. It ships with an optimized set of worldwide coverage of cities and towns, but any customized data can be supported as well.
Screenshot
What areas does the World Reverse Geocoding cover?
BuildingSamples-ForWpf
In this WPF project, we show how to use `BuildingOverlay`, `BuildingStyle` and `OsmBuildingOnlineServiceFeatureLayer`.
This repo contains three projects. - BuildingOverlay represents a WPF specific overlay that simulates the 2.5D building rendering. - BuildingStyle represents a style for building that is compatible with the other products such as WPF, WinForms and Web. - OsmBuildingOnlineServiceFeatureLayer represents the online data source of feature layer.
 Build Preview
PerformanceSample-ForWpf
This is a WPF desktop sample for drawing performance test of MapSuite product. When running the sample, it will render 16,000 count of rectangle shape features at first, these features will be distributed in 4 layers averagely. After clicking Start button the sample application will update 1,600 count of rectangle shape features per 1,000 milliseconds, the time cost of features drawing will display in the application footer. Customer can modify the update rate, update features count, and enable or disable the layers.
Key Points
- The rectangle shape is added to an InMemoryFeatureLayer, the layer uses a ValueStyle to draw the shape. The ValueStyle has 4 count of ValueItems which the item Id is from 0 to 3 and the item AreaStyle uses 4 different of fill colors. The shape also has a column value of 0 at the first time, the ValueStyle will use this value to draw the shape using corresponding AreaStyle.
- In each update, the application will choose 1,600 count of features from all valid features randomly to modify their column values. The column value will be modified to 0, 1, 2 or 3 circularly.
- The CustomLayerOverlay will be used in the update, the application will create a new InMemoryFeatureLayer and add it to this overlay when updating, all determined 1,600 count of features will be added to the layer. The previous overlay will be removed if it exists in the map, then a new overlay will be added to the map. Before removing the previous overlay, the all resources (include all layer tiles and background images) from the overlay will be drawn on a GeoImage, then set the GeoImage to the background image of the new overlay. We do this to make sure only 1,600 count of features would be rendered in each update, and the previous updated features would be displayed correctly in the map.
- Customer can check or uncheck the layers in the right list of the application form, the application will only choose the features which in the checked layers when updating, and the unchecked layers will be hidden in the map.
Screenshot
Filter Style Sample for Wpf
This project outlines how to apply the FilterStyle to a layer's display. By using this style, the map will filter the features queried from the source file by checking if a specified column value fits the input condition. This effect can be applied to all the Map Suite products.
Screenshot
Delay Drawing Sample for Wpf
This WPF project shows how to use the Delay Map Drawing feature to control whether or not the layer is redrawn after a specified delay. This option is very helpful for anyone wanting to do something before actually refreshing the map - such as editing the elements, adding an animation, etc.
Screenshot
Annotation Style Sample for Wpf
Description
In this project you will see how to use the AnnotationStyle to display and edit a feature depending on the value of a specific property in its data source.
Screenshot
About the Code
protected override void DrawCore(IEnumerable<Feature> features, GeoCanvas canvas, Collection<SimpleCandidate> labelsInThisLayer, Collection<SimpleCandidate> labelsInAllLayers)
    foreach (var feature in features)
        if (feature.GetWellKnownType() == WellKnownType.Line)
            LineShape lineShape = (LineShape)feature.GetShape();
            Feature newFeature = new Feature(lineShape.Vertices[0]);
            newFeature.ColumnValues.Add(TextColumnName, feature.ColumnValues[TextColumnName]);
            var labelingCandidates = GetLabelingCandidates(newFeature, canvas, Font, XOffsetInPixel, YOffsetInPixel, RotationAngle);
            foreach (var labelingCandidate in labelingCandidates)
                PolygonShape maskArea = ConvertPolygonShapeToWorldCoordinate(labelingCandidate.ScreenArea, canvas.CurrentWorldExtent, canvas.Width, canvas.Height);
                PointShape closestPoint = maskArea.GetClosestPointTo(new PointShape(lineShape.Vertices[1]), canvas.MapUnit);
                if (closestPoint != null)
                    lineShape.Vertices[0] = new Vertex(closestPoint.X, closestPoint.Y);
                    LeaderLineStyle.Draw(new LineShape[] { lineShape }, canvas, labelsInThisLayer, labelsInAllLayers);
                DrawMask(labelingCandidate, canvas, labelsInThisLayer, labelsInAllLayers);
                foreach (LabelInformation labelInfo in labelingCandidate.LabelInformation)
                    var textPathInScreen = new ScreenPointF((float)labelInfo.PositionInScreenCoordinates.X, (float)labelInfo.PositionInScreenCoordinates.Y);
                    canvas.DrawText(labelInfo.Text, Font, TextBrush, HaloPen, new ScreenPointF[] { textPathInScreen }, DrawingLevel, 0, 0, DrawingTextAlignment.Default, (float)labelInfo.RotationAngle);
Getting Help
About ThinkGeo
Hello World Sample for Wpf
This sample shows you how to get started building your first application with the Map Suite Desktop for Wpf 10.0.0.
Screenshot
Usgs Dem Sample for Wpf
This sample demonstrates how you can read data from an DEM file in your Map Suite GIS applications, and how to render it with DEM embedded value style as well as a customized style. This DEM File support would work in all of the Map Suite controls such as Wpf, Web, Android and iOS.
Screenshot
Touch Events Sample for Wpf
This sample shows how to take advantage of touch screen to manipulate that map using one’s fingers. Learn how the map can be panned, zoomed in and out or rotated using two fingers. On addition, markers can be added, and shapes can be added and edited by tapping the screen.
The sample code makes this straight forward to implement.
Screenshot
Wmts Layer Sample for Wpf
Screenshot
Reproject Wmts Sample for Wpf
Description
In today’s project, we show how to create your own projection class that allows projecting a WMTS layer from any internal projection to any external.
Screenshot
About the Code
wmtsLayer = new WmtsLayer();
wmtsLayer.WmtsSeverEncodingType = ThinkGeo.MapSuite.Layers.WmtsSeverEncodingType.Kvp;
wmtsLayer.ServerUris.Add(new Uri("https://basemap.nationalmap.gov/arcgis/rest/services/USGSImageryOnly/MapServer/WMTS"));
wmtsLayer.ActiveLayerName = "USGSImageryOnly";
wmtsLayer.ActiveStyleName = "default";
wmtsLayer.TileMatrixSetName = "GoogleMapsCompatible";
wmtsLayer.OutputFormat = "image/png";
wmtsLayer.Projection = new Proj4Projection(3857, 4326);
wmtsLayer.ProjectedTileCache = new FileBitmapTileCache("WmtsProjectedTileCache", "USGSImageryOnly-4326");
wmtsLayer.TileCache = new FileBitmapTileCache("WmtsTileCache", "USGSImageryOnly-3857");
Getting Help
About ThinkGeo
Show A Legend Sample for Wpf
In today’s project we learn how to display a simple legend using the new and improved LegendAdornmentLayer. The improved LegendAdornmentLayer was added to Map Suite 5.0 and provides an easy to use API for creating legend adornments. The LegendAdornmentLayer is part of Map Suite Core which allows you to access this powerful feature across all Map Suite products.
Screenshot
Rotate Events Sample for Wpf
Screenshot
Draggable Labels Sample for Wpf
In this WPF project, you will learn how to place labels from a shapefile into a SimpleMarkerOverlay. Using the DragMode property of the SimpleMarkerOverlay, the user can then drag the labels to place them at the desired location for the most pleasing labeling effect. This project will be later completed to show how to save the state of the dragged labels from the SimpleMarkerOverlay and reload them.
Screenshot
Color Replacement Sample for Wpf
Screenshot
Site Selection Sample for Wpf
Screenshot
Mini Map Sample for Wpf
This project shows how to create a simple mini map to give a reference of where you are when you zoomed in. As for the MiniMapAdormentLayer inherits from AdornmentLayer.
Screenshot
Magnetic Declination Sample for Wpf
In today's WPF project, we show you how to add the Magnetic Declination or Magnetic variation to the map, it's designed as an AdormentLayer, which is used for showing the angle on the horizontal plane between magnetic north (the direction in which the north end of a compass needle, corresponding to the direction of the Earth's magnetic field lines) and true north (the direction along a meridian towards the geographic North Pole). This angle varies depending on one's position on the Earth's surface, and over time. See
Screenshot
Building 3D Sample for Wpf
This project shows to create simulated 3D buildings on WPF map control and Shapefile.
Screenshot
Friends Network Sample for Wpf
Screenshot
Combine Overlay Sample for Wpf
Screenshot
US Demographic Map Sample for Wpf
Screenshot
Elevation Statistics Sample for WPF
This Sample shows the elevation data of a road in the form of a line [chart][1].
- Elevation SDK - support query elevation data by points, line and polygon based on [SRTM][2] and Ned13 elevation source data. - For point - Create a buffer and aggregate all points within buffer to create average for the elevation of the point. - For line - There are two ways to get the elevation data of the line. First, get the points on the line by setting the interval distance. The other, is to take the points by setting the number of points to be fetched. Then query the elevation data of the point. - For polygon - By setting the interval distance, clip the polygon to the grids and get all the center of the grids where the polygon is located. Now, determine whether the center points are within the surface or inside the surface (use improved arc-length method).
Screenshot
Local Datum UTM Sample for Wpf
The purpose of this WPF sample is to get familiar with the concept of datum and datum shift in UTM and Geographic coordinates. Using local data, you might be required to apply datum transformation to your data to go from an old datum to a more recent datum. Here we are taking the example of Australia, which went to change its datum (from AGD84 to GDA94) for its mapping purposes. We show how to apply the datum transformation in both the longitude/latitude coordinate system and in the local UTM systems (AMG based on AGD84 and MGA based on GD94).
See the code and note the comments in the MouseMove event where all the projection logic is taken place. Notice that the correction is about 200 meters. Once you understand for the case for Australia, you will be able to apply the same principles for your own datums in UTM.
Screenshot
Multi Line Labeling Sample for Wpf
For labeling purpose, TextStyle has a property called LabelAllPolygonParts that will label all the parts making up a polygon based feature. Unfortunately, we don’t have an equivalent API for labeling all the parts of a line based feature. But thanks to the flexible framework of Map Suite, we show in this WPF sample how easily you can expand the TextStyle class to allow this labeling capability. Look at the custom class MultiLinetextStyle and how DrawCore function is overridden to have the expected labeling behavior.
Screenshot
Cluster Feature Layer Sample for Wpf
The sample shows how to use ClusterFeatureLayer to render the specified column data as a pie chart. Allows users to compare data visually.
Screenshot
Google Map To Geodetic Sample for Wpf
In this Wpf project, we are showing a trick for getting the current extent of the map with Google Map as an image and displaying it on a map in decimal degrees unit. You may be in a situation where you want the details and accuracy of Google Map, especially the satellite view but want to have it displayed on your map in decimal degrees. In this sample, you will see how to get the Google Map image and create the accompanying world file for decimal degrees. Notice that we are realizing an affine transformation on the image to go to Geodetic as illustrated in the case 3
Screenshot
GPS Exchange Format Feature Layer Sample for Wpf
Screenshot
Dynamic Marker Overlay Sample for Wpf
Screenshot
ThinkGeo MBTiles Maps Sample for WPF
This sample demonstrates how you can draw the map with Vector Tiles saved in *.MBTiles in your Map Suite GIS applications, with any style you want from StyleJSON (Mapping Defination Grammar). It will show you how to use the XyzFileBitmapTileCache to improve the performance of map rendering. It supports have 3 built-in default map styles and more awasome styles from StyleJSON file you passed in, by 'Custom': - Light - Dark - TransparentBackground - Custom
If you want the *.mbtile file of any area in the world, or you have any requirement of building *.mbtile file based on your own data, such as shape file, Oracle, MsSql and more, please contact support@thinkgeo.com.
*.MBTile format can be supported in all of the Map Suite controls such as Wpf, Web, MVC, WebApi, Android and iOS.
Screenshot
Four Color Map Sample for Wpf
Any map can be colored using four colors in such a way that adjacent regions receive different colors. The sample discover how to use ShapeFileFeatureLayer to get four color features, then use ValueStyle to render the four color map.
At present, the four color map only supports polygon, and doesn't support point and line.
Screenshot
Elevation Grade Of Line Sample for Wpf
In this sample, we show how you can use Map Suite Elevation SDK to get the elevation values of a specific line for your .NET application. It allows you to customize your query to get data as detailed as you need it to be. Draw elevation profiles for your hiking or biking trip, contral the granularity of the response, sample elevation values at controllable intervals along a route should be shown up.
Screenshot
Custom Parameters Projection Sample for Wpf
Screenshot
Class Break Style Sample for Wpf
Description
In this project you will see how to use the ClassBreakStyle to group and render features by values. ClassBreakStyle is a useful technique as it allows you to group various features by the specified values, then applies differently style to the feature groups.
Screenshot
About the Code
Use a ClassBreakStyle to colorize each state differently depending on the range into which its population falls. This value is found in the states ShapeFile DBF in the column named “POP1990”.
ClassBreakStyle statesStyle = new ClassBreakStyle("POP1990");
statesStyle.ClassBreaks.Add(
    new ClassBreak(value: 0, areaStyle: AreaStyles.CreateSimpleAreaStyle(
        fillBrushColor: GeoColors.LightGray,
        outlinePenColor: GeoColors.DarkGray,
        outlinePenWidth: 1)
    new ClassBreak(value: 1000000, areaStyle: AreaStyles.CreateSimpleAreaStyle(
        fillBrushColor: GeoColors.LightBlue,
        outlinePenColor: GeoColors.CornflowerBlue,
        outlinePenWidth: 1)
    new ClassBreak(value: 3500000, areaStyle: AreaStyles.CreateSimpleAreaStyle(
        fillBrushColor: GeoColors.SkyBlue,
        outlinePenColor: GeoColors.DeepSkyBlue,
        outlinePenWidth: 1)
// Add stateStyle to the statesLayer and apply the style to all zoom levels.
statesLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(statesStyle);
statesLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
Getting Help
About ThinkGeo
Arc GIS Server Rest Layer Sample for WPF
In this wpf-based project, we'll demonstrate the new ArcGISServerRestLayer released with Map Suite 9.0. This layer gives developers a simple and powerful tool to access their maps that reside on ArcGIS Server. This new layer utilizes the ArcGIS Server REST API. Now, the latest version of Map Suite Core can support that. In order to run this project, you will need the Development Build 9.0.443.0 or later.
Screenshot
Large Scale Map Printing Sample for Wpf
This WPF project is the second in our series of samples on printing. The
Screenshot
Labeling Flight Lines Sample for Wpf
This sample shows how to offset arc shaped flight lines so multiple from point to point are visible and then show popup labels providing information on the flights the lines represent.
Screenshot
Default Value Style Sample for Wpf
Screenshot
Clipping On Line Layer Sample for Wpf
This Wpf project completes the series of projects dedicated to the clipping geoprocessing. We already saw how to perform clipping on a polygon based layer in “Clipping” and on a point layer in “Clipping On Point Layer”. Here we show how to perform the clipping geopressing on a line based layer. As for the same operation on a polygon based layer, the key geometric function is GetIntersection. We will also appreciate the operation of creating a layer from scratch as in addition to the geometric operation itself, geoprocessing also involves creating a result layer from the original layers, the clipping layer and the clipped layer.
Please refer to Wiki for the details.
Screenshot
View this sample on Gitlab
Graticule With Google Projection Sample for Wpf
In this Wpf project, we explore more features of the GraticuleAdornmentLayer, which shows meridians and parallels at various intervals based on the zoom level. Being natively in Geodetic, GraticuleAdornmentLayer can be set to any projection. In this project’s example, you have the graticule showing with World Map Kit in Spherical Mercator (Google Map projection). Also, note how easily you can change the appearance with properties such as GraticuleLineStyle and GraticuleTextFont.
Screenshot
Edit Attribute Of Shapefile Sample for Wpf
The purpose of this Wpf sample is to show how to edit the attributes of a feature of a shapefile. This sample is useful for anyone wanting to actualize the attributes part of its data by simply clicking on the desired feature on the map and updating its attributes in a textbox. You will find the editing part of the code in the KeyDown event of the textbox.
Screenshot
Display Oracle Data Sample for Wpf
Discover how to use OracleFeatureLayer to build up your map. Use oracle data to render map.
Screenshot
Adjacent Road Search Sample for Wpf
This WPF project shows how to get a route between two adjacent roads, even if they don't intersect within an allowable tolerance.
It’s based on Map Suite Geometry Topology module and does not require the Map Suite Routing Extension.
Screenshot
NOAA Global Weather Station Layer Sample for Wpf
This WPF project, demonstrates how to query and display real time NOAA weather station data directly as a Layer, which allows you to display up-to-date weather station data from around the world on top of your maps. The weather station data is sourced from NOAA and is refreshed every 15 minutes in the background. As these classes are inherited from the FeatureSource and FeatureLayer, many properties are querable and can be used to create a variety of maps or analysis of current weather patterns. This feature can be applied in all Map Suite products.
Screenshot
SQLite Bitmap Tile Cache Sample for Wpf
This sample shows how you can cache the tile images in SQLite database.
Screenshot
Wmts Tiled Overlay Sample for Wpf
This project shows how to consume data from a WMTS Server using WmtsOverlay. You would find the code pretty straightforward, while behind the scenes we request tiles from the server asynchronously and efficiently, and stitch them into a proper map. This class is introduced from version 6.0.187.0, besides this WmtsOverlay, we also have WmtsLayer available.
Screenshot
Display File GeoDatabase Sample for Wpf
This sample demonstrates how you can read data from an ESRI FileGeodatabase, and you will find the code as straightforward as consuming any other data source in Map Suite.
Screenshot
Multiple Dot Density Styles Sample for Wpf
This sample takes a detailed look at the DotDensityStyle. You can combine different DotDensityStyles on one FeatureLayer using different columns. Demographic data are usually well fit to be used with that type of style. Here each dot of a certain color represents 100,000 persons of the same age group by state. Using multiple DotDensityStyles, the dimension of age group demographics is added to the representation of population density.
Note that the PointToValueRatio is used to set how many people a dot is going to represent. For example, if you want a dot to represent 100,000 persons, you set it to 0.00001 (1 / 100000). If you want it to be 500,000 persons, you set it to 0.000002 (1 / 500000).
Screenshot
BackgroundMapSwitchingSample-ForWpf
This sample shows you how to use these four different types of maps as background in Map Suite Desktop (WPF) Edition. - ThinkGeo Cloud Maps - Open Street Map - Bing Maps - Google Maps
Screenshot
Highlight At Mouse Hover Sample for Wpf
Screenshot
Cluster Point Sample for Wpf
Description
ClusterPointStyle is integrated into ThinkGeo's styles. In this project you will see how to use the ClusterPointStyle for clustering various features into one. Sometimes, the map may have too many features which are stacked on top of each other making the map illegible at higher zoom levels. Clustering is a useful technique as it allows you to group together various features into one labeled symbol with the count of all the features.
Screenshot
About the Code
ClusterPointStyle clusterPointStyle = new ClusterPointStyle();
clusterPointStyle.MinimumFeaturesPerCellToCluster = 1;
clusterPointStyle.DefaultTextStyle = TextStyle.CreateSimpleTextStyle("FeatureCount", "Arail", 10,
                                                         DrawingFontStyles.Regular, GeoColors.Black);
clusterPointStyle.DefaultTextStyle.TextPlacement = TextPlacement.Center;
clusterPointStyle.DefaultTextStyle.OverlappingRule = LabelOverlappingRule.AllowOverlapping;
clusterPointStyle.DrawingClusteredFeature += ClusterPointStyle_DrawingClusteredFeature;
private void ClusterPointStyle_DrawingClusteredFeature(object sender,
   DrawingClusteredFeatureClusterPointStyleEventArgs e)
    classBreakStyle = classBreakStyle ?? GetClassBreakStyle("FeatureCount");
    e.Styles.Add(classBreakStyle);
private ClassBreakStyle GetClassBreakStyle(string columnName)
    ClassBreakStyle classBreakStyle = new ClassBreakStyle();
    classBreakStyle.ColumnName = columnName;
    PointStyle pointStyle1 = new PointStyle(PointSymbolType.Circle, 8,
                                            new GeoSolidBrush(GeoColor.FromArgb(250, 100, 200, 100)),
                                            new GeoPen(GeoColor.FromArgb(100,120, 200, 120), 5));
    classBreakStyle.ClassBreaks.Add(new ClassBreak(1, pointStyle1));
    PointStyle pointStyle2 = new PointStyle(PointSymbolType.Circle, 15,
                                            new GeoSolidBrush(GeoColor.FromArgb(250, 222, 226, 153)),
                                            new GeoPen(GeoColor.FromArgb(100 222, 226, 153), 8));
    classBreakStyle.ClassBreaks.Add(new ClassBreak(2, pointStyle2));
    PointStyle pointStyle3 = new PointStyle(PointSymbolType.Circle, 25,
                                            new GeoSolidBrush(GeoColor.FromArgb(250, 255, 183, 76)),
                                            new GeoPen(GeoColor.FromArgb(100,255, 183, 76), 10));
    classBreakStyle.ClassBreaks.Add(new ClassBreak(5, pointStyle3));
    PointStyle pointStyle4 = new PointStyle(PointSymbolType.Circle, 35,
                                            new GeoSolidBrush(GeoColor.FromArgb(250, 243, 193, 26)),
                                            new GeoPen(GeoColor.FromArgb(100,243, 193, 26), 15));
    classBreakStyle.ClassBreaks.Add(new ClassBreak(10, pointStyle4));
    PointStyle pointStyle5 = new PointStyle(PointSymbolType.Circle, 40,
                                            new GeoSolidBrush(GeoColor.FromArgb(250, 245, 7, 10)),
                                            new GeoPen(GeoColor.FromArgb(100,245, 7, 10), 15));
    classBreakStyle.ClassBreaks.Add(new ClassBreak(100, pointStyle5));
    PointStyle pointStyle6 = new PointStyle(PointSymbolType.Circle, 50,
                                            new GeoPen(GeoColor.FromArgb(100,245, 7, 10), 20));
    classBreakStyle.ClassBreaks.Add(new ClassBreak(500, pointStyle6));
    return classBreakStyle;
Getting Help
About ThinkGeo
Mask Raster Layer Sample for Wpf
This sample shows how to use GeoTiff raster layer to mask the background map and allows users to draw a polygon shape in order to only show the raster image which is covered by the polygon. The rendering logic can be applied to other RasterLayers by overwriting DrawCore method.
Screenshot
View this sample on Github # Weather Line Style Sample for Wpf
### Description
In this WPF sample, we learn how to extend LineStyle class to create a style for representing weather fronts, such as cold front, warm front, or occluded front for your weather maps. To achieve that styling a regular LineStyle is used for the front line itself. For symbolizing the type of front an icon is used.
Notice the two handy properties to give you more control: Spacing property to adjust the distance in screen coordinate between each symbol on the line, and Side property to control on what side of the line front the symbols should appear. Of course, as you zoom in and out on the map the spacing between each symbol remain the same as it is set in screen coordinate.
Please refer to [Wiki](http://wiki.thinkgeo.com/wiki/thinkgeo_desktop_for_wpf) for the details.
![Screenshot](https://github.com/ThinkGeo/WeatherLineStyleSample-ForWpf.NETCore/blob/master/ScreenShot.png)
### About the Code ```csharp class customGeoImageLineStyle : LineStyle {
           System.Collections.ObjectModel.Collection<SimpleCandidate> labelsInThisLayer,
           System.Collections.ObjectModel.Collection<SimpleCandidate> labelsInAllLayers)
     PointStyle pointStyle = new PointStyle(geoImage);
     foreach (Feature feature in features)
          lineStyle.Draw(new BaseShape[] { lineShape }, canvas, labelsInThisLayer, labelsInAllLayers);
          double totalDist = 0;
          for (int i = 0; i < lineShape.Vertices.Count - 1; i++)
              PointShape pointShape1 = new PointShape(lineShape.Vertices[i]);
              PointShape pointShape2 = new PointShape(lineShape.Vertices[i + 1]);
              LineShape tempLineShape = new LineShape();
              tempLineShape.Vertices.Add(lineShape.Vertices[i]);
              tempLineShape.Vertices.Add(lineShape.Vertices[i + 1]);
              double angle = GetAngleFromTwoVertices(lineShape.Vertices[i], lineShape.Vertices[i + 1]);
              if (side == SymbolSide.Left)
                  if (angle >= 270) { angle = angle - 180; }
              else
                  if (angle <= 90) { angle = angle + 180; }
              pointStyle.RotationAngle = (float)angle;
              float screenDist = ExtentHelper.GetScreenDistanceBetweenTwoWorldPoints(
                          canvas.CurrentWorldExtent,pointShape1, pointShape2, canvas.Width, canvas.Height);
              double currentDist = Math.Round(pointShape1.GetDistanceTo(pointShape2, canvas.MapUnit,
        DistanceUnit.Meter), 2);
              double worldInterval = (currentDist * spacing) / screenDist;
              while (totalDist <= currentDist)
                  PointShape tempPointShape = tempLineShape.GetPointOnALine(StartingPoint.FirstPoint,
                                                            totalDist, canvas.MapUnit, DistanceUnit.Meter);
                  pointStyle.Draw(new BaseShape[] { tempPointShape }, canvas,
                  totalDist = totalDist + worldInterval;
              totalDist = totalDist - currentDist;
} ``` ### Getting Help
[Map Suite Desktop for Wpf Wiki Resources](http://wiki.thinkgeo.com/wiki/thinkgeo_desktop_for_wpf)
[Map Suite Desktop for Wpf Product Description](https://thinkgeo.com/ui-controls#desktop-platforms)
[ThinkGeo Community Site](http://community.thinkgeo.com/)
[ThinkGeo Web Site](http://www.thinkgeo.com)
### About ThinkGeo ThinkGeo is a GIS (Geographic Information Systems) company founded in 2004 and located in Frisco, TX. Our clients are in more than 40 industries including agriculture, energy, transportation, government, engineering, software development, and defense.
Tracked Shapes To File Sample for Wpf
Screenshot
Save Load State Sample for Wpf
The purpose of this Wpf project is to show how to use the new SaveState and LoadState of the SimpleMarkerOverlay. We show how you can simply drag the icons to change their location, save their state to a file and then reload the state from that file. For this sample to work, you will need to use the latest
Screenshot
Snap To Layer Sample for Wpf
Screenshot
MBTiles Extractor Sample for WPF
Description
The MBTiles Extractor allows you to create new smaller subsets from the MBTiles database. You simply specify the bounding box by tracking a rectangle shape on the map for the new area, then it will create a new SQLite database for that regions.
Screenshot
About the Code
The sample can extract MBTiles from source database to target database. One thing needs to be aware of: there are three tables (“map”,“images”,“metadata”) need to be copied from source database to target database.
ThinkGeoMBTilesLayer.CreateDatabase(targetFilePath);
var targetDBConnection = new SqliteConnection($"Data Source={targetFilePath}");
var targetMap = new Map(targetDBConnection);
var targetImages = new Images(targetDBConnection);
var targetMetadata = new Metadata(targetDBConnection);
var sourceDBConnection = new SqliteConnection("Data Source=Data/tiles_Frisco.mbtiles");
var sourceMap = new Map(sourceDBConnection);
var sourceImages = new Images(sourceDBConnection);
var sourceMetadata = new Metadata(sourceDBConnection);
sourceMetadata.NextPage();
foreach (MetadataEntry entry in sourceMetadata.Entries)
    if (entry.Name.Equals("center"))
        PointShape centerPoint = projection.ConvertToExternalProjection(bbox).GetCenterPoint();
        entry.Value = $"{centerPoint.X},{centerPoint.Y},{maxZoom}";
targetMetadata.Insert(sourceMetadata.Entries);
int recordLimit = 1000;
foreach (var tileRange in tileRanges)
    long offset = 0;
    bool isEnd = false;
    while (!isEnd)
        string querySql = $"SELECT * FROM {sourceMap.TableName} WHERE " + ConvetToSqlString(tileRange)
                            + $" LIMIT {offset},{recordLimit}";
        var entries = sourceMap.Query(querySql);
        targetMap.Insert(entries);
        if (entries.Count < recordLimit)
            isEnd = true;
        querySql = $"SELECT images.tile_data as tile_data, images.tile_id as tile_id FROM {sourceImages.TableName} "
                    + $WHERE images.tile_id IN ( SELECT {Map.TileIdColumnName} FROM {sourceMap.TableName} WHERE "
                    + ConvetToSqlString(tileRange) + $" LIMIT {offset},{recordLimit} )";
        entries = sourceImages.Query(querySql);
        targetImages.Insert(entries);
        offset = offset + recordLimit;
Getting Help
About ThinkGeo
Screenshot
Display MsSql GeoDatabase Sample for Wpf
This sample demonstrates how you can read data from an MsSql database, and you will find the code as straightforward as consuming any other data source in Map Suite.
Screenshot
Use Wpf Map Control Sample for WinForms
The wpf map control supports multi-thread to render map, so it performs better than winforms map control. This sample demonstrates how you can use wpf map control in your winforms applications.
Screenshot
ThinkGeo Cloud Color Sample for Wpf
This sample demonstrates how you can use ThinkGeo Cloud Client to get colors from ThinkGeo GIS Server. It supports 7 different colors: - Hue - Quality - Analogous - Complementary - Contrasting - Tetradic - Triadic
ThinkGeo Cloud Client support would work in all of the Map Suite controls such as Wpf, Web, MVC, WebApi, Android and iOS.
Screenshot
Popup and marker need to use click events etc, so they inherit Control class. SimpleMarkerOverlay and PopupOverlay can't be printed directly, and They need to be converted to image. This sample demonstrates how to print popup and marker by PrinterGeoCanvas.
Screenshot
Raster Layer Print Quality Sample for Wpf
This WPF project is the 3rd sample on the printing series. It demonstrates how to print your maps in high quality. This new feature for Map Suite is available in version 9.0.483.0 or later. From the sample you will better understand how to use DPI for handling print quality. The sample is based on raster images, but could also be used with vector data.
Screenshot
Custom Rotation Projection Sample for Wpf
In today’s project, we show how to create your own projection class that allows projecting a layer from any internal projection to any external while doing a rotation at the same time. Having the capability to apply those two operations in one step may come handy if the original layer was created in a different projection with the north at an angle and you want to align it on the base map.
Screenshot
Centering And Rotating Sample for Wpf
Screenshot
Wrap Dateline Mode Sample for Wpf
Screenshot
Map Loading Progress Sample for Wpf
Discover how to use progress bar to show the LayerOverlay rendering progress. The project is simple and meant to show only the basic logic; to extend it, you could add some other information or a loading image instead of a progress bar.
Screenshot
ThinkGeo Cloud Geocoding Sample for Wpf
This Sample demonstrates how you can use ThinkGeo Cloud Client to get a geographic location from ThinkGeo GIS Server by a street address.
Screenshot
Screenshot
Cad Viewer Sample for Wpf
Description
Screenshot
### About the Code ```csharp CadFeatureLayer layer = new CadFeatureLayer(@“AppData\” + sampleFileListBox.SelectedItem.ToString()); layer.StylingType = CadStylingType.StandardStyling; layer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = LineStyles.CreateSimpleLineStyle(GeoColor.SimpleColors.Black, 2, true); layer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyles.CreateSimplePointStyle(PointSymbolType.Circle, GeoColor.SimpleColors.Blue, 8); layer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = AreaStyles.CreateSimpleAreaStyle(GeoColor.SimpleColors.Yellow); layer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; ```
### Getting Help
[ThinkGeo Desktop for Wpf Wiki Resources](http://wiki.thinkgeo.com/wiki/thinkgeo_desktop_for_wpf)
[ThinkGeo Desktop for Wpf Product Description](https://thinkgeo.com/ui-controls#desktop-platforms)
### About ThinkGeo
Image Style Sample for Wpf
Description
Screenshot
About the Code
[Serializable]
class ImageAreaStyle : Style
    private GeoImage geoImage = null;
    public ImageAreaStyle(GeoImage geoImage)
        this.geoImage = geoImage;
        // Loop through all of the features being passed in to draw.
            WellKnownType shapeWellKnownType = feature.GetWellKnownType();
            if (shapeWellKnownType == WellKnownType.Polygon)
                PolygonShape polygonShape = new PolygonShape(feature.GetWellKnownBinary());
                canvas.DrawArea(polygonShape, new GeoTextureBrush(geoImage), DrawingLevel.LevelOne);
            else if (shapeWellKnownType == WellKnownType.Multipolygon)
                MultipolygonShape multiPolygonShape = new MultipolygonShape(feature.GetWellKnownBinary());
                canvas.DrawArea(multiPolygonShape, new GeoTextureBrush(geoImage), DrawingLevel.LevelOne);
Getting Help
About ThinkGeo
Earthquake Statistics Sample for Wpf
Description
Screenshot
About the Code
GridInterpolationModel interpolationModel = new InverseDistanceWeightedGridInterpolationModel(3, double.MaxValue);
isoLineLayer = new DynamicIsoLineLayer(dataPoints, IsoLineLayer.GetIsoLineLevels(dataPoints.Values, 12),
                                       interpolationModel, IsoLineType.ClosedLinesAsPolygons);
IsoLineLayer.GetIsoLineLevels(dataPoints, 12);
levelClassBreakStyle = new ClassBreakStyle(isoLineLayer.DataValueColumnName);
levelClassBreakStyle.ClassBreaks.Add(new ClassBreak(double.MinValue,
                                     new AreaStyle(new GeoPen(GeoColor.FromHtml("#FE6B06"), 1),
                                     new GeoSolidBrush(new GeoColor(100, levelAreaColors[0])))));
Getting Help
About ThinkGeo
ThinkGeo Cloud Elevation Sample for Wpf
Screenshot
Find Nearest Cross Streets Sample for Wpf
Screenshot
Spatial Query With ThinkGeo Cloud Vector Maps Sample for Wpf
This sample demonstrates how you can query the features of Vector Tiles requested from ThinkGeo Cloud Services in your Map Suite GIS applications, such as searching the nearest places to your clicked place or the roads in the area with a specific distance you specified.
Screenshot
Find Shortest Line And Splitting Lines Sample for Wpf
Screenshot
Polygon Shapes To Multipolygon Shape Sample for Wpf
Screenshot
World Map Kit Data Extractor Sample for Wpf
The World Map Kit Data Extractor allows you to create new smaller subsets from the World Map Kit SQLite master database. You simply specify the bounding box (or a shape file) for the new area then it will create a new SQLite database for that regions. There are options to preserve high level data allowing you to keep higher extent features, about 700 meg of data, such as the world, countries, high level roads etc. as a backdrop to the cut out area. If you choose not to preserve the high level data the tool crosscuts every layer leaving you with the smallest dataset possible. The tool works with multiple projections but does not re-project. Specifying the srid allows you to configure your bounding box in decimal degrees regardless of the source database projection. We will consider enhancing the tool to support projection based on feedback.
Screenshot
Connecting Two Shapes With Arraw Line Sample for Wpf
Screenshot
Multiple Jpeg2000 Raster Layer Sample for Wpf
Screenshot
Use Custom Font Symbol With PointStyle for Wpf
Description
In this sample we show you how to use custom font symbol with pointStyle to your Map Suite applications for the WPF environment. The UseCustomFontSymbolWithPointStyle-ForWpf.NETCore sample supports ThinkGeo UI for Wpf 12.0 and higher.
Screenshot
### About the Code ```csharp ShapeFileFeatureLayer citiesLayer = new ShapeFileFeatureLayer(“AppData/MajorCities_3857.shp”); citiesLayer.Name = “MajorCities”; citiesLayer.ZoomLevelSet.ZoomLevel04.DefaultPointStyle = new PointStyle(
                                  new GeoFont("AppData/vectormap-icons.ttf", 20, DrawingFontStyles.Regular),
                                  "\ue0b5",new GeoSolidBrush(GeoColors.Red));
citiesLayer.ZoomLevelSet.ZoomLevel05.DefaultPointStyle = new PointStyle(
                                  new GeoFont("AppData/vectormap-icons.ttf", 25, DrawingFontStyles.Regular),
                                  "\ue05c",new GeoSolidBrush(GeoColors.Orange));
citiesLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = new PointStyle(
                                  new GeoFont("AppData/vectormap-icons.ttf", 28, DrawingFontStyles.Regular),
                                  "\ue078",new GeoSolidBrush(GeoColors.Green));
citiesLayer.ZoomLevelSet.ZoomLevel07.DefaultPointStyle = new PointStyle(
                                  new GeoFont("AppData/vectormap-icons.ttf", 30, DrawingFontStyles.Regular),
                                  "\ue035",new GeoSolidBrush(GeoColors.DarkBlue));
citiesLayer.ZoomLevelSet.ZoomLevel08.DefaultPointStyle = new PointStyle(
                                  new GeoFont("AppData/vectormap-icons.ttf", 34, DrawingFontStyles.Regular),
                                  "\ue02e",new GeoSolidBrush(GeoColors.Blue));
citiesLayer.ZoomLevelSet.ZoomLevel09.DefaultPointStyle = new PointStyle(
                                  new GeoFont("AppData/vectormap-icons.ttf", 36, DrawingFontStyles.Regular),
                                  "\ue06f",new GeoSolidBrush(GeoColors.Purple));
citiesLayer.ZoomLevelSet.ZoomLevel10.DefaultPointStyle = new PointStyle(
                                  new GeoFont("AppData/vectormap-icons.ttf", 40, DrawingFontStyles.Regular),
                                  "\ue084", new GeoSolidBrush(GeoColors.Red));
Render Point With TextStyle for Wpf
Description
In this sample we show you how to render points with textStyle in your WPF applications. It is using ThinkGeo Web Font which can be browsed/downloaded from Here. This sample uses ThinkGeo UI for Wpf 12.0.12 or higher.
TextStyle can render a point layer with font glyphs, it can also take advantage of the text confliction check to avoid duplication. PointClusterStyle can also be used to remove duplication, and [here](https://github.com/ThinkGeo/ClusterPointSample-ForWpf.NETCore) is a sample of it.
![Screenshot](https://github.com/ThinkGeo/RenderPointWithTextStyle-ForWpf.NETCore/blob/master/Screenshot.gif)
### About the Code The sample is rendering the points from FriscoSchools.shp. One thing needs to be aware of: Column name is required for grabbing the corresponding attributes for each record in the shapefile. Here we pass in a column (“textColumn”) which doesn't exist in the data, that raises CustomColumnFetch event in which we can simply return the glyph content we are going to draw for each feature.
```csharp
  ShapeFileFeatureLayer shapeFileFeatureLayer = new ShapeFileFeatureLayer("AppData/FriscoSchools.shp");
  // CustomColumnFetch event is raised every time the layer is fetching a column which doesn't exist.
  // In this example as "textColumn" does not exist in the shape file, CustomColumnFetch event
  // will be raised so give us a way to programmatically filling it in.
  shapeFileFeatureLayer.FeatureSource.CustomColumnFetch += FeatureSource_CustomColumnFetch;
  // Use a font glyph to render a point.
  // This font in the sample can be downloaded at https://thinkgeo.com/map-icons-webfont.
  GeoFont geoFont = new GeoFont("AppData/vectormap-icons.ttf", 20);
  TextStyle textStyle = new TextStyle("textColumn", geoFont, GeoBrushes.Yellow);
  // "textColumn" doesn't exist in the shape file, this is why CustomColumnFetch is raised.
  shapeFileFeatureLayer.ZoomLevelSet.ZoomLevel01.CustomStyles.Add(textStyle);
  shapeFileFeatureLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
  private void FeatureSource_CustomColumnFetch(object sender, CustomColumnFetchEventArgs e)
      // "\ue0aa" is the school zone glyph content in ThinkGeo Web Font.
      // Visit https://thinkgeo.com/map-icons-webfont and you can find more glyph icons from ThinkGeo.
      e.ColumnValue = "\ue0aa";
### Getting Help
Get Feature Clicked On With Projection Sample for Wpf
While the function GetFeaturesNearestTo as used in “Get Feature Clicked On” works quickly and is adequate in most cases, it is not guaranteed to get the closest feature. In contrast, with the new function GetFeaturesWithinDistanceOf, you can loop through the features within a specified tolerance and get their exact distance. While this approach requires some more code, it is guaranteed to get the closest feature in any case.
This sample also demonstrates another aspect of distance queries. We have the layers projected to the Google Map projection from WGS84, and you'll notice that the aforementioned distance functions (GetFeaturesWithinDistanceOf and GetFeaturesWithinDistanceOf) work seamlessly without requiring the developer to worry whether the layers are projected or not.
Screenshot
Apply DirectionPointStyle for LineStyle for Wpf
Description
The Map Suite WPF ApplyDirectionPointStyleForLineStyle sample will guide you to draw lineStyle's direction Point on map. The direction Point can be an image or a glyph, it not only rotates the icon accross the angle of the road, but also provides a way to customize the rotation of the direction point. The arrows highlighted in the red circle in the following screenshot are customized based on the line's attributes. Please check out the source for detail. This sample supports Map Suite 10.5.8 and higher.
Screenshot
About the Code
// Set up the line style with white inner pen and black center pen.
var lineStyle = new LineStyle(new GeoPen(GeoColors.Black, 16) { StartCap = DrawingLineCap.Round, EndCap = DrawingLineCap.Round }, new GeoPen(GeoColors.White, 13) { StartCap = DrawingLineCap.Round, EndCap = DrawingLineCap.Round });
// Set up the required column name for the style. We will customize the line style based on this column value.
lineStyle.RequiredColumnNames.Add("FENAME");
// Set up the style for Direction Point and set up the event for customization.
lineStyle.DirectionPointStyle = new PointStyle(new GeoImage("AppData\\Arrow.png"));
lineStyle.DrawingDirectionPoint += LineStyle_DrawingPointStyle;
private void LineStyle_DrawingPointStyle(object sender, DrawingDirectionPointEventArgs e)
    // Customize the direction point for the line feature whose "FENAME" column equals to "Mo-Pac".
    if (e.Line.ColumnValues["FENAME"] == "Mo-Pac")
        e.RotationAngle = 0;
Getting Help
About ThinkGeo
File Geo Database Viewer Sample for Wpf
Description
Screenshot
About the Code
layerOverlay = new LayerOverlay();
layer = new FileGeoDatabaseFeatureLayer(@"..\..\..\AppData\Shapes.gdb");
layer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857);
layer.ZoomLevelSet.ZoomLevel01.DefaultLineStyle = new LineStyle(new GeoPen(GeoColors.Green));
layer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = new PointStyle(PointSymbolType.Circle, 5, new GeoSolidBrush(GeoColors.Red));
layer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = new AreaStyle(new GeoPen(GeoColors.Black));
layerOverlay.Layers.Add(layer);
mapView.Overlays.Add(layerOverlay);
Getting Help
About ThinkGeo
In this sample we show you how to add robust printing support to your Map Suite applications for the WPF. Using the code in this sample, you'll be able to build a Print Preview interface that lets your users interactively arrange items on a virtual page before printing the result to a printer, exporting to a PDF or to a bitmap image. The printing system also print maps with multi pages or print multi maps to one page.
Screenshot
Distance Query On Wrap Dateline Mode Sample for Wpf
This WPF sample shows how to take advantage of the projection class WrapDatelineProjection for doing spatial queries when on a “virtual map”. From this spatial query example, the developer should understand how the same principle using the same projection class can be applied for other operations such as Spatial Queries, Identify, etc.
Screenshot
Get Features From Arc GIS Server Sample for WPF
In this wpf-based project, it illustrates how to get the features from the ArcGIS Restful Server. On the left side of the screenshot shows the raster data from ArcGIS Server and on the other side shows the features from ArcGIS Restful Server. In order to run this project, you will need the Development Build 9.0.482.0 or later.
Screenshot
This sample demonstrates how you can draw the map with Vector Tiles requested from ThinkGeo Cloud Services in your Map Suite GIS applications, with any style you want from StyleJSON (Mapping Definition Grammar). It will show you how to use the XyzFileBitmapTileCache and XyzFileVectorTileCache to improve the performance of map rendering. It supports have 3 built-in default map styles and more awasome styles from StyleJSON file you passed in, by 'Custom': - Light - Dark - TransparentBackground - Custom
Screenshot
Styles With Inmemory Feature Layer Sample for Wpf
Screenshot
ThinkGeo Cloud Reverse Geocoding Sample for Wpf
This Sample demonstrates how you can use ThinkGeo Cloud Client to get meaningful addresses from ThinkGeo GIS Server by a geographic location. It ships with an optimized set of worldwide coverage of cities and towns, but any customized data can be supported as well.
Screenshot
CustomZoomLevel for ThinkGeoCloudRasterOverlay for Wpf
Description
The Map Suite WPF CustomZoomLevelForThinkGeoCloudRasterOverlay sample will guide you to how to draw map with custom zoomlevels. This CustomZoomLevelForThinkGeoCloudRasterOverlay sample supports Map Suite 10.0.0.0 and higher and will show you how to create a WPF application using Map Suite WPF components.
Screenshot
About the Code
ThinkGeoCloudMapsZoomLevelSet thinkGeoCloudMapsZoomLevelSet = new ThinkGeoCloudMapsZoomLevelSet();
ThinkGeoCloudMapsZoomLevelSet customZoomLevelSet = new ThinkGeoCloudMapsZoomLevelSet();
customZoomLevelSet.CustomZoomLevels.Clear();
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[3].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[4].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[5].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[6].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[7].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[8].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[9].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[10].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[11].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[12].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[13].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[14].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[15].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[16].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[17].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[18].Scale));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[19].Scale));
double zoomlevel17Scale = thinkGeoCloudMapsZoomLevelSet.CustomZoomLevels[19].Scale;
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(zoomlevel17Scale / 2));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(zoomlevel17Scale / 4));
customZoomLevelSet.CustomZoomLevels.Add(new ZoomLevel(zoomlevel17Scale / 8));
Getting Help
About ThinkGeo
Display Wms Raster Layer Sample for WinForms
Screenshot
ThinkGeo Cloud Maps Sample for Android
Screenshot
ThinkGeo Cloud Maps Sample for iOS
Screenshot
ThinkGeo Cloud Maps Sample for WebForms
Screenshot
ThinkGeo Cloud Maps Sample for WinForms
Screenshot
ThinkGeo Cloud Maps Sample for Mvc
Screenshot
Display ThinkGeo Cloud Maps Sample for JavaScript
Screenshot
Web for WebAPI Samples
Quickstart Sample for WebApi
The Map Suite WebAPI illustrated QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. This edition of the QuickStart Guide supports Map Suite WebAPI 10.0.0.0 and higher and will show you how to create a ASP.NET WebAPI application using this product.
Screenshot
Quickstart Sample for WebApi .NetCore
Description
The guide will show you through the process of creating a sample of WebAPI application for rendering a shapefile with ThinkGeo.UI.WebApi and will help you become familiar with ThinkGeo Products. The Quickstart Guide supports ThinkGeo UI for WebApi 12.0 and higher.
![Screenshot](https://github.com/ThinkGeo/QuickstartSample-ForWebApi.NetCore/blob/master/Screenshot.png)
About the Code
API
First, we need to create an API for reponding the getting tile requests. The code snippet shows like below:
    [ApiController]
    [Route("")]
    public class DefaultController : ControllerBase
        [Route("tile/{z}/{x}/{y}")]
        public IActionResult GetMapTile(int z, long x, long y)
            // Create the LayerOverlay for displaying the map.
            var countriesLayer = new ShapeFileFeatureLayer(Path.Combine(Directory.GetCurrentDirectory(), "wwwroot", "AppData", "Countries.shp"));
            // Set the style for ZoomLevels.
            countriesLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = new AreaStyle
                FillBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)),
                OutlinePen = new GeoPen(GeoColors.Gray, 1)
            countriesLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = new TextStyle("CNTRY_NAME", new GeoFont("Arial", 10), GeoBrushes.Black);
            // Apply the zoom level's style to zoom level 20.
            countriesLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20;
            // Apply ProjectionConverter. The source is in DecimalDegree and needs to be convert to Mercator Projection.
            countriesLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857);
            // Initialize a LayerOverlay.
            var layerOverlay = new LayerOverlay();
            layerOverlay.Layers.Add(countriesLayer);
            return DrawTileImage(layerOverlay, z, x, y);
        private IActionResult DrawTileImage(LayerOverlay layerOverlay, int z, long x, long y)
            // Create a new GeoImage
            using (GeoImage image = new GeoImage(256, 256))
                var geoCanvas = GeoCanvas.CreateDefaultGeoCanvas();
                // Get the BoundingBox for the specified x, y, z.
                RectangleShape boundingBox = WebApiExtentHelper.GetBoundingBoxForXyz(x, y, z, GeographyUnit.Meter);
                geoCanvas.BeginDrawing(image, boundingBox, GeographyUnit.Meter);
                if (layerOverlay != null)
                    layerOverlay.Draw(geoCanvas);
                geoCanvas.EndDrawing();
                return File(image.GetImageBytes(), "image/png");
Client Side
Now we need to create a client side to consume the API, in this sample, we use OpenLayers v6.0.1.
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <title>QuickStart</title>
    <meta name="viewport" content="width=device-width, initial-scale=1.0, maximum-scale=1.0, user-scalable=no" />
    <meta http-equiv="content-type" content="text/html; charset=utf-8" />
    <meta name="author" content="ThinkGeo" />
    <link rel="stylesheet" href="https://cdn.jsdelivr.net/gh/openlayers/openlayers.github.io@master/en/v6.0.1/css/ol.css" type="text/css">
    <style>
        #map {
            height: 600px;
            width: 800px;
    </style>
</head>
<body>
    <div id="map">
    </div>
    <script src="https://cdn.jsdelivr.net/gh/openlayers/openlayers.github.io@master/en/v6.0.1/build/ol.js"></script>
    <script>
        var map = new ol.Map({
            target: 'map',
            layers: [
                new ol.layer.Tile({
                    source: new ol.source.XYZ({
                        url: '/tile/{z}/{x}/{y}'
            view: new ol.View({
                center: [-472202, 5009377.08569731],
                zoom: 1
    </script>
</body>
</html>
Getting Help
About ThinkGeo
Display Cad File Sample for WinForms
Screenshot
Layers Sample for WebApi
This sample shows the different types of layers and data formats you can use to build up your map.
Screenshot
Display Nautical Charts Sample for WebApi
This sample shows how you can use Map Suite WebAPI Edition to display nautical charts in your web application.
Screenshot
ThinkGeo Cloud Vector Maps Sample for WebApi
This sample demonstrates how you can draw the map with Vector Tiles requested from ThinkGeo Cloud Services in your Map Suite GIS applications, with any style you want from StyleJSON (Mapping Definition Grammar). It will show you how to use the XyzFileBitmapTileCache and XyzFileVectorTileCache to improve the performance of map rendering. It supports 3 built-in default map styles and more awasome styles from StyleJSON file you passed in, by 'Custom': - Light - Dark - TransparentBackground - Custom
Screenshot
Getting Started Sample for WebApi
This sample shows you how to get started building your first application with the Map Suite WebAPI Edition.
Screenshot
Site Selection Sample for WebApi
This sample template allows you to view, understand, interpret, and visualize spatial data in many ways that reveal relationships, patterns, and trends. In this example, the user can apply the features of GIS to analyze spatial data to efficiently choose a suitable site for a new retail outlet.
Screenshot
Routing Data Explorer Sample for Wpf
How to use this tool:
1. Load rtg data:  Click menu “File→Load” browse to a rtg file. You also require a shapefile for the routing source file in the same folder, otherwise it display message “Could not find shp file in the same folder where you seleted”. 2. Start routing:
Screenshot
Screenshot
Hello World Sample for WebApi
This sample shows you how to get started building your first application with the Map Suite Web for WebApi 10.0.0.
Screenshot
Select Feature By Click Sample for WebApi
The purpose of this project is to show the technique for finding the feature the user clicked on. To give the user the expected behavior, a buffer in screen coordinates needs to be set so that the feature gets selected within a constant distance in screen coordinates to where the user clicked, regardless of the zoom level.
Screenshot
Building 3D JS Sample for WebApi
This project shows to create a simulated 3D buildings and use world map kit server as background map.
Screenshot
Query Tools Sample for WebApi
This sample shows the different ways you can query your data.
Screenshot
Screenshot
View this sample on Github # HowDoISample-ForWebAPI
### Description
The “How Do I?” samples collection is a comprehensive set containing dozens of interactive samples. Available in C# (WebAPI), these samples are designed to hit all the highlights of ThinkGeo WebAPI UIs, from simply adding a layer to a map to performing vehicle tracking and applying a thematic style. Consider this collection your “encyclopedia” of all the ThinkGeo basics and a great starting place for new users.
Please refer to [ThinkGeo Web UI for WebAPI](https://thinkgeo.com/gis-ui-web) for the details.
![Screenshot](https://github.com/ThinkGeo/HowDoISample-ForWebAPI/blob/master/Screenshot.gif)
### About the Code Backgrounds for this sample are powered by ThinkGeo WebAPI Maps samples, please refer to [Online Sample](https://samples.thinkgeo.com/webapi/) for more details, in each sample, you can click the “View Source” button in the upper-right corner to get the sample code, Also here is [an entrance](https://gitlab.com/thinkgeo/public/thinkgeo-web-maps/-/tree/master/samples/web-api) for source code list.
### FAQ - Q: How do I make background map work? A: Backgrounds for this sample are powered by ThinkGeo Cloud Maps and require a Client ID and Secret. These were sent to you via email when you signed up with ThinkGeo, or you can register now at https://cloud.thinkgeo.com. Once you get them, please update the code in property ApiKey=“” in RazorControl partial classes.
### Getting Help
[ThinkGeo Community Site](https://community.thinkgeo.com)
[ThinkGeo Web Site](https://www.thinkgeo.com)
Adornments Sample for WebApi
Learn how to add legends, scale bars, directional arrows, and many more adornments to your map.
Screenshot
Projection Sample for WebApi
Learn about Map Projection and how to apply it to your data.
Screenshot
Basic Styling Sample for WebApi
This sample shows you how to apply basic styles to render your vector data layers.
Screenshot
Labeling Sample for WebApi
This sample shows you how to examine different labeling techniques to make your maps informative.
Screenshot
Drawing And Editing Sample for WebApi
This sample demonstrates how to implement drawing and editing shapes into your web application.
Screenshot
Visualization Sample for WebApi
This sample shows you how to explore the different styles available to help you analyze and visualize your data.
Screenshot
Marker And Popup Sample for WebApi
This sample shows you how to make your maps more interactive by using Markers and Popups.
Screenshot
Topology Validation Sample for WebApi
This sample shows simple ways to validate topology rules.
Screenshot
Overlays Sample for WebApi
Discover how to use Overlays to build up your map, or to add existing basemaps to your application.
Screenshot
Printing Sample for WebApi
A demonstration of how to use printing with map suite that can be added to your projects.
Screenshot
ThinkGeo Cloud Maps Sample for Wpf
Screenshot
Geometric Functions Sample for WebApi
This sample shows how to explore all the different APIs for Geometric Functions.
Screenshot
Description
![Screenshot](https://github.com/ThinkGeo/CadViewerSample-ForWpf.NETCore/blob/master/Screenshot.png)
### Getting Help
### About ThinkGeo
Screenshot
Screenshot
Screenshot
Screenshot
Screenshot
Screenshot
Screenshot
Screenshot
Web for Mvc Samples
Quickstart Sample for Mvc
The Map Suite MVC QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite. The QuickStart Guide supports Map Suite 10.0.0.0 and higher and will show you how to create an ASP.NET MVC application.
Screenshot
Vehicle Tracking Sample for Mvc
Screenshot
Screenshot
Hello World Sample for Mvc
This sample shows you how to get started building your first application with the Map Suite Web for Mvc 10.0.0.
Screenshot
How Do I Sample for Mvc
The “How Do I?” samples collection is a comprehensive set containing a lot of interactive samples.
Screenshot
Site Selection Sample for Mvc
Screenshot
Us Demographic Map Sample for Mvc
Screenshot
Us Earthquake Statistics Sample for Mvc
Screenshot
Screenshot
Screenshot
Screenshot
Screenshot
View this sample on Github # Cad Viewer Sample for Wpf
### Description
### Getting Help
### About ThinkGeo
Screenshot
Screenshot
Screenshot
Screenshot
Screenshot
Screenshot
There are two ways to get the elevation data of the line. First, get the points on the line by setting the interval distance. The other, is to take the points by setting the number of points to be fetched. Then query the elevation data of the point.
Screenshot
Web for WebForms Samples
Quickstart Sample for WebForms
The Map Suite Web QuickStart Guide will guide you through the process of creating a sample application and will help you become familiar with Map Suite.
Screenshot
Create Sublayers Sample for WebForms
This sample shows you how to use FeatureSource to implement sublayer fuctions.
Screenshot
Hello World Sample for WebForms
This sample shows you how to get started building your first application with the Map Suite Web for WebForms 10.0.0.
Screenshot
Display Map By Specified Boundary Sample for WebForms
This sample shows how to display map by specified boundary. It shows how to cancel a request based on its extent to improve performance.
Screenshot
Us Demographic Map Sample for WebForms
Screenshot
Geocoding Sample for WebForms
Sample Data Download
Screenshot
RoutingSample-ForWebForms
Screenshot
Ajax Vehicle Tracking Sample for WebForms
The Ajax Vehicle Tracking sample template gives you a head start on your next ajax tracking project. With a working code example to draw from, you can spend more of your time implementing the features you care about and less time thinking about how to accomplish the basic functionality of a ajax tracking system.
Screenshot
Screenshot
Us Earthquake Statistics Sample for WebForms
Screenshot
Screenshot
Edit Overlay Styles Sample for WebForms
This Web project demonstrates how to control the styles of the EditOverlay, for both the default style and the editing style. In order to accomplish this, we use javascript code. Look at the code in the *script* tag to see how we can control the fill color, the opacity, the border width, and other attributes of the features in the EditOverlay.
Screenshot
How Do I Sample for WebForms
Screenshot
Site Selection Sample for WebForms
Screenshot
map_suite_all_samples.1488422456.txt.gz · Last modified: 2017/03/02 02:40 by tgwikiupdate
