ThinkGeo Wiki is the central and official source of documentation, sample code and learning material for ThinkGeo users. It contains resources such as API reference, Quickstart Guides to get you started, sample projects with source code you can learn from, change logs for each version, and more.
Overview
Give you an overview picture on ThinkGeo Cloud
Client Keys Guideline
Help you apply a key and consume it in your application.
Online Documentation
The Documentation for all ThinkGeo Cloud Services.
Online Samples
The samples showing off what can be done with ThinkGeo Cloud.
Sample Gallery
It shows samples on different platforms including Desktop, Mobile and Web.
.NET SDK
An easier way to consume ThinkGeo Cloud in an .NET application.
ThinkGeo provides feature-rich .NET controls based on different platforms and different technology. They are available on NuGet, as long as many other ThinkGeo Map Suite NuGet packages which are shared among ThinkGeo UI controls, and that's why the majority of the APIs among different UI controls are the same. Here is a platform coverage showing what feature package is shared across different products.
Mobile for Android
Mobile for iOS
Desktop for WPF
Build Windows client apps using WPF (Windows Presentation Foundation)
Desktop for WinForms
Build Windows client apps using Windows WinForms.
Web for WebAPI
Build REST based web services for JS/HTML5 Web applications.
Web for MVC
Web for WebForms
Build traditional ASP.NET Web Forms mapping applications.
ThinkGeo provides the following Add-Ons and offline data, which is the same one ThinkGeo Cloud is using. The data can be properly consumed by ThinkGeo UI Controls Offline.
Routing
Find the shortest path between multiple locations, deliver turn-by-turn directions, avoid specified areas.
Maps Streets
Royalty-free worldwide vector data ready to use in your application.
Maps Imagery
Royalty-free high-level global imagery matched with highly-detailed US imagery.
Geocoding
Convert US addresses to coordinates and vice-versa
Reverse-Geocoding
Reverse-geocoding allows you to match a latitude and longitude location to a street address anywhere on earth.
Elevation
Global elevation point, contour, and viewshed at your fingertips
ThinkGeo provides following open Open Source libraries, all available on Github.
VectorMap.js
A JavaScript rendering engine works with any data including ThinkGeo Cloud Vector Tiles.
StyleJSON
A ThinkGeo styling format can be used with VectorMap.js and other ThinkGeo products.
Icons Font
ThinkGeo Web Fonts library.
