ThinkGeo Wiki is the central and official source of documentation, sample code and learning material for ThinkGeo users. It contains resources such as API reference, Quickstart Guides, sample projects with source code, change logs for each version, and more.
Overview
A general overview of ThinkGeo Cloud
Client Keys Guide
A guide to generating an API key and applying it into your application
Online Documentation
The Documentation for all ThinkGeo Cloud Services.
Online Samples
The samples showing off what can be done with ThinkGeo Cloud.
Sample Gallery
Additional samples for our other development platforms including Desktop, Mobile and Web.
.NET SDK
An easier way to consume ThinkGeo Cloud in an .NET application.
ThinkGeo provides feature-rich .NET controls based on different platforms and different technologies. They are available on NuGet, as well as many other ThinkGeo Map Suite NuGet packages which are shared amongst ThinkGeo UI controls which is why you will notice the majority of the APIs sharing common descriptions and samples. Here is a breakdown of platform coverage showing what feature package is shared across different products.
Mobile for Android
Mobile for iOS
Desktop .NET Framework
Build Windows client for the tranditional .NET Framework
Desktop for .NET Core
Build Windows client for the cross platform framework: .NET Core
Web for .NET Framework
Build Web apps using for the tranditional .NET Framework
Web for .NET Core
ThinkGeo provides the following Add-Ons and offline data, which happen to be the same as what ThinkGeo Cloud is using. The data can be properly consumed by ThinkGeo UI Controls Offline.
Routing
Find the shortest path between multiple locations, deliver turn-by-turn directions, avoid specified areas.
Maps Streets
Royalty-free worldwide vector data ready to use in your application.
Maps Imagery
Royalty-free high-level global imagery matched with highly-detailed US imagery.
Geocoding
Convert US addresses to coordinates and vice-versa
Reverse-Geocoding
Reverse-Geocoding allows you to match a latitude and longitude location to a street address anywhere on Earth.
Elevation
Get the elevation of a point on the earth.
ThinkGeo provides the following open Open Source libraries, all available on Github.
VectorMap.js
A JavaScript rendering engine works with any data including ThinkGeo Cloud Vector Tiles.
StyleJSON
A ThinkGeo styling format can be used with VectorMap.js and other ThinkGeo products.
Icon Fonts
ThinkGeo Icon Fonts library.
