This is a complete list of the methods exposed in the Cygnus Track 6.0 web portal web services. These services allow you to manipulate your Cygnus Track web portal accounts, users, departments, devices and more.
The web service APIs are divided into two groups: Account APIs and Installation APIs. Account APIs are available to all Cygnus Track editions, while Installation APIs are available only to users of Cygnus Track Hosted, Enterprise and Integrator Editions.
The following services are available and documented; click on the name of a service below to jump directly to its part of the reference guide.
NOTE: This page and its contained pages are a work in progress. The complete Cygnus Track Developer Center content is currently available on the ThinkGeo website in the Cygnus Track Developer Center.
Available in all Cygnus Track editions
Parameters:
securityKey | Required,user ID | |
accountID | Required, Account ID | |
Return value: String
Function description: Gets an organization from an account.
Parameters:
userName | Required, user name for authentication | |
password | Required, password for authentication | |
Function description: Gets all organizations from an account.
Parameters:
orgID | Required, Organization ID | |
Function description: Gets an organization.
Parameters:
accountID | Required, account ID | |
orgName | Required, organization name | |
Description | Organization description | |
mapDataID | Required, map Data ID | |
timeZone | Required, time zone of the organization's location | |
metric | Required, selects whether the organization's unit system is metric or imperial | |
status | Required, organization status, must be ACTIVE or INACTIVE, default is ACTIVE | |
externalID | Required, Reserved field | |
Return value: OrganizationID
Function description: Creates an organization.
Parameters:
userName |
password |
accountID |
orgID |
orgName |
description |
manager |
imageName |
mapDataID |
timeZone |
metric |
status |
externalID |
Function description: Edits an organization.
Parameters:
userName |
password |
orgID |
Function description: Deletes an organization in the system.
Parameters:
userName |
password |
orgID |
deviceID |
Function description: Adds a device to an organization.
Parameters:
userName |
password |
orgID |
carrierID |
Function description: Adds a carrier to an organization.
Parameters:
userName |
password |
orgID |
monitorID |
Function description: Adds a monitor to an organization.
Parameters:
Function description: Gets the carriers in an organization.
Parameters:
Function description: Gets the devices in an organization.
Parameters:
Function description: Gets the monitors in an organization.
Parameters:
carrierID | Required, carrier ID | |
Function description: Deletes a carrier from an organization.
Parameters:
deviceID | Required, device ID | |
Function description: Deletes a device from an organization.
Parameters:
monitorID | Required, monitor ID | |
Function description: Deletes a monitor from an organization.
Parameters:
Function description: Gets all available map data for an account.
Parameters:
adminUserName | Required, admin user name for authentication | |
adminPassword | Required, admin password for authentication | |
name | Required, Monitor name | |
description | Monitor description | |
userName | Required, user name | |
password | Required, password | |
entryReference | Required, selects which page is the default entry page - Dashboard or Map Area | |
status | Required, monitor status, must be ACTIVE or INACTIVE, default is ACTIVE | |
externalID | Reserved field | |
Return value: MonitorID
Function description: Creates a monitor.
Parameters:
monitorID | Monitor ID | |
Function description: Edits a monitor.
Parameters:
MonitorID | Required, Monitor ID | |
Function description: Deletes a monitor from the system.
Parameters:
Function description: Gets a monitor.
Parameters:
Function description: Gets monitors from an account.
Parameters:
Function description: Gets monitors from an organization.
Parameters:
Function description: Gets users from an account.
Parameters:
userID | Required, user ID | |
Function description: Gets a user.
Parameters:
status | Required, user status, must be ACTIVE or INACTIVE, default is ACTIVE | |
firstName | First name | |
lastName | Last name | |
emailAddress | Email address | |
activateDate | Activation date | |
deactiveDate | Deactivation date | |
allowMultipleSessions | Whether to enable multiple sessions, which allow the same user to be logged in more than once simultaneously | |
checkMessageInterval | Check message interval | |
Return value: UserID
Function description: Creates a user.
Parameters:
Function description: Edits a user.
Parameters:
Function description: Deletes a user from the system.
Parameters:
newPassword | Required, new password | |
Function description: Change a user's password.
Parameters:
username | Required, the user name to check for | |
Return value: bool
Function description: Checks whether a specified username is in use.
Parameters:
emailAddress | Required, the email address to check for | |
Return value: bool
Function description: Checks whether a specified user email address is in use.
Parameters:
securityKey | Required, user ID | |
organizationID | Required, organization ID | |
Function description: Gets the devices from an organization.
Parameters:
accountid | Required, account ID | |
Function description: Gets the devices from an account.
Parameters:
orgID | Required, organization ID | |
Function description: Gets all devices from an organization.
Parameters:
Function description: Gets the device categories.
Parameters:
Function description: Gets a device.
Parameters:
deviceName | Required, device name | |
description | Device description | |
topSpeed | Required, top speed | |
status | Required, device status, must be ACTIVE or INACTIVE, default is ACTIVE | |
imei | Required, International Mobile Equipment Identifier (IMEI) or Electronic Identifier (EID) of the wireless modem | |
cannedMessage | Required, specifies whether or not the device supports two-way communication | |
deviceCategoryID | Device category ID | |
colorCode | Choose a color to associate with the device, default is a random color | |
Return value: DeviceID
Function description: Creates a device.
Parameters:
Function description: Edits a carrier.
Parameters:
Function description: Delete a device from the system.
Parameters:
Function description: Gets the carriers from an account.
Parameters:
Function description: Gets the carriers from an organization.
Parameters:
Function description: Gets a carrier's device.
Parameters:
Function description: Gets a carrier.
Parameters:
carrierName | Required, carrier name | |
carrierPin | Carrier's personal identification number, the default value is 0000 | |
status | Required, carrier status, must be ACTIVE or INACTIVE, default is ACTIVE | |
Return value: CarrierID
Function description: Creates a carrier.
Parameters:
description | Required, description of the carrier | |
otherInformation | Other information about the carrier, HTML supported. Will be displayed in a popup bubble on the tracking screen. | |
Parameters:
Function description: Deletes a carrier from the system.
Parameters:
Function description: Assigns a device to a carrier.
Parameters:
Function description: Disassociates a device from a carrier.
Parameters:
severity | Required, severity level | |
Function description: Loads an event response for an account.
Parameters:
Function description: Loads an event response for an organization.
Parameters:
additionalEmailAddresses | Required | |
alertPopupAction | Required, popup action | |
alertThreshold | Required, alert threshold | |
friendlyName | Required, friendly name | |
iconPath | Required | |
noisePath | Required | |
overridden | Required | |
overrides | Required | |
repeat | Required | |
sendEmail | Required | |
severityColor | Required | |
Function description: Edits an event response for an account.
Parameters:
Function description: Edits an event response for an organization.
Parameters:
IMEI | Required, Device IMEI | |
locationID | Required, New Guid | |
logTime | Required, GPS date time of message | |
ypoint | Required, Latitude | |
xpoint | Required, Longitude | |
altitude | Required, altitude | |
speed | Required, device speed | |
travelDirection | Required, Travel Direction | |
speedUncertainty | Required, Speed Uncertainty or not | |
responseCode | Required | |
assistanceUsed | Required | |
Return value: LocationID
Function description: Create a location for device.
Parameters:
locationID | Required | |
Function description: Get current location for the device.
Parameters:
lsessionD | Required | |
Function description: Get locations for the session.
<small>Available in Cygnus Track Hosted, Enterprise, and Integrator editions only</small>
Parameters:
installUserName | Required, installer user name for authentication | |
installPassword | Required, installer password for authentication | |
adminUserName | Required, admin user name for the account | |
adminPassword | Required, admin password | |
accountName | Required, account name | |
status | Required, account status, must be ACTIVE or INACTIVE, default is ACTIVE | |
activateDate | Account activation date | |
deactivateDate | Account deactivation date | |
manageSecurity | Can manage security or not | |
manageBrand | Can manage brand or not | |
processLocationInfo | Can process Location Information of map or not in account level | |
termsOfUse | Can use terms of use or not | |
orgLimit | Organization limit, default is -1 (unlimited) | |
monitorLimit | Monitor limit, default is -1 (unlimited) | |
carrierLimit | Carrier limit, default is -1 (unlimited) | |
deviceLimit | Device limit, default is -1 (unlimited) | |
targetLimit | Target limit, default is -1 (unlimited) | |
areaLimit | Area limit, default is -1 (unlimited) | |
securityPath | If Two-Factor Authentication is enabled in Account General Settings, the security binary path will be used to judge whether or not this account is TwoFactorSecurity Valid when a user logs in. | |
Return value: AccountID
Function description: Creates an account at the installer level.
Parameters:
installerPassword | Required, installer password for authentication | |
Function description: Checks to see whether the account exists in the system.
Parameters:
Function description: Gets all of the accounts under this installation.
Parameters:
Function description: Edits an account at the installer level.
Parameters:
Function description: Deletes an account in the system at the installer level.
Parameters:
Function description: Gets a list of languages available in the installation.
Parameters:
languageID | Required, language ID | |
Function description: Gets a language.
Parameters:
Function description: Gets a list of the available system languages.
Parameters:
Function description: Deletes a language.
Parameters:
languageName | Required, language name | |
isSystem | Required | |
Status | Required, status | |
Function description: Creates a new language.
Parameters:
Function description: Edits a language.
Parameters:
Function description: Sets the language for a user.
Return to the: Cygnus Track Developer Center
