Have questions? Call us toll-free at 1-866-847-7510 (outside North America, call 1-785-727-4133)
Map Suite Routing FAQ All Questions
From ThinkGeo Wiki
Jump to: navigation, search
Contents
How is the Map Suite Routing Extension Licensed?
The Map Suite Routing Extension is licensed on a per developer and per production server basis. If you are deploying your routing solution inside a desktop application then all deployment is royalty-free and all that is needed is a developer license. However, if your routing solution is utilizing a Web or centralized server, additional production server licenses are required.
What type of data can I use with the Map Suite Routing Extension?
The Map Suite Routing extension can be used with virtually any type of dataset. By utilizing the flexible feature source support inside of Map Suite, you can easily read ShapeFile data, SQL Server 2008 data and Oracle Spatial data, just to name a few examples. Additionally, with Map Suite's extensible framework, you can even build support for your own proprietary formats.
How does the Map Suite Routing Extension integrate in with the other Map Suite products?
The Map Suite Routing Extension provides a routing layer class that will allow you to easily add and display routes on your map using any of the Map Suite 3.x editions (Desktop, Web, Silverlight or Services).
What types of scenarios is the Map Suite Routing plug-in commonly used for?
The Map Suite Routing Extension was built for doing routing within a localized area such as your metro area, county or city. However, with the flexible API that the Map Suite Routing Extension offers, you are free to implement a routing solution that meets your specific needs.
How do I find the points of interests within certain distance of a route?
Sample:POI on Route
In today’s project, we are looking at the Routing extension of Map Suite. As a reinforcement of what we learned in the samples of “How Do I”, we show how to find the shortest route between the start and the end point. In addition to that, we show how to use the MultiLineShape from the result of the GetRoute function to do a spatial query to get the points of interests (POI) on the route. For this sample, you would need a reference of either the full or evaluation of MapSuiteCore.dll and MapSuiteRouting.dll.
Sample:POI on route(Advanced)
In the project “POI on route”, we learned how to get the points of interests (POI) on the route within a certain buffer distance. In today’s project, we are going to go a step further and we show the technique for finding the POIs according to what side of the route they are located. For example, in the delivery industry, it is far more efficient to deliver to stops on the right side of the road when driving on the right side of the road.
How do I route in one projection and display the route information in another projection?
Sample:Routing with Projections
How do I modify data to make them one-way streets?
Sample:One Way Street Builder
In the sample apps “How Do I” of the Routing product, we have a sample that shows how the route is constructed on a one way street. Today’s project is meant to complement by showing how to set selected streets to be one way and in the desired direction. From this sample, you can create your own utility to handle your data for routing purposes.
How can I show one-way streets arrows on my roads?
How do I create a custom style to display routes?
Sample:Routing Styles
Personal tools
Variants
Actions
Products
Data
Add Ons
Navigation
Toolbox
Learn More About Map Suite, Download a Free Trial, or Buy Now
GIS Developer Components for .NET
Map Suite Extensions & Add-Ons
Map Data Sets & Icons
Try Map Suite Free
Map Suite Online Store
sales@thinkgeo.com
1-866-847-7510 (Toll-Free)
1-785-727-4133 (Outside North America)
ThinkGeo LLC
2801 Network Blvd. Suite 215
Frisco, TX 75034
Map Suite Support Center
