This page tells how to copy the necessary dlls into target folders, if you want to download the dlls yourself instead of use NuGet.
You should want to download all the packages(.nupkg file) from NuGet.org at first.
You can visit the www.nuget.org, find target package you want to get and click download button in the page.
In fact the .nupkg file is a zip package, so you can unzip them by some common utilities for example 7-zip.
There are three types directory structure for the unzipped package
The list shows the packages:
You can find the valid dlls under lib/net45, you only need reference the dlls in your project.
Its name should be looks like: ThinkGeo.MapSuite.xxx.xxx.10.x.0 or ThinkGeo.MapSuite.xxx.10.1.0
The dlls under lib/net45 is used for reference in project.
And if you found folders and dlls under build/net45, you need to copy them to your debug folder (bin folder).
The package name is started with MapSuiteDependency
We need handle it like this:
