To get started with ThinkGeo UI Web for Blazor, you first need to install the .NET Core 3.0 SDK. You'll also want an IDE, such as Visual Studio 2019 (version 16.3 or newer) or Visual Studio Code. For this quick start guide, we'll be using Visual Studio Code. More information about the tools you can use to work with Blazor, please refer to the Microsoft documentation on how to get started with ASP.NET Core Blazor.
NOTE: ThinkGeo UI Web for Blazor currently only supports server-side Blazor projects, so in this guide we will walk you through the process of creating a server-size Blazor sample. ThinkGeo intends to support client-side Blazor projects with WebAssembly once Microsoft's client-side Blazor framework has left preview.
Once your environment and tooling are set up, let's create a Blazor project.
dotnet new blazorserver -o QuickStart
Now, you have successfully created a server-side Blazor boilerplate project. Next, we'll be adding the ThinkGeo UI map control to the web page. If you have encountered any issues getting to this point, please refer to the Microsoft documentation on getting started with ASP.NET Core Blazor.
To build this sample, you need to reference the “ThinkGeo.UI.Blazor” package from NuGet Package Manager. NuGet brings us a flexible way and pleasant experience to manage our references.
Now, we have all the references set. let's start by writing code step by step to display a world map.
@using ThinkGeo.Core @using ThinkGeo.UI.Blazor
<head> ... <link href="https://cdn.thinkgeo.com/blazor/1.0.0/blazor.css" rel="stylesheet" /> </head> <body> ... <script src="https://cdn.thinkgeo.com/blazor/1.0.0/blazor.js"></script> </body>
@page "/" <!--You can control the width and height in CSS too, if you like. --> <MapView Id="demomap" MapUnit="@ThinkGeo.Core.GeographyUnit.Meter" Zoom="3" Width="800" Height="600"> <OverlaysSetting> <ThinkGeoCloudRasterMapsOverlay Id="RasterOverlay" MapType="ThinkGeo.Core.ThinkGeoCloudRasterMapsMapType.Light" ApiKey="Input your key"></ThinkGeoCloudRasterMapsOverlay> </OverlaysSetting> </MapView>
It requires an APIKey of ThinkGeo Cloud, and you can get the API Key from the registration email. If you don't have an account of ThinkGeo Cloud yet, please refer to ThinkGeo Cloud Client Keys to get your ThinkGeo Cloud account.
Run the app by pressing F5. If you have not set up a developer license, the Map Suite Product Center will pop up. You will need to activate your developer license, either by starting a free evaluation of ThinkGeo UI Web for Blazor, or by purchasing the full edition of the product. For more details, please refer to our developer license guide.
Once your developer license is ready, run the application. Your map should look like the one below:
