To get started with ThinkGeo UI Web for Blazor, you first need to install the .NET Core 3.0 SDK. You'll also want an IDE, such as Visual Studio 2019 (version 16.3 or newer) or Visual Studio Code. For this quick start guide, we'll be using Visual Studio 2019. More information about the tools you can use to work with Blazor, please refer to the Microsoft documentation on how to get started with ASP.NET Core Blazor.
NOTE: ThinkGeo UI Web for Blazor currently only supports server-side Blazor projects, so in this guide we will walk you through the process of creating a server-size Blazor sample. ThinkGeo intends to support client-side Blazor projects with WebAssembly once Microsoft's client-side Blazor framework has left preview.
Once your environment and tooling are set up, let's create a Blazor project.
Now, you have successfully created a server-side Blazor boilerplate project. Next, we'll be adding the ThinkGeo UI map control to the web page. If you have encountered any issues getting to this point, please refer to the Microsoft documentation on getting started with ASP.NET Core Blazor.
To build this sample, you need to reference the component package from NuGet Manager. NuGet brings us a flexible way and pleasant experience to manage our references.
Now, we have all the references set. let's start by writing code step by step to display a world map with Shapefile.
1. Add the following code snippet to ~/_imports.razor file to reference ThinkGeo.UI.Blazor into all components in this project:
@using ThinkGeo.Core @using ThinkGeo.UI.Blazor
2. Open the ~/Pages/_host.cshtml file in the blazor project. Register the stylesheet and javascript of ThinkGeo Web For Blazor from CDN:
<head> ... <link href="https://cdn.thinkgeo.com/blazor/1.0.0/blazor.css" rel="stylesheet" /> </head> <body> ... <script src="https://cdn.thinkgeo.com/blazor/1.0.0/blazor.js"></script> </body>
3. Open ~/wwwroot/css/site.css file and add the following stylesheet for demomap which is the element Id of map in this sample.
#demomap { width:600px; height:500px; }
4. Open ~/Pages/Index.razor file and Add a ThinkGeo.UI.Blazor.Map component at the end as following:
@page "/" <h1>Hello World!</h1> Welcome to your new app. <MapView Id="demomap" @ref="map" BackgroundColor="@backgroundColor" MapUnit="@ThinkGeo.Core.GeographyUnit.Meter" Center="@(new PointShape(-11067139.908560446, 5855996.337964549))" Zoom="3"> <OverlaysSetting> <LayerOverlay Id="CustomOverlay" Layers="@layers"></LayerOverlay> </OverlaysSetting> <MapToolsSetting> <MapTools> <ZoomBarMapTool /> </MapTools> </MapToolsSetting> </MapView> @code{ GeoColor backgroundColor = GeoColor.FromHtml("#89d3f0ff"); GeoCollection<Layer> layers = new GeoCollection<Layer>(); MapView map; protected override void OnInitialized() { // We create a new Layer and pass the path to a ShapeFile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer("./Data/countries/countries.shp"); worldLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); // Set the worldLayer to use a preset Style. AreaStyle areaStyle = new AreaStyle(); areaStyle.FillBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; // This setting will apply from ZoomLevel01 to ZoomLevel20, which means we can // see the world the same style all the time no matter how far we zoom in or out. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the worldLayer to the LayerOverlay in the map. layers.Add(worldLayer); } }
We'll use a ShapeFile containing data of the entire world. We have one such ShapeFile available to us:
(NOTE: The data used in this sample can be found in the attached sample above at “./Data/countries” folder)
Run the app by pressing F5. If you have not set up a developer license, the Map Suite Product Center will pop up. You will need to activate your developer license, either by starting a free evaluation of ThinkGeo UI Web for Blazor, or by purchasing the full edition of the product. For more details, please refer to our developer license guide.
Once your developer license is ready, run the application. Your map should look like the one below:
Next, let's add a ShapeFileFeatureLayer with a PointStyle for displaying the world's capital cities. We'll do this in the OnInitialized method.
protected override void OnInitialized() { // We create a new Layer and pass the path to a ShapeFile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer("./Data/countries/countries.shp"); worldLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); // Set the worldLayer to use a preset Style. AreaStyle areaStyle = new AreaStyle(); areaStyle.FillBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; // This setting will apply from ZoomLevel01 to ZoomLevel20, which means we can // see the world the same style all the time no matter how far we zoom in or out. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the worldLayer to the LayerOverlay in the map. layers.Add(worldLayer); ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer("./Data/capitals/WorldCapitals.shp"); capitalLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); PointStyle pointStyle = new PointStyle(); pointStyle.SymbolType = PointSymbolType.Square; pointStyle.FillBrush = new GeoSolidBrush(GeoColors.White); pointStyle.OutlinePen = new GeoPen(GeoColors.Black, 1); pointStyle.SymbolSize = 6; PointStyle stackStyle = new PointStyle(); stackStyle.SymbolType = PointSymbolType.Square; stackStyle.FillBrush = new GeoSolidBrush(GeoColors.Maroon); stackStyle.OutlinePen = new GeoPen(GeoColors.Transparent, 0); stackStyle.SymbolSize = 2; pointStyle.CustomPointStyles.Add(stackStyle); capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = pointStyle; // This setting also applies from ZoonLevel01 to ZoomLevel20, that means we can // see city symbols the same style with ZoomLevel01 all the time. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the capitalLayer to the LayerOverlay in the map. layers.Add(capitalLayer); }
TextStyles are used to label items on the map. Because every ShapeFile has a companion .dbf file that includes descriptions for each record, the most common way to use TextStyles is for labeling features with these descriptive values. For example, the WorldCapitals Shapefile's corresponding .dbf file contains the field “CITY_NAME”. We can use this field to label the cities on our map.
ThinkGeo.Core has many TextStyles built in to help us quickly design attractive labels for the cities on our map. We can just pick the TextStyle we like and use it.
protected override void OnInitialized() { // We create a new Layer and pass the path to a ShapeFile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer("./Data/countries/countries.shp"); worldLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); // Set the worldLayer to use a preset Style. AreaStyle areaStyle = new AreaStyle(); areaStyle.FillBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; // This setting will apply from ZoomLevel01 to ZoomLevel20, which means we can // see the world the same style all the time no matter how far we zoom in or out. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the worldLayer to the LayerOverlay in the map. layers.Add(worldLayer); ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer("./Data/capitals/WorldCapitals.shp"); capitalLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); PointStyle pointStyle = new PointStyle(); pointStyle.SymbolType = PointSymbolType.Square; pointStyle.FillBrush = new GeoSolidBrush(GeoColors.White); pointStyle.OutlinePen = new GeoPen(GeoColors.Black, 1); pointStyle.SymbolSize = 6; PointStyle stackStyle = new PointStyle(); stackStyle.SymbolType = PointSymbolType.Square; stackStyle.FillBrush = new GeoSolidBrush(GeoColors.Maroon); stackStyle.OutlinePen = new GeoPen(GeoColors.Transparent, 0); stackStyle.SymbolSize = 2; pointStyle.CustomPointStyles.Add(stackStyle); capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = pointStyle; // This setting also applies from ZoonLevel01 to ZoomLevel20, that means we can // see city symbols the same style with ZoomLevel01 all the time. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the capitalLayer to the LayerOverlay in the map. layers.Add(capitalLayer); // We create a new Layer for labeling the capitals. ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer("./Data/capitals/WorldCapitals.shp"); capitalLabelLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); GeoFont font = new GeoFont("Arial", 9, DrawingFontStyles.Bold); GeoSolidBrush txtBrush = new GeoSolidBrush(GeoColors.Maroon); TextStyle textStyle = new TextStyle("CITY_NAME", font, txtBrush); textStyle.XOffsetInPixel = 0; textStyle.YOffsetInPixel = -6; // We use the preset TextStyle. Here we passed in the “CITY_NAME”, // which is the name of the field we want to show on the map. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = textStyle; capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; layers.Add(capitalLabelLayer); }
Now that we know how to render text and render symbols, let's define two different ZoomLevel ranges in one single layer, and create our own custom Style and TextStyle.
protected override void OnInitialized() { // We create a new Layer and pass the path to a ShapeFile into its constructor. ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer("./Data/countries/countries.shp"); worldLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); // Set the worldLayer to use a preset Style. AreaStyle areaStyle = new AreaStyle(); areaStyle.FillBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214)); areaStyle.OutlinePen = new GeoPen(GeoColor.FromArgb(255, 118, 138, 69), 1); areaStyle.OutlinePen.DashStyle = LineDashStyle.Solid; worldLayer.ZoomLevelSet.ZoomLevel01.DefaultAreaStyle = areaStyle; // This setting will apply from ZoomLevel01 to ZoomLevel20, which means we can // see the world the same style all the time no matter how far we zoom in or out. worldLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the worldLayer to the LayerOverlay in the map. layers.Add(worldLayer); ShapeFileFeatureLayer capitalLayer = new ShapeFileFeatureLayer("./Data/capitals/WorldCapitals.shp"); capitalLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); PointStyle pointStyle = new PointStyle(); pointStyle.SymbolType = PointSymbolType.Square; pointStyle.FillBrush = new GeoSolidBrush(GeoColors.White); pointStyle.OutlinePen = new GeoPen(GeoColors.Black, 1); pointStyle.SymbolSize = 6; PointStyle stackStyle = new PointStyle(); stackStyle.SymbolType = PointSymbolType.Square; stackStyle.FillBrush = new GeoSolidBrush(GeoColors.Maroon); stackStyle.OutlinePen = new GeoPen(GeoColors.Transparent, 0); stackStyle.SymbolSize = 2; pointStyle.CustomPointStyles.Add(stackStyle); // We can customize our own Style. Here we passed in a color and a size. capitalLayer.ZoomLevelSet.ZoomLevel01.DefaultPointStyle = PointStyle.CreateSimpleCircleStyle(GeoColors.White, 7, GeoColors.Brown); // The Style we set here is available from ZoomLevel01 to ZoomLevel05. // That means if we zoom in a bit more, the appearance we set here // will not be visible anymore. capitalLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLayer.ZoomLevelSet.ZoomLevel06.DefaultPointStyle = pointStyle; // The Style we set here is available from ZoomLevel06 to ZoomLevel20. // That means if we zoom out a bit more, th appearance we set here // will not be visible any more. capitalLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the capitalLayer to the LayerOverlay in the map. layers.Add(capitalLayer); // We create a new Layer for labeling the capitals. ShapeFileFeatureLayer capitalLabelLayer = new ShapeFileFeatureLayer("./Data/capitals/WorldCapitals.shp"); capitalLabelLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857); GeoFont font = new GeoFont("Arial", 9, DrawingFontStyles.Bold); GeoSolidBrush txtBrush = new GeoSolidBrush(GeoColors.Maroon); TextStyle textStyle = new TextStyle("CITY_NAME", font, txtBrush); textStyle.XOffsetInPixel = 0; textStyle.YOffsetInPixel = -6; // We use the preset TextStyle. Here we passed in the “CITY_NAME”, // which is the name of the field we want to show on the map. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.DefaultTextStyle = TextStyle.CreateSimpleTextStyle("CITY_NAME", "Arial", 8, DrawingFontStyles.Italic, GeoColors.Black, 3, 3); // The TextStyle we set here is available from ZoomLevel01 to ZoomLevel05. capitalLabelLayer.ZoomLevelSet.ZoomLevel01.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level05; capitalLabelLayer.ZoomLevelSet.ZoomLevel06.DefaultTextStyle = textStyle; // The TextStyle we set here is available from ZoomLevel06 to ZoomLevel20. capitalLabelLayer.ZoomLevelSet.ZoomLevel06.ApplyUntilZoomLevel = ApplyUntilZoomLevel.Level20; // We need to add the capitalLayer to the LayerOverlay in the map. layers.Add(capitalLabelLayer); }
Below is the result.
The PointStyle will change as you zoom in.
That completes this scenario. The next thing you might want to do is to make your application run on another machine, such as a web server, that does not have a ThinkGeo UI developer license installed. For that, you'll want to install a production deployment license on your server. Check out our deployment licensing guide for further details.
