Get started with Blazor, you need .NET Core 3.0 and Visual Studio 2019 Preview. More information please refer to Get started with ASP.NET Core Blazor. (NOTE: ThinkGeo UI Web for Blazor only support server-side of Blazor currently, In this guide we are just using Blazor serverside as an example.)
Let's create a Blazor project after the environment is installed. Also you can run the project you just downloaded.
Now, you successfully created a native blazor serverside sample. See Get started with ASP.NET Core Blazor, If there are any issue during running this sample.
To build this sample, you need to reference the component package from NuGet Manager. NuGet brings us a flexible way and pleasant experience to manage our references.
Now, we have all the references set. let's start by writing code step by step to display a map with Shapefile.
@using ThinkGeo.Core @using ThinkGeo.UI.Blazor
<link href="https://cdn.thinkgeo.com/blazor/1.0.0/blazor.css" rel="stylesheet" /> <script src="https://cdn.thinkgeo.com/blazor/1.0.0/blazor.js"></script>
@page "/"
<h1>Hello, world!</h1>
Welcome to your new app.
<Map Id="demomap" @ref="map" Background="@background"
MapUnit="@ThinkGeo.Core.GeographyUnit.Meter"
Center="@(new PointShape(1056665.479014, 6066042.564712))"
Zoom="5">
<OverlaysSetting>
<LayerOverlay Id="CustomOverlay" Layers="@layers"></LayerOverlay>
</OverlaysSetting>
</Map>
@code{
GeoSolidBrush background = new GeoSolidBrush(GeoColor.FromHtml("#89d3f0ff"));
GeoCollection<Layer> layers = new GeoCollection<Layer>();
Map map;
protected override void OnInitialized()
ShapeFileFeatureLayer worldLayer = new ShapeFileFeatureLayer("./Data/countries/countries.shp");
worldLayer.FeatureSource.ProjectionConverter = new ProjectionConverter(4326, 3857);
// Set the worldLayer to use a preset Style.
areaStyle.FillBrush = new GeoSolidBrush(GeoColor.FromArgb(255, 233, 232, 214));
// We need to add the worldLayer to the LayerOverlay in the map.
layers.Add(worldLayer);
-we'll use a ShapeFile containing data of the entire world. We have one such ShapeFile available to us:
(NOTE: The data used in this sample can be found in the attached sample above at “./Data/countries” folder)
Run the App by pressing F5. you'll see a worldstreet layer like this:
Screenshot is coming soon
This completes this scenario. The next thing you might want to do is to make it run on another machine that does not have a developer license. A runtime license is the one we are looking for. Here is the guide to generate a runtime license: http://wiki.thinkgeo.com/wiki/map_suite_runtime_license_guide_for_desktop
