thinkgeo_web_for_blazor
ThinkGeo UI Web for Blazor
ThinkGeo UI Web for Blazor is a .NET Standard component using Blazor, the cutting edge technology from Microsoft.
Getting Started
You can start from getting the samples from GitHub, or creating a new application in Visual Studio or VS Code. Please have a quick look at the following short videos.
ThinkGeo Web for Blazor Quickstart On Windows
Run GitHub Sample in Visual Studio (2'30“)
ThinkGeo Web for Blazor Hello World
Create Hello World project in VS Code on Linux(3'09”)
Helps you get you up to speed with integrating the ThinkGeo Web for Blazor map control into your GIS software.
Product Guides
Introduces what licenses are needed / how the license would work for debugging/deploying the ThinkGeo products
Introduces the dependencies ThinkGeo Web for Blazor needs with their features, versions and source websites.
Introduces how to upgrade to ThinkGeo 12.0 from ThinkGeo 10.0 or previous version.
Explains how to use styles in ThinkGeo to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with ThinkGeo, as well as a step by step guide of creating your own custom styles.
Show ThinkGeo features coverage of different product and different platfoms
Code Samples
All the samples are available on Nuget through the link below.
Package
API Documentation
  • ThinkGeo.UI.Blazor
    It covers the ThinkGeo.UI.Blazor namespace which resides in the ThinkGeo.UI.Blazor.dll assembly, including the map control itself, Overlays, and supported map classes. It also covers all the types in ThinkGeo.Core which is the key dependency of Blazor.
Frequently Asked Questions
  • Do I have control over how the map looks and fits into my application
    Yes, absolutely. ThinkGeo Web for Blazor is a control, so you can easily integrate it into your application just like any other control from the Toolbox. We expose a large amount of APIs that allow you to customize every aspect of the map and the user interface so that they fit in with the look and feel of your application.
  • What other software is required to work with ThinkGeo Web for Blazor?
    Microsoft Visual Studio, or VS Code.
  • What type of map data does ThinkGeo Web for Blazor Support?
    ThinkGeo Web for Blazor comes with native support for the most popular vector and raster file formats, and includes a free extension that enables support for more than a dozen more vector formats and raster formats. Check out Data Formats Guide for detail.
  • How big of a learning curve is there to using ThinkGeo Web for Blazor?
    ThinkGeo Web for Blazor was designed to be easy to understand and easy to use. While mapping/GIS controls typically have a larger learning curve than other simpler controls like grids or charts, we feel ThinkGeo has taken the complexity out of mapping and allows you to develop your application in days or weeks instead of weeks or months.
  • Where do I go if I need help with ThinkGeo Web for Blazor?
Help & Support Guides
  • Support Options
  • Support Ticket Guide
  • Discussion Forum Guide
  • NuGet Guide
  • Release Cycle Guide
thinkgeo_web_for_blazor.1568918929.txt.gz · Last modified: 2019/09/19 18:48 by benbai
