thinkgeo_web_for_api
ThinkGeo Web for WebAPI
Note: This version of ThinkGeo Web API is based on .NET Standard 2.1 and is NOT supporting .NET Framework anymore(see .NET implementation support. Please use Map Suite 10 if you want to stay with .NET Framework. To upgrade a previously-built .NET Framework project to .NET Core, please refer to our guide "Updating from .NET Framework to .NET Core".
ThinkGeo Web for WebAPI allows you to easily build REST based web services to do the server side rendering, querying and geometric functions in your HTML5/Javascript application utilizing any JavaScript mapping client library (Leaflet, OpenLayers3 & KendoUI).
Helps you get you up to speed with integrating the ThinkGeo Web for API into your GIS software.
Product Guides
Walks you through installing the ThinkGeo Web for API on your system and creating a simple GIS application.
Introduces what licenses are needed and how licensing works for debugging and deploying projects using ThinkGeo UI.
Introduces the dependencies required by ThinkGeo Web for API, along with their features, versions and source websites.
Walks you through deploying your ThinkGeo Web for API project to your user base.
Lists the various GIS data formats that are supported by the ThinkGeo UI map control, as well as any caveats to be aware of with certain formats.
Describes how to upgrade to ThinkGeo UI 12 from previous versions of ThinkGeo UI or ThinkGeo Map Suite.
Explains how to use ThinkGeo UI's style system to beautifully represent your GIS mapping data. The guide includes an overview of styles, a detailed explanation of the various styles that ship with ThinkGeo, as well as a step-by-step guide to creating your own custom styles.
Explains how to use our custom serialization class to render your ThinkGeo objects to XML, or other format etc. This allows your GIS application to easily save things such as Layers, Styles, or even whole maps to XML to be recalled at a later time.
Walks you through various ways you can increase performance in your .NET mapping application.
Shows which ThinkGeo UI controls run on which platforms (Windows, Linux, MacOS, etc).
thinkgeo_web_for_api.1571303605.txt.gz · Last modified: 2019/10/17 09:13 by tgwikiupdate
