If you need to publish a desktop application that was developed with ThinkGeo UI for WPF components, it's required to publish your application along with the Runtime License. Otherwise, a map will be rendered with “Not Licensed for Run Time”. This guide demonstrate how to setup the runtime license.
A Runtime License can be generated by “ThinkGeo Product Center” which can be found from your application's bin folder (The same folder of the compiled *.exe file). Please double click ThinkGeo.MapSuite.ProductCenter.exe and switch to ThinkGeo UI Desktop for WPF tab as indicated in the figure below.
Click the Browse button on the right below RunTime License (The button is not available unless the product is activated) and select the application that you want to publish.
A “Save As” dialog will pop up after the application is selected. Click the “Save” button to generate runtime license file(*.mapsuitelicense) on your disk.
You can deploy your applications with following two ways:
Now the runtime license is ready for this application.
