thinkgeo_data_format_guide
ThinkGeo Data Format Guide
Vector Formats
Format Support Type Map Suite Version
ShapeFile1) Read/write 1.0
MapInfo TAB Read/write 5.0
ThinkGeo TinyGeo Read/write 6.0
ESRI File Geodatabase Read/write 7.0
Microsoft SQL Server Spatial 2008 and newer Read/write 3.0
Oracle Spatial Read/write 3.0
PostgreSQL PostGIS2) Read/write 3.0
S-57 Maritime Charts Read 8.0
GPX (GPs eXchange format) Read 8.0
Tobin TDRBM II (.bas) Read 8.0
ESRI Grid (.grd) Read 5.0
SQLite Read/write 8.0 (refresh)
Raster Formats
Mr. Sid Read 3.0
ECW Read 3.0
JPEG2000 Read 3.0
GeoTIFF Read 3.0
BMP Read 3.0
PNG Read 3.0
GIF Read 3.0
JPG Read 3.0
TIFF Read 3.0
Web Based Datasets
Format/Provider
Map Suite Version Description
World Map Kit Online 3.0 ThinkGeo's basemap based on Open Street Map Data that is displayed in most of the sample applications. You can check out what the maps look like at http://maps.thinkgeo.com
WMS (Web Map Service) 6.0 WMS is a open standard set by the OGC to consume maps over the web.
WFS (Web Feature Service) 6.0 WFS is a open standard set by the OGC.
Google Maps 3) 3.0 Google Maps
Bing Maps 4) 3.0 Bing Maps
NOAA Radar 8.0 NEXRAD Radar updated every 15 minutes covering most of the United States.
NOAA Weather Watches & Warnings 8.0 Current weather watches and warnings covering the United States.
NOAA Weather Stations 8.0 Current temperatures and other weather information from NOAA weather stations around the United States.
Additional Formats using the GDAL Extension
1) All versions of Map Suite support ShapeFile DBFs in the standard dBASE III format. Additionally, since Map Suite 8.0, DBFs in Visual FoxPro format are also supported.
2) Requires that you reference the free Postgre extension which is included with Map Suite.
3) *Use of Google Maps within a Map Suite developer SDK requires a Google Maps API For Business license and is subject to Google's licensing terms. For more information, please visit: https://developers.google.com/maps/licensing
4) *Use of Bing Maps within a Map Suite developer SDK requires a Bing Maps license and is subject to Microsoft's licensing terms. For more information, please visit: http://www.microsoft.com/maps/Licensing/licensing.aspx
thinkgeo_data_format_guide.1571627874.txt.gz · Last modified: 2019/10/21 03:17 by tgwikiupdate
