| Format | Support Type | Map Suite Version |
| ShapeFile1) | Read/write | 1.0 |
| MapInfo TAB | Read/write | 5.0 |
| ThinkGeo TinyGeo | Read/write | 6.0 |
| ESRI File Geodatabase | Read/write | 7.0 |
| KML (Keyhole Markup Language) | Read | 8.0 |
| Microsoft SQL Server Spatial 2008 and newer | Read/write | 3.0 |
| Oracle Spatial | Read/write | 3.0 |
| PostgreSQL PostGIS2) | Read/write | 3.0 |
| CAD formats .dwg and .dxf | Read | 8.0 |
| S-57 Maritime Charts | Read | 8.0 |
| GPX (GPs eXchange format) | Read | 8.0 |
| Tobin TDRBM II (.bas) | Read | 8.0 |
| ESRI Grid (.grd) | Read | 5.0 |
| SQLite | Read/write | 8.0 (refresh) |
| Mr. Sid | Read | 3.0 |
| ECW | Read | 3.0 |
| JPEG2000 | Read | 3.0 |
| GeoTIFF | Read | 3.0 |
| BMP | Read/Write | 3.0 |
| PNG | Read/Write | 3.0 |
| GIF | Read/Write | 3.0 |
| JPG | Read/Write | 3.0 |
| TIFF | Read/Write | 3.0 |
| Format/Provider | Map Suite Version | Description |
| World Map Kit Online | 3.0 | ThinkGeo's basemap based on Open Street Map Data that is displayed in most of the sample applications. You can check out what the maps look like at http://maps.thinkgeo.com |
| WMS (Web Map Service) | 6.0 | WMS is a open standard set by the OGC to consume maps over the web. |
| WFS (Web Feature Service) | 6.0 | WFS is a open standard set by the OGC. |
| Google Maps 3) | 3.0 | Google Maps |
| Bing Maps 4) | 3.0 | Bing Maps |
| NOAA Radar | 8.0 | NEXRAD Radar updated every 15 minutes covering most of the United States. |
| NOAA Weather Watches & Warnings | 8.0 | Current weather watches and warnings covering the United States. |
| NOAA Weather Stations | 8.0 | Current temperatures and other weather information from NOAA weather stations around the United States. |
