ThinkGeo Cloud Elevation provides the way to get elevation data from ThinkGeo's Cloud Server. Check out Get Elevation Along Path for a quick look.
The Elevation SDK supports querying of elevation data by points, line and polygon based on SRTM and Ned13 elevation source data. It returns 3 types of data:
* Try it Online: All of the ThinkGeo Cloud RESTful APIs can be tested online by following the instructions below:
ThinkGeo Cloud Elevation provides the following RESTful APIs:
<!-- Get the elevation of a point -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/{pointY},{pointX}
<!-- Get the elevation of points along a line -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/line
<!-- Get the elevation of a matrix of points within an area. -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/area
<!-- Get reverse geocoding for points -->
HTTP POST
https://cloud.thinkgeo.com/api/v1/location/reverse-geocode/multi
/* POST parameters, if a parameter specified in both POST and GET, the value from POST parameter will be applied. */ [ { "coord": "string", // The coordinates of the point. The format is: y,x. "srid": int, // The SRID (coordinate system) of the input feature. Defaults to 4326. "proj4String": "string", // The Proj4 (coordinate system) of the input feature. "elevationUnit": "string", // The unit of measure in which the elevation result is expressed. Defaults to "Feet". } ]
<!-- Get the grade (slope) of a line, optionally split into segments -->
HTTP GET
https://cloud.thinkgeo.com/api/v1/elevation/grade/line
A .Net SDK ThinkGeo Cloud Client is provided to consume the ThinkGeo Cloud Service as well. It's available on NuGet, here is the complete API List.
Sample Code:
ElevationClient elevationClient = new ElevationClient(clientId, clientSecret); elevationClient.BaseUris.Add(new Uri(GisServerUri)); var response = elevationClient.GetElevationOfLineAsync(line, 3857, numberOfSegments: pointNumber, elevationUnit: DistanceUnit.Meter);
Online Sample:
Desktop Sample:
