thinkgeo_cloud_.net_sdk
ThinkGeo Cloud .NET SDK
ThinkGeo Cloud .NET SDK helps developers use the ThinkGeo Cloud APIs in their .NET applications. You can use ThinkGeo Cloud API through standard RESTful API calls from any platforms any language and don't have to use this SDK at all. It's just to make your job a bit easier when with ThinkGeo Cloud on a .NET project.
Check out this Quick Start Guide to get started.
APIs
ThinkGeo Cloud .NET SDK wraps all the ThinkGeo Cloud RESTful APIs and make it simpler to use from a .NET project. The complete APIs are listed here and below are code snippets as samples:
Elevation
ElevationClient elevationClient = new ElevationClient(clientId, clientSecret);
elevationClient.BaseUris.Add(new Uri(GisServerUri));
var response = elevationClient.GetElevationOfLineAsync(line, 3857, numberOfSegments: pointNumber, elevationUnit: DistanceUnit.Meter);
Geocoding
GeocodingClient geocodingClient = new GeocodingClient(clientId, clientSecret);
geocodingClient.BaseUris.Add(new Uri(GisServerUri));
var result = geocodingClient.SearchAsync(searchText, options);
Reverse Geocoding
ReverseGeocodingClient reverseGeocodingClient = new ReverseGeocodingClient(clientId, clientSecret);
reverseGeocodingClient.BaseUris.Add(new Uri(GisServerUri));
ReverseGeocodingResult searchResult = await reverseGeocodingClient.SearchPointAsync(searchPoint.X, searchPoint.Y, 3857, searchRadius, DistanceUnit.Meter, reverseGeocodingOption);
Color
ColorClient colorClient = new ColorClient(clientId, clientSecret);
colorClient.BaseUris.Add(new Uri(GisServerUri));
var hueColors = colorClient.GetColorsInHueFamily(specifiedColor, numberOfColors);
Projection
ProjectionClient projectionClient = new ProjectionClient(clientId, clientSecret);
projectionClient.BaseUris.Add(new Uri(GisServerUri));
var projectedFeature = projectionClient.Project(feature, fromSrid, toSrid);
Raster and Vector Tile
MapsClient client = new MapsClient(clientId, clientSecret);
Stream imageStream = client.GetRasterTile(z, x, y, projection, mapType, tileSize, tileResolution);
Task<Stream> task = client.GetRasterTileAsync(z, x, y, projection, mapType, tileSize, tileResolution);
Not only we have APIs to get one single Vector Tile or Raster Tile, but we also provide a much simpler way in ThinkGeo UI Components as following to render the tiles on the map. Here below is an example for rending RasterTiles on a Desktop map (WPF):
ThinkGeoCloudMapsOverlay backgroundMap = new ThinkGeoCloudMapsOverlay(clientId, clientSecret);
Here below is an example for rending Vector Tiles on a Desktop map (WPF)
Samples
The following samples work in all of the Map Suite controls such as Wpf, Web, MVC, WebApi, Android and iOS.
Elevation
Geocoding
This Sample demonstrates how you can use ThinkGeo Cloud Client to get a geographic location into meaningful addresses from ThinkGeo GIS Server. It ships with an optimized set of worldwide coverage of cities and towns, but any customized data can be supported as well.
Reverse Geocoding
Colors
thinkgeo_cloud_.net_sdk.1549559806.txt.gz · Last modified: 2019/02/07 17:16 by benbai
