<!– Class –> This is the default constructor of this parameter.
*System.Object System.EventArgs *ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs
TrackEndedTrackInteractiveOverlayEventArgs | Constructor of TrackEndedTrackInteractiveOverlayEventArgs class. | ||
TrackEndedTrackInteractiveOverlayEventArgs | BaseShape | Constructor of TrackEndedTrackInteractiveOverlayEventArgs class. |
TrackShape | BaseShape | Gets or sets the tracked shape. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#TrackEndedTrackInteractiveOverlayEventArgs.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#TrackEndedTrackInteractiveOverlayEventArgs.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#TrackEndedTrackInteractiveOverlayEventArgs.28BaseShape.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#TrackEndedTrackInteractiveOverlayEventArgs.28BaseShape.29</a>
| trackShape | BaseShape<!– ThinkGeo.MapSuite.Core.BaseShape –> | This parameter specified the tracked shape. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#GetType.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#TrackShape” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs#TrackShape</a>
<!– ThinkGeo.MapSuite.WpfDesktopEdition.TrackEndedTrackInteractiveOverlayEventArgs –> Go Back
