thinkgeo.mapsuite.wpfdesktopedition.drawnoverlayeventargs
ThinkGeo.MapSuite.WpfDesktopEdition.DrawnOverlayEventArgs
<!– Class –> This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the Overlay has been drawn.
This is the event arguments for the OverlayDrawn event on the MapEngine class. It is raised after the Overlay has been drawn. This event allows you draw something with the canvas after the Layer draws.
Public MethodDrawnOverlayEventArgs Constructor of DrawnOverlayEventArgs class.
Public MethodDrawnOverlayEventArgs RectangleShape Constructor of DrawnOverlayEventArgs class.
Public MethodGetType Object
Public MethodToString Object
Public PropertyWorldExtent RectangleShape Gets or sets an extent for drawing an overlay.
DrawnOverlayEventArgs()
Overloads
This is the default constructor. If you use this constructor then you need to set the required properties manually.
Name Type Description
Go Back
DrawnOverlayEventArgs(RectangleShape)
Overloads
This constructor allows you to set the Overlay drawn, the world extent and the image you are drawing on.
worldExtent RectangleShape<!– ThinkGeo.MapSuite.Core.RectangleShape –> This parameter is an extent for drawing an overlay.
Go Back
Return Type Description
Boolean<!– System.Boolean –>
Int32<!– System.Int32 –>
Type<!– System.Type –>
String<!– System.String –>
Void<!– System.Void –>
WorldExtent
Return Type
<!– ThinkGeo.MapSuite.WpfDesktopEdition.DrawnOverlayEventArgs –> Go Back
thinkgeo.mapsuite.wpfdesktopedition.drawnoverlayeventargs.1440040136.txt.gz · Last modified: 2015/09/18 03:10 (external edit)
