<!– Class –> Represents an overlay object that gets map images from the WMS servers.
The <strong>WorldMapKitWmsWebOverlay</strong> gets images from four WMS servers that we specify by default. Usually, you add a WMS server URI to the <strong>ServerUris</strong> collection and the <strong>WorldMapKitWmsWebOverlay</strong> will make requests to that WMS servers to get its tile images.The WorldMapKitWmsWebOverlay will randomly send requests to those WMS servers in a concurrent fashion. This means that the tile images can come from different WMS servers, thus greatly enhancing performance.
*System.Object ThinkGeo.MapSuite.WebEdition.Overlay *ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay
WorldMapKitWmsWebOverlay | Initialize an instance of the WmsOverlay class. | ||
WorldMapKitWmsWebOverlay | String | Initialize an instance of the WmsOverlay class with the overlay identifier specified. | |
WorldMapKitWmsWebOverlay | WorldMapKitLayerType | ||
WorldMapKitWmsWebOverlay | String, WorldMapKitLayerType | ||
WorldMapKitWmsWebOverlay | String, TileType | Initialize an instance of the WmsOverlay class with the overlay identifier specified. | |
WorldMapKitWmsWebOverlay | String, TileType, WorldMapKitLayerType |
MemberwiseClone | Object | ||
OnTick | EventArgs | Overlay | Raises the Tick event of the MarkerOverlay. |
RegisterJavaScriptLibraryCore | Page | Overlay | Registers a Javascript library URL string to the client HTML page. |
Attribution | String | Overlay | |
AutoRefreshInterval | TimeSpan | Overlay | Gets or sets the time interval in which the MarkerOverlay refreshes itself. |
Id | String | Overlay | Gets the identifier for the overlay to be found. |
IsBaseOverlay | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is a base overlay. |
IsVisible | Boolean | Overlay | Gets or sets a value that indicates whether the overlay is visible on the map. |
IsVisibleInOverlaySwitcher | Boolean | Overlay | Gets or sets a value that indicates whether the overlay name is displayed in the OverlaySwitcher. |
LayerType | WorldMapKitLayerType | ||
MapType | WorldMapKitMapType | ||
Name | String | Overlay | Gets or sets the name of the overlay, which will display in the OverlaySwitcher. |
Opacity | Single | Overlay | Gets or sets the opacity level of the overlay. |
Projection | WorldMapKitProjection | Gets or sets a WorldMapKitProjection represents which projection will be used. | |
TileType | TileType | Gets or sets whether or not the WmsOverlay uses tiling. | |
TransitionEffect | TransitionEffect | Gets or sets the transition effect to use when the map is zoomed. | |
TransitionEffectDelayInMilliseconds | Int32 | ||
WrapDateline | WrapDatelineMode | Gets or sets a value that indicates whether the overlay wraps at the date line. |
HasTickEvent | Boolean | Overlay(overriden) | Don't support auto tick event by default. |
OverlayType | String | Overlay(overriden) | Gets a string that indicates the overlay type. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.29</a>
| id | String<!– System.String –> | The identifier string used to find the overlay. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28WorldMapKitLayerType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28WorldMapKitLayerType.29</a>
| layerType | WorldMapKitLayerType<!– ThinkGeo.MapSuite.Core.WorldMapKitLayerType –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.2C_WorldMapKitLayerType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.2C_WorldMapKitLayerType.29</a>
| id | String<!– System.String –> | |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.2C_TileType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.2C_TileType.29</a>
| tileType | TileType<!– ThinkGeo.MapSuite.WebEdition.TileType –> | Whether or not the overlay uses tiling. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.2C_TileType.2C_WorldMapKitLayerType.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WorldMapKitWmsWebOverlay.28String.2C_TileType.2C_WorldMapKitLayerType.29</a>
| tileType | TileType<!– ThinkGeo.MapSuite.WebEdition.TileType –> | |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Equals.28Object.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Equals.28Object.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#GetHashCode.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#GetHashCode.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#GetType.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#GetType.28.29</a>
Returns a JSON string which contains the information for creating an overlay at the client side.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#ToJson.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#ToJson.28.29</a>
| String<!– System.String –> | A JSON string which is used to create an overlay at the client side. |
<!– ThinkGeo.MapSuite.WebEdition.Overlay –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#ToString.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#ToString.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Finalize.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Finalize.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#MemberwiseClone.28.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#MemberwiseClone.28.29</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#OnTick.28EventArgs.29” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#OnTick.28EventArgs.29</a>
| e | EventArgs<!– System.EventArgs –> | An System.EventArgs object that contains the event data. |
The <strong>RegisterJavaScriptLibraryCore</strong> method allows derived classes to override and register their own Javascript library URL to the HTML page.
| page | Page<!– System.Web.UI.Page –> | The page object that is used for registering the javascript library. |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Attribution” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Attribution</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#AutoRefreshInterval” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#AutoRefreshInterval</a>
| TimeSpan<!– System.TimeSpan –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Id” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Id</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#IsBaseOverlay” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#IsBaseOverlay</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#IsVisible” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#IsVisible</a>
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#IsVisibleInOverlaySwitcher” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#IsVisibleInOverlaySwitcher</a>
<!– ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay –> Go Back
| WorldMapKitMapType<!– ThinkGeo.MapSuite.Core.WorldMapKitMapType –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Name” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Name</a>
The <strong>Opacity</strong> property enables you to specify a level of transparency for the overlay. When this property is set to a value less than 100 percent (1.00), the entire overlay is made more transparent. The lower the value, the more transparent it is. Setting this property to a value of 0 percent (0.00) makes the overlay completely invisible.
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Projection” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#Projection</a>
| WorldMapKitProjection<!– ThinkGeo.MapSuite.Core.WorldMapKitProjection –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#TransitionEffect” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#TransitionEffect</a>
| TransitionEffect<!– ThinkGeo.MapSuite.WebEdition.TransitionEffect –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WrapDateline” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#WrapDateline</a>
| WrapDatelineMode<!– ThinkGeo.MapSuite.WebEdition.WrapDatelineMode –> |
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#HasTickEvent” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#HasTickEvent</a>
<!– ThinkGeo.MapSuite.WebEdition.Overlay(overriden) –> Go Back
For the most updated Info for this topic, please check it here:<a href=“http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#OverlayType” target=“_blank”>http://wiki.thinkgeo.com/wiki/ThinkGeo.MapSuite.WebEdition.WorldMapKitWmsWebOverlay#OverlayType</a>
Occurs when the number of milliseconds specified in the AutoRefreshInterval property has elapsed and the page is posted to the server.
| Event Arguments |
NOTOC WebEdition ThinkGeo.MapSuite.WebEdition UpdateDocumentation
